LarsImNetz Posted January 2, 2023 Share Posted January 2, 2023 Hi all, for anyone of interest, find here the complete source code for building Pacmen evolution. pacmen.evolution Since it requires the wnf.compiler, you should follow the README and install all tools for build from scratch. Regards Lars 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted January 2, 2023 Share Posted January 2, 2023 6 minutes ago, LarsImNetz said: pacmen.evolution This is just a link to this thread. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted January 2, 2023 Share Posted January 2, 2023 (edited) A ground hog day link.. Edited January 2, 2023 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 2, 2023 Share Posted January 2, 2023 @LarsImNetz You attached a link to your own topic, you need to attach the files or the link to the files. Quote Link to comment Share on other sites More sharing options...
LarsImNetz Posted January 2, 2023 Author Share Posted January 2, 2023 Oh how embarrassing https://github.com/the-atari-team/tat.pacmen.evolution This is the real link. 1 2 Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted January 3, 2023 Share Posted January 3, 2023 Glad to see that you are using Atasm If you want any specific mods to the Assembler let me know. I've just recently (V1.20) added better support for .IF .ELSEIF .ELSE .ENDIF blocks (.ELSEIF is new) Quote Link to comment Share on other sites More sharing options...
LarsImNetz Posted January 3, 2023 Author Share Posted January 3, 2023 56 minutes ago, RetroCoder said: Glad to see that you are using Atasm If you want any specific mods to the Assembler let me know. I've just recently (V1.20) added better support for .IF .ELSEIF .ELSE .ENDIF blocks (.ELSEIF is new) Hi RetroCoder, yes, I would like to get one feature, I've not seen in any Assembler. You know the branch mnemonics bcc,bcs,bne,beq,... the greatest problem is the length of the jump, +-128 bytes. I would like to see something like long conditional jumps. Maybe name it LBCC, LBCS... or LCC, LCS... `LBCC jumpmark` could be replaced to `BCC jumpmark` as long as the jump is less than 128 bytes long and if the jump takes more bytes it will replaced by it's negative and a following jmp: # BCC with long jump BCS ?jumpover JMP jumpmark ?jumpover ... jumpmark At the moment this works only in a macro, if the jumpmark is before this construct. Would be nice if the jumpmark could be also in front. This could be nice. Also the ".if .ref " ... ".endif" feature of the mac65 could be nice to see. So the code could be smaller if some functions are not need to be build, because they are not referenced. Regards Lars Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted January 4, 2023 Share Posted January 4, 2023 23 hours ago, LarsImNetz said: Also the ".if .ref " ... ".endif" feature of the mac65 could be nice to see. So the code could be smaller if some functions are not need to be build, because they are not referenced. Hi Lars I fixed the .if .ref feature in atasm. Something like this will now create func1 but not func2. V1.21 has been pushed to github. *=$2000 jsr func1 rts .IF .REF func1 func1 lda #1 sta $4000 rts .ENDIF .IF .REF func2 func2 lda #1 sta $4000 rts .ENDIF As for the macro for the long jump, I'll take a look at that next. Cheers Peter Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted January 4, 2023 Share Posted January 4, 2023 On 1/3/2023 at 5:52 PM, LarsImNetz said: Hi RetroCoder, yes, I would like to get one feature, I've not seen in any Assembler. You know the branch mnemonics bcc,bcs,bne,beq,... the greatest problem is the length of the jump, +-128 bytes. I would like to see something like long conditional jumps. Maybe name it LBCC, LBCS... or LCC, LCS... `LBCC jumpmark` could be replaced to `BCC jumpmark` as long as the jump is less than 128 bytes long and if the jump takes more bytes it will replaced by it's negative and a following jmp: # BCC with long jump BCS ?jumpover JMP jumpmark ?jumpover ... jumpmark At the moment this works only in a macro, if the jumpmark is before this construct. Would be nice if the jumpmark could be also in front. Hi Lars Could you show me the macro you use and how you would like to have it work. Just write is as if the feature would be implemented already (and how you do it at the moment) Quote Link to comment Share on other sites More sharing options...
pps Posted January 4, 2023 Share Posted January 4, 2023 On 1/3/2023 at 4:52 PM, LarsImNetz said: Hi RetroCoder, yes, I would like to get one feature, I've not seen in any Assembler. You know the branch mnemonics bcc,bcs,bne,beq,... the greatest problem is the length of the jump, +-128 bytes. I would like to see something like long conditional jumps. Maybe name it LBCC, LBCS... or LCC, LCS... `LBCC jumpmark` could be replaced to `BCC jumpmark` as long as the jump is less than 128 bytes long and if the jump takes more bytes it will replaced by it's negative and a following jmp: # BCC with long jump BCS ?jumpover JMP jumpmark ?jumpover ... jumpmark At the moment this works only in a macro, if the jumpmark is before this construct. Would be nice if the jumpmark could be also in front. This could be nice. Also the ".if .ref " ... ".endif" feature of the mac65 could be nice to see. So the code could be smaller if some functions are not need to be build, because they are not referenced. Regards Lars For that I would go the way MADS uses... Simply type jne, jeq, jmi, jcs, jcc and you have that long jumps. 1 Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted January 6, 2023 Share Posted January 6, 2023 On 1/4/2023 at 8:02 PM, pps said: For that I would go the way MADS uses... Simply type jne, jeq, jmi, jcs, jcc and you have that long jumps. That is a good alternative but not quite the same. The JNE command always translates into the inverse branch and a jump. The idea here is that one can optimize this a little if you know the jump distance is going to be less than +- 128 then you can just branch per normal. If the distance is >128 then you can use the inverse-jump implementation. This is relatively easy to implement if you are jumping backwards in code, then the assembler would know the memory location of the target and you can decide which command sequence to use. But in a normal 2 pass assembler the forward references will prevent this from working. The best I can think off is to output an optimization list after the assembler where it may suggest to change the jne.. commands in bne at a specific file location. Quote Link to comment Share on other sites More sharing options...
pps Posted January 6, 2023 Share Posted January 6, 2023 Ah, yes it is the automatic switch which is wanted. I thought it was not included at all. but imho - that automatic switch is luxury. I am fine, when the assembler shouts, that the label is out of reach. Then simply change the b to a j and assemble it again. Did that thousands of time with mads Quote Link to comment Share on other sites More sharing options...
ggn Posted January 6, 2023 Share Posted January 6, 2023 I think that the assembler reporting of long jumps that could be short is the best solution. Can be ignored at will (or it could even be a switch so it isn't shown during assembly) during main development, then taken care of during the final stages of the project, or when the cycle budget gets tight. But the worst part with adding extra directives is tool lock-in. Suddenly your source isn't portable (for example if others want to use your code it won't be as straightforward), and not straightforward to read for someone who isn't accustomed to the tool. Just my 2 cents, and full disclosure: I do work on an assembler myself. Quote Link to comment Share on other sites More sharing options...
matosimi Posted January 6, 2023 Share Posted January 6, 2023 seems we got slightly off topic but see the MADS assembly+disassembly: short branches are preferred by MADS. 1 Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted January 11, 2023 Share Posted January 11, 2023 On 1/4/2023 at 8:02 PM, pps said: For that I would go the way MADS uses... Simply type jne, jeq, jmi, jcs, jcc and you have that long jumps. Good idea. Atasm 1.22 now has support for long jump branching (using the same names as mads). If 'beq target' is too far away simply use 'jeq target'. When using the jump-branch instructions and the target address is known during the first pass of the assembler and the distance is short then the code will generate the branch version of the command: 'jeq target' -> 'beq target' and not 'bne #3; jmp target' The assembler will dump a list of suggested optimizations at the end 2 2 Quote Link to comment Share on other sites More sharing options...
LarsImNetz Posted January 13, 2023 Author Share Posted January 13, 2023 Very nice, in my way, I have create a compiler which generate assembler source code. Due to simplification I can't check the jump range and now I will use the new jne/jeq... feature. Please give me some days to fix the compiler this way. Also I will add the working .if .ref feature into the libraries. Really great work. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
