Fonzie Posted February 7, 2023 Share Posted February 7, 2023 I love tinkering on real iron. Today, on a whim I decided to try to compile a simple xb using Classic99 and the latest XBGDP. Downloaded and installed Classic99 Q1399.663 and Juwel4 +GEM. I put the Juwel99 folder in with DSK 1,2 & 3 of CLASSIC99. Configured Disk 1 to .\Juwel99\ and checked the appropriate boxes as shown in the XBGDP.pdf. I ran Hello slow & fast and saved it. Everything seemed to run ok. Xb, compiler, assembler until the R underscore. Hitting enter brings up **DSR ERROR:00F4 DSK1.RunTime1.TXT. I’m embarrassed to tell you how many times I’ve blown away both programs re-downloaded them again and tried many variations to no avail. Any Ideas? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted February 7, 2023 Share Posted February 7, 2023 Check how you configured DSK1. Make sure it matches what the manual says it should be. There is a box that must be checked in order to read windows text files. Quote Link to comment Share on other sites More sharing options...
Fonzie Posted February 8, 2023 Author Share Posted February 8, 2023 Yes, I double checked. All boxes are checked as shown in the image on the pdf. Quote Link to comment Share on other sites More sharing options...
Fonzie Posted February 8, 2023 Author Share Posted February 8, 2023 Don't know if this means anything but immediately after the error message:**DSR Error:00f4 DSK!.runtime1.txt (there is a space followed by 2 or 3 jibberish characters). Also, checking the Juwel folder there is no file listed as runtime1.txt. There are ,however, several files named runtim(1-9) -s. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted February 8, 2023 Share Posted February 8, 2023 That error code is telling you that the assembler cannot find RUNTIME1.TXT, which you have already figured out. I think you have used the "real iron" version of the compiler which is in the folder JUWEL99. Read page 3 of Using XBGDP.pdf and that should guide you in the right direction. I see that file needs some slight updating. It was for the ISABELLA version, but you just have to substitute JUWEL for ISABELLA Quote Link to comment Share on other sites More sharing options...
Fonzie Posted February 8, 2023 Author Share Posted February 8, 2023 Thanks Harry. Once I put the Juwel4 folder into the classic99 folder alongside DSK1 ,2, and 3, it all worked perfectly. 1 Quote Link to comment Share on other sites More sharing options...
