hueyjones70 Posted January 25, 2023 Share Posted January 25, 2023 I don't think this problem is peculiar to the 130XE. I am getting power to the power connector and to the switch. When I place the switch in the ON position I don't get any power. The power connector and the switch show zero voltage. I replaced the switch and got the same results. I can't imagine what is causing it. I thought maybe there was a short to ground but nothing gets warm and there is no voltage reading anywhere on the board. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 25, 2023 Share Posted January 25, 2023 It's a simple circuit in terms of what you stated. Power supply, switch, and filter cap, so unless there is a break, a short, dead cap or faulty power supply that shuts down under load there isn't much else. You might want to rethink on this and make sure you have the correct switch type as well. Make sure no contact with lower shield is occurring etc. Otherwise the problem is deeper than you think. Your short does not have to make a component hot, and may not be a component at all as there is more than one way to have a short. Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted January 26, 2023 Author Share Posted January 26, 2023 The switch is standard replacement from BEST. I haven't checked the filter cap, is it the large upright cap nearest the switch (C1)? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 26, 2023 Share Posted January 26, 2023 (edited) Correct that's the first major one. Edited January 26, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted January 26, 2023 Author Share Posted January 26, 2023 Thanks, that gives me a starting point. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 26, 2023 Share Posted January 26, 2023 As @_The Doctor__ says, it's highly likely a short somewhere, the PSU is just shutting down to protect itself. Put your meter on "Ohms" across the 5V and 0V lines of the 130XE with the PSU disconnected, you should be seeing a very low reading if there's a short. Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted January 30, 2023 Author Share Posted January 30, 2023 Would that be at the power jack? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 30, 2023 Share Posted January 30, 2023 yes Quote Link to comment Share on other sites More sharing options...
