reifsnyderb Posted August 7, 2023 Author Share Posted August 7, 2023 (edited) I decided to finish up OS 6.1 today. Summary of changes from OS3 are: Fix MAXDEV, problems resulting from CRASS65 version, initial address for RAM sizing, "Boot Error" message, initial address for cartridge equivalence checksum, mishandling of SIO NAK, and initializing of CHKSUM. R. K. Nordin 03/27/84 Merged from Revision 3, Version 2 (600XL/800XL/1450XLD) Dedicate PDVI ($D1FF) to external parallel device IRQ status Dedicate IPDVI ($D1CF) to internal parallel device IRQ status Using PDIMSK ($0249) for external parallel device IRQ selection mask Using IPDIMK ($0254) for internal parallel device IRQ selection mask After masking (PDVI, PDIMSK) & (IPDVI, IPDIMK), OR the result together, prior to processing parallel device IRQ On cold start, initialize PDVI = 0, to avoid potential checksum error. Y. T. JANG, V. WU 02/22/84 Merged from Revision 3, Version 3 (600XL/800XL/1450XLD) Dedicate the 11 bytes at ACMVAR ($3ED-$3F7) for use as a RESET routine area. On warmstart, the OS will JSR to ACMVAR immediately after initializing hardware. MIKE BARALL 06/08/84 Merged from Revision 3, Version 4 (600XL/800XL/1450XLD) Make CIO accept device number 0 (like Rev B did). MIKE BARALL 06/21/84 Merged from Revision 4, Version 0 (600XL/800XL/1450XLD) In PBK, change DEC BRKKEY to STA BRKKEY. Mike Barall 07/24/84 Changes by Brian E. Reifsnyder Shift-Control-Delete cold starts the computer. Control-Help sets left screen margin to 0. Processing of Control F1 through Control F4 no longer affects PORTB. Left margin set to 0. Reduced KRPDEL from 48 to 20 for NTSC and from 40 to 20 for PAL. Reduced KEYREP from 6 to 4 for NTSC and from 5 to 4 for PAL. Cleaned up and reorganized KIR. Re-added F1-F4 keys to the keyboard self test. Re-wrote the majority of the self test to conserve space. Added a built-in CX85 numeric keypad handler for joystick port 2. Shift-Control-3 (#) to toggle on/off. Atari BASIC version now displayed on self test screen. Self test now displays which bit(s) failed the memory test. Video type displayed on self test screen. Patched with Fast Math F+ floating point package. Moved Self-test, Part 3, into self-test bank. ROM Checksum now only checked during self test. Move power-up validation byte PUPBT1 to $026A Reduced SIO command retries (CRETRY/CRETRI) to 4 to reduce boot time Removed LNBUG compiler directives. Removed RANSYS compiler directives. Removed ACMI compiler directives. Patched with Highspeed SIO patch V 1.33 (2023 version). SHIFT-CONTROL-S Clears SIO speed table/enables highspeed SIO SHIFT-CONTROL-N Disables highspeed SIO SHIFT-CONTROL-H Enables highspeed SIO Locations of SIO and KIR are now fixed so as to work properly with Highspeed SIO patch. Clear self test screen RAM prior to use. Boot with SELECT key down to disable Highspeed SIO. The two changes from OS 6.1 Alpha are: Clear self test screen RAM prior to use. Boot with SELECT key down to disable Highspeed SIO. I decided to add the ability to boot and disable the HIghspeed SIO so as to ensure compatibility with software that will not run off of floppy disks with HIghspeed SIO. (Flight Simulator II is one of these programs.) Atari_OS_61_source.zip OS61_ROM.zip This has been tested on real hardware. 🙂 Edited August 7, 2023 by reifsnyderb 8 2 Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted August 7, 2023 Share Posted August 7, 2023 Thanks! I am looking forward to burn this OS into a couple of EPROMS for two of my computers. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 7, 2023 Share Posted August 7, 2023 (edited) select key being held down conflicts w/ MIO setup... chicken or the egg, who gets there first? shift control h could just be a toggle for high speed on / off bypass on boot could just be holding shift or control during boot maybe, if not used by sdx or something else. Edited August 7, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 7, 2023 Author Share Posted August 7, 2023 (edited) 3 minutes ago, _The Doctor__ said: select key being held down conflicts w/ MIO setup... chicken or the egg, who gets there first? I was afraid there would be a conflict with something. But if the MIO detects the select key is held down, and enters setup, will it be a problem to enter the setup with the high speed SIO disabled? Normal, low speed SIO will work. Edited August 7, 2023 by reifsnyderb Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 7, 2023 Share Posted August 7, 2023 (edited) You will be in MIO setup every time you want to boot without hsio.. select at reset or power on takes you into MIO setup. option is typically for cartridge control start for cassette and so on I though I did a run down of all the keys in use previously for all devices and carts etc. Edited August 7, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 7, 2023 Author Share Posted August 7, 2023 (edited) 1 minute ago, _The Doctor__ said: You will be in MIO setup every time you want to boot without hsio Good point. I didn't think that answer through very well, did I? 😞 Are there many MIOs in the wild? Edited August 7, 2023 by reifsnyderb Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 7, 2023 Share Posted August 7, 2023 (edited) a crap ton, it was a major legacy device and had a remake issued not that many years ago as well ... Ken Jones MIO/ICD MIO remade it's got representation in altirra as well so you can have an idea what it's up to. MIO and Black Box were THE pbi devices to have bitd Edited August 7, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 7, 2023 Author Share Posted August 7, 2023 8 minutes ago, _The Doctor__ said: You will be in MIO setup every time you want to boot without hsio.. select at reset or power on takes you into MIO setup. option is typically for cartridge control start for cassette and so on I though I did a run down of all the keys in use previously for all devices and carts etc. Do you have a list available? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 7, 2023 Share Posted August 7, 2023 (edited) might even probably be in one of your threads? with others chiming in. I wouldn't know where the last list made would be anymore but it's been done a few times as different devices and os's have come along, like MyBIOS etc. some creative ways were made to allow more than on thing to use a key based on time held as well quick did one held did another. and of course the multiple keys held like your doing for some. MIO reacts to select not matter what I think, I can double check... And I remembered correctly it responds to select no matter the combination Edited August 7, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 7, 2023 Author Share Posted August 7, 2023 6 minutes ago, _The Doctor__ said: might even probably be in one of your threads? with others chiming in. I wouldn't know where the last list made would be anymore but it's been done a few times as different devices and os's have come along, like MyBIOS etc. some creative ways were made to allow more than on thing to use a key based on time held as well quick did one held did another. and of course the multiple keys held like your doing for some. MIO reacts to select not matter what I think, I can double check... I am not sure what keys are left. Option -- BASIC Select -- MIO & Disable High Speed SIO on OS 6.1 Start -- Cassette boot Shift -- XEP-80 to boot in 40 column mode. There really needs to be some sort of system like a BIOS config..... 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 7, 2023 Share Posted August 7, 2023 Option is defacto cart control, not only for BASIC but stacked Carts like EXPRESS! will pull up a menu so you can configure your cart choices, so you can choose NO cart, BASIC, Express!, or stacked cart above Express! or other stackables. Quote Link to comment Share on other sites More sharing options...
Mathy Posted August 7, 2023 Share Posted August 7, 2023 Hello Brian If the OS can detect the presence of the MIO, you could for instance display a short message asking the user what (s)he wants, "no high speed" or "MIO set up". Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 8, 2023 Author Share Posted August 8, 2023 (edited) 3 hours ago, Mathy said: Hello Brian If the OS can detect the presence of the MIO, you could for instance display a short message asking the user what (s)he wants, "no high speed" or "MIO set up". Sincerely Mathy I don't have enough space to add too much more. Right now, there is roughly 400 bytes left. I am thinking it can be used for that Atari wozmon port, once the source code is available. It's either that or a printer spooler. I think that in 1985 an OS-based printer spooler would have been awesome on the XL's. Edited August 8, 2023 by reifsnyderb Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted August 8, 2023 Share Posted August 8, 2023 (edited) 7 hours ago, reifsnyderb said: I am not sure what keys are left. Option -- BASIC Select -- MIO & Disable High Speed SIO on OS 6.1 Start -- Cassette boot Shift -- XEP-80 to boot in 40 column mode. There really needs to be some sort of system like a BIOS config..... The Help key is also used to call up config screen for U1MB Is there no way to detect when two of option keys are pressed at the same time during startup? Or any other keyboard keys like control? Edited August 8, 2023 by scorpio_ny Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 8, 2023 Author Share Posted August 8, 2023 11 minutes ago, scorpio_ny said: The Help key is also used to call up config screen for U1MB Is there no way to detect when two of option keys are pressed at the same time during startup? Or any other keyboard keys like control? In the OS, it's possible to see if more than one key is pressed at once. However, the big question would be how is everything else handling the key presses. i.e. If MIO is checking to see if Select is pressed, how is MIO checking the other keys? Ideally, another key should be checked.... Quote Link to comment Share on other sites More sharing options...
kenames99 Posted August 8, 2023 Share Posted August 8, 2023 1 hour ago, scorpio_ny said: The Help key is also used to call up config screen for U1MB Is there no way to detect when two of option keys are pressed at the same time during startup? Or any other keyboard keys like control? the Help key is also used by the Supra/KP HD Interface to use disk 2 as disk 1 if held down at boot time. Ken Quote Link to comment Share on other sites More sharing options...
kenames99 Posted August 8, 2023 Share Posted August 8, 2023 54 minutes ago, reifsnyderb said: In the OS, it's possible to see if more than one key is pressed at once. However, the big question would be how is everything else handling the key presses. i.e. If MIO is checking to see if Select is pressed, how is MIO checking the other keys? Ideally, another key should be checked.... MIO just tests the console keys, no others. Ken Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted August 8, 2023 Share Posted August 8, 2023 Use Control or space bar or atari/inverse video for high speed? Or follow your own pattern, with N Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 8, 2023 Author Share Posted August 8, 2023 4 hours ago, kheller2 said: Use Control or space bar or atari/inverse video for high speed? Or follow your own pattern, with N That's an option. I'll have to do something to ensure that if the N key is held down, at boot, that the character buffer isn't loaded with the "N" later on. Quote Link to comment Share on other sites More sharing options...
351cougar Posted August 8, 2023 Share Posted August 8, 2023 would it be possible, like on a PC , that there is a brief period of system only KB functions, F12 F8 etc then a pause then everyone can see the KB entries. Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 8, 2023 Author Share Posted August 8, 2023 1 hour ago, 351cougar said: would it be possible, like on a PC , that there is a brief period of system only KB functions, F12 F8 etc then a pause then everyone can see the KB entries. That might be possible. I'll look into it. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 9, 2023 Share Posted August 9, 2023 (edited) On 8/8/2023 at 4:35 AM, scorpio_ny said: The Help key is also used to call up config screen for U1MB There's an option in the setup menu to use START instead for that function. The other U1MB hotkeys (used in conjunction with RESET, and all activated or deactivated via the setup menu) are: SHIFT (re-read HDD partition table) SELECT (coldstart the OS) There are some addiitonal hotkeys commonly used at cold power-up or while the boot logo is displayed: 1-4 (switch to config profile 1-4, in the forthcoming update) X (suppress SpartaDOS X) D (bring up boot drive menu) Edited August 9, 2023 by flashjazzcat 3 Quote Link to comment Share on other sites More sharing options...
deffroe Posted August 19, 2023 Share Posted August 19, 2023 On 8/7/2023 at 8:09 PM, reifsnyderb said: This has been tested on real hardware. 🙂 I got round to odering a eeprom programmer and 16K roms so I could try out your new Atari ROM. I'll add more finding, if any, when I have a bit more time, but for now I found a minor (non)issue. This is using a 130XE with 41256's in the second bank(2 banks of 8 chips), but still running as 128KB. RAM test skips some blocks once it reaches the second row, photos included, pic OS61a shows the last block before it jumps to OS61b. One more thing I noticed was the READY prompt was right up against the left hand border, not indented. I'm really liking how everything is one screen. Thanks for your time an effort in doing this. Phil 2 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 19, 2023 Author Share Posted August 19, 2023 1 hour ago, deffroe said: I got round to odering a eeprom programmer and 16K roms so I could try out your new Atari ROM. I'll add more finding, if any, when I have a bit more time, but for now I found a minor (non)issue. This is using a 130XE with 41256's in the second bank(2 banks of 8 chips), but still running as 128KB. RAM test skips some blocks once it reaches the second row, photos included, pic OS61a shows the last block before it jumps to OS61b. One more thing I noticed was the READY prompt was right up against the left hand border, not indented. I'm really liking how everything is one screen. Thanks for your time an effort in doing this. Phil Hello! It's good to hear you like the OS! The Ready prompt being to the far left is by design as you will have a little more space on the screen. Some people requested this as they told me they usually move the prompt to the far left as one of the first things they do. The RAM Self Test speed-up is due to the fast section not being RAM at the time of the test. Instead that's the location that is banked in by the self test. Atari hid this by inserting delays so it wasn't apparent. They also put delays in the ROM test, as well, even though the ROM test is just a quick checksum test. Thanks! Brian 4 Quote Link to comment Share on other sites More sharing options...
w1k Posted November 14, 2023 Share Posted November 14, 2023 testing on real HW 4 Quote Link to comment Share on other sites More sharing options...
