Shift838 Posted February 24, 2023 Share Posted February 24, 2023 My 800XL has U1MB, UAG Svideo, USB Keyboard installed. I have found one term program that works with Fujinet on my 800XL and that is BobTerm. Are there others? I have tried Ice-T, but I get a couple of error messages when trying to launch it: *Base 48K not free! * R: device not found! I know my Fujinet config is set to Virtual Modem = Yes. Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 24, 2023 Share Posted February 24, 2023 If you are using spartados x type x before the file you are loading. I.e “x iced.com” Bobterm had an r: handler built in I don’t know if all versions of iced t have them built in. You would need to load one. Rs232.com from Sparta dos usually works Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted February 24, 2023 Share Posted February 24, 2023 You need a R-device driver. "BOBVERTER" for example. You may guess it already... Its programmed by the same genius. Bobterm is already configured to load the driver first. Stefan Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted February 24, 2023 Share Posted February 24, 2023 Uh... much too slow. Sorry ! Stefan Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 25, 2023 Author Share Posted February 25, 2023 Loading the RS232.com driver works and starting the program with X in front. I have 2.80 Ice-T and 2.76. Neither of them will do color ANSI. the only selection I see in the settings is IBM graphics or standard text. How do I get it to do the ANSI as I have seen in other post of images of it working? Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 25, 2023 Share Posted February 25, 2023 I remember having the same problem however I don’t remember what version I used to get the color ansi. Next time I head down to my man cave I will check if nobody else has an answer. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 25, 2023 Share Posted February 25, 2023 I think it's a beta version that has it - 2.80 beta 7. The ANSI option will be under the "special" section. icet2807.xex 2 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 26, 2023 Author Share Posted February 26, 2023 3 hours ago, Stephen said: I think it's a beta version that has it - 2.80 beta 7. The ANSI option will be under the "special" section. icet2807.xex 34.96 kB · 4 downloads I load this up via my SIDE3 after I have loaded the RS232.com from SpartaDOS and after it loads within a few seconds the screen starts going wonky just display garbage and almost looks like a vertical scroll constantly like the old tube TVs. if I load up an older version off ATR from SpartaDOS the screen is fine. anyone have this beta version that supports ANSI in ATR format that I can run from SpartaDOS? Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 26, 2023 Author Share Posted February 26, 2023 I got it working. I'm learning as I go since I'm so new to Atari. i loaded the RS232.com, then just executed X ICET280A7.XEX and bam.. worked.. 4 Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 26, 2023 Share Posted February 26, 2023 Welcome to the party! Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 27, 2023 Author Share Posted February 27, 2023 i'm wondering if the ANSI Graphics will look better (they look off with the SVIDEO) when I install my VBXL mod. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 27, 2023 Share Posted February 27, 2023 30 minutes ago, Shift838 said: i'm wondering if the ANSI Graphics will look better (they look off with the SVIDEO) when I install my VBXL mod. No - the VBXE / VBXL modes do not work well with Ice-T. I need to do some investigating to see why, but the PMG overlay/underlay that is used to create the colouring is definitely broken on the VBXE hardware. Keep in mind - with stock A8, there can never be proper ANSI emulation. There is no way to have hi-res text and color info for each character. We're lucky to get this approximation via Ice-T. With VBXE, an almost true ANSI is possible. Only caveat being, 16 text colours, but only 8 background colours. We at least get a proper 256 character font. Here's my latest demo code showing the original CGA font and colours: Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 27, 2023 Share Posted February 27, 2023 I have sophia2 in two of my machines and if I remember correctly, the ansi for ice-t looked pretty good. Obviously not perfect but passable and not long after that I got a wimodem for my st so that is where I do most of my ansi bbsing. Quote Link to comment Share on other sites More sharing options...
