neogeo1982 Posted November 26, 2023 Share Posted November 26, 2023 I played mostly 1 modern game this week, but still had some Sega time. Game Gear Battletoads - 30min Columns- 25min 6 Quote Link to comment Share on other sites More sharing options...
Kurt_Woloch Posted November 26, 2023 Share Posted November 26, 2023 (edited) Here are my times for this week (November 20th through 26th) on classic systems: Battle Zone (Bootleg of Mayday) - 44 min. Battletoads - 4 min. Bells & Whistles - 40 min. Birdiy - 10 min. Block Block - 37 min. This week I continued with the quest of getting to know and replay several arcade games in alphabetical order. Battle Zone (Bootleg of Mayday) has got nothing to do with Battlezone by Atari, it's rather similar to Defender, but a bit simpler. Actually it seems to run on Joust hardware, at least it takes over some of the sounds of Joust, which probably means it has the same sound CPU running the same software as in Joust, as the sounds are procedurally generated there. Incidentally, I started to disassemble the sound code of Joust a while ago since I wanted to improve the inofficial C-64 version by Joust which you can find here: Joust (C64) - 1984 Atarisoft - GTW64 (gamesthatwerent.com) As you can see there, the C64 version was done by Jack Verson and is actually a hack of the Atari 8-bit version. Though the gameplay works fine, the sound hasn't been ported over very well. I've peeked into the sound routine, and it seems to just convert the POKEY sound data to the SID format, which doesn't work very accurately at all. Thus, I thought of re-creating the sound for the C-64 version from scratch, based on the original sound code. I've attached my disassembly to this post, of the code which I guess is also being used in "Battle Zone". The game itself is a bit hard. Similar to Defender, you blow up enemies, but they move in different patterns. Instead of the smart bombs, you have something that slows you down very much for a time. Battletoads is another Jump & Run game which I don't like as much as the Asterix game I played lately. Bells & Whistles is a game I liked to play back in the day, a vertical scrolling shooting game similar to Xevious and Parodius, with the extras being given by bells coming out of clouds. The bells change color if you hit them often enough, and then they give different extras. In their standard color they only give points though. Birdiy is a non-scrolling game where you have to feed birds in a nest. This one seems to based on Pengo hardware as far as I can tell, but strangely it ends each round after feeding a single bird. It didn't hold my attention for too long. It has an interesting high score music though, which seems to push the Namco sound chip a bit farther than any other game I've seen, providing drums. Block Block is another Breakout clone, similar to Arkanoid, but here you have horizontal and vertical blocks, and later levels add pinball elements to keep things interesting. It takes longer to finish a round though because there's no extra that would give you the capability to shoot blocks. joust.asm Edited November 26, 2023 by Kurt_Woloch 6 Quote Link to comment Share on other sites More sharing options...
carlsson Posted November 27, 2023 Author Share Posted November 27, 2023 Another week of zero minutes. Hopefully 2024 will be slightly less frantic with more time to play games. 5 1 Quote Link to comment Share on other sites More sharing options...
agb Posted November 27, 2023 Share Posted November 27, 2023 On 11/22/2023 at 12:27 PM, Atarian7 said: I played Solar Fox to 8.5 million last night, but got bored and screwed up. The fun part is clearing Rack 255. That always give me a little bit of an adrenaline rush. Great score Atarian7. Will you be going for the all time record soon? Times Atari 2600 Red Sea Crossing 15 FB HSC River Raid Brazil version 10. Much more difficult than regular version. Skiing 16 FB HSC Solar Fox 182 all fun. 6 1 Quote Link to comment Share on other sites More sharing options...
Skippy B. Coyote Posted November 27, 2023 Share Posted November 27, 2023 Lots of gaming laid back in bed while I continue recovering from that surgery I had a few weeks ago, and this week the Anbernic RG35XX was my bed buddy. I ended up playing a ton of Monopoly for the Game Boy Color on it, and used it to play some Samurai Shodown II for the Neo Geo and do full playthroughs of Ristar and Ecco Jr. for the Sega Genesis as well. Game Boy Color Monopoly - 350 minutes Neo Geo Samurai Shodown II - 31 minutes Sega Genesis Ecco Jr. - 100 minutes Ristar - 154 minutes 7 Quote Link to comment Share on other sites More sharing options...
Wayler Posted November 27, 2023 Share Posted November 27, 2023 I grabbed a controller again for the longest time. Corona and the allotted free time does that. Tried out a few fastROM hacks and found out Axelay was way harder this way. Tackling Terranigma as an ongoing playthrough. SNES Axelay - 30 min Darius Twin - 10 min Parodius - 10 min Terranigma - 345 min 7 Quote Link to comment Share on other sites More sharing options...
Keir Posted November 27, 2023 Share Posted November 27, 2023 Only tabletop gaming for me last week! 5 1 Quote Link to comment Share on other sites More sharing options...
Atarian7 Posted November 27, 2023 Share Posted November 27, 2023 Atari 2600 Kaboom! - 137 minutes Solar Fox - 103 minutes I don't know about going for the all-time record on Solar Fox. 6 Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted November 27, 2023 Share Posted November 27, 2023 My times for the week: Intellivision: Frog Bog - 2 min. Earthshaking stuff. Or, at least, lily-pad-shaking. 4 3 Quote Link to comment Share on other sites More sharing options...
+jgkspsx Posted November 28, 2023 Share Posted November 28, 2023 Not much for me this week, and like @Kurt_Woloch all arcade for once! Arcade: BattleZone - 10 minutes First time I've ever played a real machine with the periscope! Flying Shark - 75 minutes I just can't crack 100k... Frogger - 5 minutes Embarrassing performance... Punch Out - 10 minutes Q*Bert - 15 minutes Real machine, ugly LCD screen. Oh well. Space Invaders - 10 minutes Volfied - 25 minutes Beyond my own arcade time I also got to introduce three young second cousins to Gauntlet. They played for a half an hour with only two quarters to top them off! They also enjoyed Q*Bert and Frogger. 6 Quote Link to comment Share on other sites More sharing options...
carlsson Posted November 28, 2023 Author Share Posted November 28, 2023 Here's the summary for Week 47, running from November 20 - 26. We logged 1835 minutes of eligible play, playing 28 games on a total of 8 systems. Top 10: 1. Monopoly (Game Boy Color) - 350 min. 2. Terranigma (SNES) - 345 min. 3. Solar Fox (Atari 2600) - 285 min. (#1) 4. Ristar (Genesis) - 154 min. 5. Kaboom! (Atari 2600) - 137 min. (#4) 6. Ecco Jr (Genesis) - 100 min. 7. Flying Shark (Arcade) - 75 min. (#7) 8. Battle Zone (bootleg of Mayday) (Arcade) - 44 min. 9. Bells & Whistles (Arcade) - 40 min. 10. Block Block (Arcade) - 37 min. Pre-NES top 10: 1. Solar Fox (Atari 2600) - 285 min. (PN#1) 2. Kaboom! (Atari 2600) - 137 min. (PN#2) 3. Battle Zone (bootleg of Mayday) (Arcade) - 44 min. 4. Skiing (Atari 2600) - 16 min. (PN#7) 5. Q*Bert (Arcade) - 15 min. 5. Red Sea Crossing (Atari 2600) - 15 min. 7. Battlezone (Arcade) - 10 min. 7. Birdiy (Arcade) - 10 min. 7. Punch-Out (Arcade) - 10 min. 7. River Raid Brazil (Atari 2600) - 10 min. 7. Space Invaders (Arcade) - 10 min. Top 10 systems: 1. Atari 2600 (5 games) - 463 min. (#2) 2. SNES (4 games) - 395 min. 3. Game Boy Color (1 game) - 350 min. 4. Arcade (12 games) - 285 min. (#3) 5. Genesis (2 games) - 254 min. 6. Game Gear (2 games) - 55 min. (#1) 7. Neo Geo AES/MVS (1 game) - 31 min. 8. Intellivision (1 game) - 2 min. While the overall numbers are on the low side, the battle for the title is close with 5 min between Monopoly and Terranigma. The pre-NES duo Solar Fox and Kaboom! are in a class of their own, and brings the Atari 2600 to the systems title. No changes to the 1000, 5000, 10000 Minute Clubs. 4 2 Quote Link to comment Share on other sites More sharing options...
Atarian7 Posted November 29, 2023 Share Posted November 29, 2023 I wonder: Did participation drop off last year during Thanksgiving week? 2 Quote Link to comment Share on other sites More sharing options...
carlsson Posted November 29, 2023 Author Share Posted November 29, 2023 2022 weeks 45-48: 7300, 3600, 3900, 3300 min 2023 weeks 45-47: 3000, 2000, 1800 min 2 2 Quote Link to comment Share on other sites More sharing options...
Atarian7 Posted November 29, 2023 Share Posted November 29, 2023 So it did drop some although from a higher starting point. 2 Quote Link to comment Share on other sites More sharing options...
carlsson Posted November 29, 2023 Author Share Posted November 29, 2023 More detailed comparison of participation in November: 2019 Week 45: 3855 min, 47 games, 16 systems Week 46: 2422 min, 49 games, 11 systems Week 47: 2912 min, 56 games, 13 systems Week 48: 3147 min, 46 games, 10 systems 2020 Week 45: 2607 min, 50 games, 10 systems Week 46: 1772 min, 44 games, 8 systems Week 47: 2421 min, 38 games, 10 systems Week 48: 3678 min, 75 games, 15 systems 2021 Week 45: 4087 min, 56 games, 18 systems Week 46: 4741 min, 57 games, 16 systems Week 47: 5306 min, 103 games, 20 systems Week 48: 5236 min, 79 games, 19 systems 2022 Week 45: 7286 min, 99 games, 22 systems Week 46: 3621 min, 76 games, 21 systems Week 47: 3931 min, 87 games, 23 systems Week 48: 3365 min, 84 games, 19 systems 2023 Week 45: 2992 min, 124 games, 12 systems Week 46: 2034 min, 48 games, 12 systems Week 47: 1835 min, 28 games, 8 systems So we're currently back to 2020 levels, roughly speaking, after two somewhat more active years. 3 4 Quote Link to comment Share on other sites More sharing options...
Hwlngmad Posted November 30, 2023 Share Posted November 30, 2023 So, I was away for a bit for a trip with the family to Lima, Peru. However, I did do some gaming while I was away. I will leave it to carlsson to figure out exactly how we wants to record this. My times from 11/19 to 11/29 were: Game Boy 1) BreakThru! - 40 minutes GBC 1) 720 - 25 minutes 2) Klustar - 10 minutes 3) NBA In the Zone - 5 minutes 4) Rampage World Tour - 20 minutes 5) Wario Land II DC - 20 minutes 6) Wendy: Everyday Witch - 25 minutes Game Gear 1) Side Pocket - 20 minutes 5 Quote Link to comment Share on other sites More sharing options...
+jgkspsx Posted December 1, 2023 Share Posted December 1, 2023 3 hours ago, Hwlngmad said: 5) Wario Land II DC - 20 minutes 6) Wendy: Everyday Witch - 25 minutes DC? DX? I think it's Wendy: Every Witch Way. 4 Quote Link to comment Share on other sites More sharing options...
Hwlngmad Posted December 1, 2023 Share Posted December 1, 2023 13 hours ago, jgkspsx said: DC? DX? I think it's Wendy: Every Witch Way. So, it is just "Wario Land II" and then "Wendy: Every Witch Way". Thanks! 4 Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 3, 2023 Author Share Posted December 3, 2023 Arcade: Giga Wing - 10 min. SNES: Barbie Vacation Adventure - 10 min. Cool Spot - 5 min. A bit unusual choices for me. While I didn't play any games of my own intention this week, we had a Christmas party to which a friend of mine had brought a device with 30,000 pirated games, ranging from a handful Atari games, via Famicom, Super Famicom, Game Boy and Genesis to arcade ROMs. We played a few different ones, and the above ones were the ones I bothered to take notes what they were. Apparently the Barbie game origins from a leaked prototype as the game never made the market, and while I'm definitely not in the demographic for the game, it had some interesting elements like jumping over rivers, shooting (pictures of) animals, finding hidden presents etc. The last part felt a bit like Impossible Mission minus the robots. 5 Quote Link to comment Share on other sites More sharing options...
Kurt_Woloch Posted December 3, 2023 Share Posted December 3, 2023 Here are my times for this past week (November 27th through December 3rd, 2023): Arcade: Arabian - 96 min. in 3 sessions Block Hole - 20 min. MSX: Moonsweeper - 18 min. This week, my main game was "Arabian" which I remembered from a previous session, and this time I played it until I managed to get through all 4 screens after which the screens repeat with harder difficulty. Today, I set out to do the same thing again, and strangely, it took me longer to achieve that than the previous sessions of this week combined. What I noticed about this game are different levels of transparency... you can notice the "Kangaroo effect" in some places, especially with the flying carpets. As far as I can see in the MAME driver, it used bitmapped graphics as well as sprites, so the carpets may be software sprites because they run out of hardware sprites to use which would explain their limited transparency. A new game in the "A-Z" series was Block Hole, I think by Konami, which I remember having played back in the day in the arcade as well. Finally, I played the MSX version of Moonsweeper. I chose this version because it's the only version of this game available on Retrogames.cc. It looks and feels very much like the TI-99/4A version, but runs at a higher framerate because the MSX systems have a faster processor. 5 Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted December 4, 2023 Share Posted December 4, 2023 My times for the week: Intellivision: Frog Bog - 14 min. Princess Quest - 42 min. Sydney Hunter and the Sacred Tribe - 70 min. Beat two Intellivision homebrews; thoughts here. 6 Quote Link to comment Share on other sites More sharing options...
+jgkspsx Posted December 4, 2023 Share Posted December 4, 2023 Lots of stuff on a lot of systems this week. Arcade: Battle Chopper/Mr Heli no Daibouken - 75 minutes Finally cracked 100k! Flying Shark - 80 minutes Finally cracked 100k! Nitro Ball - 10 minutes Puzzle Bobble/Bust a Move - 20 minutes Finally cracked 100k! (Okay, by a good ways.) Task Force Harrier - 35 minutes Finally cracked... you get the idea. Amiga: Bridge Strike - 25 minutes Carried over from last week, oops. Atari 2600: Trying out the new Atari paddles and carts. Really nice! Berzerk Enhanced Edition (2023) - 25 minutes This is a new official version different than the Atari original or the AtariAge enhanced edition. Breakout - 15 minutes I honestly don't think I've ever played this version before. Canyon Bomber - 10 minutes Night Driver - 5 minutes Video Olympics - 15 minutes It started out as a pitched battle against the CPU and then after it got to 11 it turned into a bloodbath. I am not sure I ever played this either? Game Boy Color: Wario Land 3 - 5 minutes Intellivision: Night Stalker - 45 minutes Neo Geo: Zed Blade - 65 minutes Odyssey2: Killer Bees! - 25 minutes P.T. Barnum's Acrobats! - 45 minutes Thanks to The Voice this is probably my favorite Circus Atari take ever. TURKEY! Q*Bert! - 10 minutes Seems very laggy. Playing PAL conversion on multicart so I am not sure if that is part of it? PlayStation: Impact Racing - 25 minutes San Francisco RUSH - 15 minutes The X-Files: The Game - 75 minutes Did Apple and Nokia actually license this??? R-Zone: Mortal Kombat Trilogy - 25 minutes Beat it and then played some more. 5 Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted December 4, 2023 Share Posted December 4, 2023 PC Engine Overload heh PC Engine: Coryoon: Child of Dragon - 122 mins Tatsujin - 12 mins W-Ring - The Double Rings - 10 mins Burning Angels - 14 mins Neutopia - 74 mins Dead Moon - 26 mins Barunba - 17 mins Terra Cresta II 45 mins Formation Armed F 16 mins Soldier Blade 31 mins Override - 18 mins Final Sodier - 28 mins Gunhed - 53 mins Daisenpuu - 14 mins Dinoforce - 10 mins Antlantean - 11 mins Magical Chase 14 mins Ankoku Densetsu (AKA The Legendary Axe II but that's funny cause you start with a sword but from what I know it's not actually a sequel lol) 27 mins Hatris - 29 mins PC Engine CD: Star Parodier - 33 mins 7 Quote Link to comment Share on other sites More sharing options...
Wayler Posted December 4, 2023 Share Posted December 4, 2023 Just continuing my travel through the world this week. Managed to beat the most overpowered boss in Spain, hopefully it's smoother sailing after that. SNES Terranigma - 304 min 5 Quote Link to comment Share on other sites More sharing options...
Hwlngmad Posted December 4, 2023 Share Posted December 4, 2023 Here are my totals from 12/1 to 12/3. My times were: N64 1) Star Wars Episode I: Racer - 55 minutes 2600 1) Air Raiders - 5 minutes 2) Bridge - 25 minutes 3) Front Line - 5 minutes 4) Ms. Pac Man - 20 minutes 5) Rally-X - 15 minutes 6) Space Invaders - 20 minutes 4 Quote Link to comment Share on other sites More sharing options...
