pmgraphics Posted January 19, 2023 Share Posted January 19, 2023 With Altirra, I attached the ATARI Assembler Editor rom. I then load an ASM file (ENTER #D:FILE.ASM). I can LIST the program to see the code. I then assemble the code with ASM,,#D:FILE.OBJ. How do I then run the program? I detached the Assembler Editor and entered DOS, selected LOAD BINARY FILE and provided D:FILE.OBJ, but nothing happened. My test ASM file is BOPOTRON.ASM from ANALOG #24. thanks Quote Link to comment Share on other sites More sharing options...
+videofx Posted January 20, 2023 Share Posted January 20, 2023 Bopotron.asm is only the assembly language to show you how they wrote the machine language for the basic program. It will not run on its own. You need to enter the basic program which has all the DATA statements for the assembly language. If you can find the disk for Analog #24 then you can just run the Bopotron.bas Quote Link to comment Share on other sites More sharing options...
ascrnet Posted January 20, 2023 Share Posted January 20, 2023 in other words, it is the source code of the machine routines used by the basic program for the movement of the PM. BOPOTRON.BAS 😉 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 20, 2023 Share Posted January 20, 2023 wasn't the idea to use the basic bopotron with the asm appended and avoid basic poking all of that in? Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 20, 2023 Share Posted January 20, 2023 I tried to explain this on the issue #24 post "BOPOTRON.OBJ is not a game, just a compiled version of the data statements in the BASIC program." 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 20, 2023 Share Posted January 20, 2023 @pmgraphics kinda fun learning this stuff again, eh? I've had to download a bunch of manuals to work with these magazine files. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 20, 2023 Share Posted January 20, 2023 (edited) 7 minutes ago, SoulBuster said: I tried to explain this on the issue #24 post "BOPOTRON.OBJ is not a game, just a compiled version of the data statements in the BASIC program." yup you did. sometimes we have to connect all the dots it seems. That's ok though tomorrow I'll be clueless and need to be told my name so look whos talkin' re learning is part of the experience Edited January 20, 2023 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
pmgraphics Posted January 20, 2023 Author Share Posted January 20, 2023 Thanks for all the replies. I was doing this more for an exercise to see how to use these assembly listings that I recall seeing as a kid and had no idea about. If the assembly listing that I used was a complete functioning program would my steps have worked to run it? Back in the day if someone had the Assembler Editor, what would they have done with these assembly listings in ANALOG if they weren't functioning programs? 1 Quote Link to comment Share on other sites More sharing options...
Mark2008 Posted January 20, 2023 Share Posted January 20, 2023 I haven't used that cart for a while, but if you know the starting address, you go into the debugger and start executing at the address. this is from the wiki ASM BUG G600 X compile, enter debugger, G600 because 600 is the init run address for the wiki's example program. The last command is to exit. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 20, 2023 Share Posted January 20, 2023 44 minutes ago, pmgraphics said: Thanks for all the replies. I was doing this more for an exercise to see how to use these assembly listings that I recall seeing as a kid and had no idea about. If the assembly listing that I used was a complete functioning program would my steps have worked to run it? Back in the day if someone had the Assembler Editor, what would they have done with these assembly listings in ANALOG if they weren't functioning programs? In short, yes. You have been following that other thread, there have been a few of the games that did compile into working games. Scroll back, read descriptions and find one that interests you. Or better yet, go to post 1 as a menu. 18 minutes ago, Mark2008 said: I haven't used that cart for a while, but if you know the starting address, you go into the debugger and start executing at the address. this is from the wiki ASM BUG G600 X compile, enter debugger, G600 because 600 is the init run address for the wiki's example program. The last command is to exit. I am focused on one job right now, but I have to say ... figuring out which assembler to use has been fun, and given the time after I complete the disks, I might give Atari Assembly a go. I like MAC/65. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 20, 2023 Share Posted January 20, 2023 Just in case this helps, I wrote this eons ago to convert any file into DATA statements for BASIC or Assembler. Probably better than this today, but saved my tons of time bitd. AUTONUM.XEX 1 Quote Link to comment Share on other sites More sharing options...
