mjm101 Posted February 9, 2002 Share Posted February 9, 2002 I have a problem with my atari 800 XL. when I put my atari on it gives a black/brown color on my tv screen. Does anyone knows what it is? Quote Link to comment Share on other sites More sharing options...
classics Posted February 10, 2002 Share Posted February 10, 2002 quote: Originally posted by keezx: I have a problem with my atari 800 XL. when I put my atari on it gives a black/brown color on my tv screen. Does anyone knows what it is? Check your power supply, make sure its putting out 5V+. The other most common failure in the 800XL is a bad ram chip, just grab a known-good 64kx1 RAM and start swapping them one at a time. Quote Link to comment Share on other sites More sharing options...
Gunstar Posted February 10, 2002 Share Posted February 10, 2002 If it is just a bad ram chip, you can turn on the computer without anything else on, holding the option button and it will go into a diagnostic mode which includes rom&ram tests. If you can't get to this system test, there's more wrong than just a memory chip out. If you can, it will show you which bank of memory it is, and then a little further deduction will clue you into which chip it is on the board. Quote Link to comment Share on other sites More sharing options...
classics Posted February 13, 2002 Share Posted February 13, 2002 I've seen planty of machines that would not even enter the self-test because of a bad ram. Quote Link to comment Share on other sites More sharing options...
