Spector Posted October 2, 2003 Share Posted October 2, 2003 i notice in the Atariage store when talking about Thrust +, it says "Supports both NTSC and PAL television formats." Do you mean that the one cart can work on both formats? Or does it mean that they are seperate cartridges? Quote Link to comment Share on other sites More sharing options...
Albert Posted October 2, 2003 Share Posted October 2, 2003 The same cartridge works with both television formats. One of the difficulty switches allows you to select between PAL and NTSC. This is the case with several homebrew games. ..Al Quote Link to comment Share on other sites More sharing options...
Spector Posted October 2, 2003 Author Share Posted October 2, 2003 That's pretty smart thinking. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 2, 2003 Share Posted October 2, 2003 That's pretty smart thinking. Thanks! To avoid any confusion: The switch in Thrust only changes the colors, not the frame rate. But that should be no problem, since by far the most PAL TVs can sync to NTSC too. And that way the overall gameplay speed is identical in PAL and NTSC. Quote Link to comment Share on other sites More sharing options...
Spector Posted October 2, 2003 Author Share Posted October 2, 2003 That's pretty smart thinking. Thanks! To avoid any confusion: The switch in Thrust only changes the colors, not the frame rate. But that should be no problem, since by far the most PAL TVs can sync to NTSC too. And that way the overall gameplay speed is identical in PAL and NTSC. This is exactly the way it should be; as you say, most TV's do 60Hz now. That's brilliant, because the speed is kept the same too and the screen has no borders- everyones a winner I think you are the first to do it this way Thomas, so congrats! I hope that other homebrew developers take note of this relatively simple idea which massively improves the gaming experience for all PAL Atarians. Quote Link to comment Share on other sites More sharing options...
liveinabin Posted October 2, 2003 Share Posted October 2, 2003 It also makes it the first 60fps version of Thrust on any PAL system:) Quote Link to comment Share on other sites More sharing options...
