Vyvyan B. Posted January 4, 2023 Share Posted January 4, 2023 (edited) On 7/15/2022 at 6:47 AM, Beeblebrox said: Go and log interest on the following thread, then wait till 2024 as the global chip shortage is dictating the next batch runs it's creator Simius can build. 2024 is the predicted date when he'll be able to get his hands on the chips. There is a massive preorder list. 🙁 Edited January 4, 2023 by Vyvyan B. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted January 4, 2023 Share Posted January 4, 2023 Not sure if the status has changed much but yeah, still believe that the global chip shortage will be delaying Sophia 2 batch runs for a good year. Then on top of that there is a massive waiting list. I was lucky enough to find a second hand Sophia 2 end of last year. Just to say there are alternatives which will give great outputs including: UGV UAV VBXE I have VBXE installed in an XE and also have a UGV unit coming destined for another XE (with U1MB). Quote Link to comment Share on other sites More sharing options...
Vyvyan B. Posted January 4, 2023 Share Posted January 4, 2023 Do any of those other options give you VGA out? And most everything seems to be equally unobtanium these days anyway. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted January 4, 2023 Share Posted January 4, 2023 (edited) 9 minutes ago, Vyvyan B. said: Do any of those other options give you VGA out? And most everything seems to be equally unobtanium these days anyway. Tied up at the mo but check out UGV and see: https://ataribits.weebly.com/ugv.html This is Mytek's creation. ***** VBXE rgb can be wired up to Scart and rgb monitor connectors See the files tab here: https://lotharek.pl/productdetail.php?id=53 ***** Uav here:https://atariprojects.org/2021/01/02/purchase-and-install-an-ultimate-atari-video-uav-for-better-composite-video-from-an-800xl-1-3-hours/ Edited January 4, 2023 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted January 4, 2023 Share Posted January 4, 2023 (edited) Another way to get VGA is use a decent upscaler. I hooked up to a VGA on a dell ultrasharp 2007fwp (or something like that) monitor in 2021 when I got back into the Atari scene. I used din to S-video to retroscaller 2 upscaler to an hdmi to VGA adapter. At the time it was the only way I could get my setup to work. If I was using an NTSC A8 machine at the time I probably would have been able to hook S-video directly up to said monitor. Sadly I was using PAL so the monitor wouldn't pick up on the signal on S-video or composite in connections. I've since got my LG lcd digital tv/monitor which is great. Use din to S-video or din13 to scart rgb or DVI from my various stock, VBXE or Sophia enabled A8's. Retroscaller 2 is a cheap but pretty good alternative to a retrotink. Edited January 4, 2023 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Vyvyan B. Posted January 4, 2023 Share Posted January 4, 2023 I use a 20" Trinitron (s-video) for my 800 and that's pretty good. But I'd like to mod one of my 800xl's with the U1MB and proper VGA monitor without an upscaler. Maybe an internal floppy too if I can fit it all in there. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted January 5, 2023 Share Posted January 5, 2023 22 hours ago, Vyvyan B. said: I use a 20" Trinitron (s-video) for my 800 and that's pretty good. But I'd like to mod one of my 800xl's with the U1MB and proper VGA monitor without an upscaler. Maybe an internal floppy too if I can fit it all in there. Nice BTW good news from Simius re Sophia 2: Quote Link to comment Share on other sites More sharing options...
mimo Posted January 5, 2023 Share Posted January 5, 2023 22 minutes ago, Beeblebrox said: Nice BTW good news from Simius re Sophia 2: That is great news 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 5, 2023 Share Posted January 5, 2023 the chips are slowly finding other avenues out of china, that is until the cccp catches thee... lolzorz Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted January 5, 2023 Share Posted January 5, 2023 On 1/3/2023 at 8:17 PM, Eksuhluhnt said: For now I believe I'll just upgrade the RAM but unsure what to buy? In addition to the upgrades mentioned previously, you may also want to take a look at the 64k SRAM Module for XL/XE computers (v3). Some minor soldering is required, but it's no more or less difficult than replacing the DRAM ICs. FWIW, you will need that machine to have 64K of base RAM if you ever plan on adding certain other upgrades, particularly those that use the PBI. Regardless of the upgrade you choose, it's pretty much necessary for compatibility with both those upgrades and most A8 software. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted January 6, 2023 Share Posted January 6, 2023 14 hours ago, x=usr(1536) said: In addition to the upgrades mentioned previously, you may also want to take a look at the 64k SRAM Module for XL/XE computers (v3). Some minor soldering is required, but it's no more or less difficult than replacing the DRAM ICs. FWIW, you will need that machine to have 64K of base RAM if you ever plan on adding certain other upgrades, particularly those that use the PBI. Regardless of the upgrade you choose, it's pretty much necessary for compatibility with both those upgrades and most A8 software. Though maybe not as cheap as changing a couple of old DRAM chips, this is a much better option, long-term, as it replaces several other devices in the memory circuit that prone to failure. Quote Link to comment Share on other sites More sharing options...
Steril707 Posted January 8, 2023 Share Posted January 8, 2023 I bought an AVG cart for my 600XL, and can play like very game under the sun with it. Still searching for something to get a better video output and not happy with the keyboard as well.. Quote Link to comment Share on other sites More sharing options...
