800_Rocks Posted January 16, 2023 Share Posted January 16, 2023 Hi - I am very rusty on MAC/65. I manually keyed-in the first example ASM program in the good old book ‘Atari Roots’. I know the spacing is critical. I have two spaces between line numbers and the start of anything else. with the exception of only one space before and after the label ‘ADDNRS’. After successful ‘ASM’ assembly I expect my little program to be automatically stored at memory location 0600 hex because of the ‘.OPT OBJ’ directive on line 05 However when I go into the DDT debugger and display memory at 0600 hex I do not find my code. So it seems my .OPT OBJ directive is being ignored?! Ideas? TIA Quote Link to comment Share on other sites More sharing options...
+MrFish Posted January 16, 2023 Share Posted January 16, 2023 See sections 8.1 and 8.2 of the Mac/65 manual. 1 Quote Link to comment Share on other sites More sharing options...
800_Rocks Posted January 16, 2023 Author Share Posted January 16, 2023 27 minutes ago, MrFish said: See sections 8.1 and 8.2 of the Mac/65 manual. That was it! Thank you!! I sure don’t remember the need to do that back in the day. I am running a physical MAC/65 cartridge but doing so with my U1MB 800XL. Back in the day I was using a stock 800. I followed the procedure described in the MAC/65 manual section 8.2 “Assembling with an offset .SET 6” after instructing the debugger to move memory from $3600 to $600 I finally see my tiny bit of code!! After the DDT command to MOVE bytes from $3600 to $0600 the *600 command shows my tiny program in memory at $0600 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted January 16, 2023 Share Posted January 16, 2023 8 minutes ago, 800_Rocks said: I sure don’t remember the need to do that back in the day. It's only for those memory-conflict situations; but a lot of BASIC ML Subs love to live in page six. It's a pretty simple workaround. Quote Link to comment Share on other sites More sharing options...
