Tidus79001 Posted February 26, 2023 Share Posted February 26, 2023 Does anyone here repair Sega Genesis consoles? I have 2 consoles that I took out of storage and while with both of the power on they both only show a black screen. I have tried both the the Sega Genesis AV cable (RCA end) as well as 2 different RF adapters. Made sure the consoles were set to channel 3 and TV tuned to 3 when using the RF adapters and turned to the correct AV input when using the AV cable. Also tested multiple games and the TV that I am connecting to is a CRT. Not sure what this issue is as the both worked last time I used them. Could just be the capacitors. Sega Genesis Model 1 (original launch version with "High Definition Graphics" printed on the case) Sega Genesis Model 1.2 (looks like with launch version but doesn't have "High Definition Graphics" printed on the case) Quote Tidus79001 324 Replied: 35 minutes ago Quote Link to comment Share on other sites More sharing options...
+Starwander Posted February 26, 2023 Share Posted February 26, 2023 If you have one of those old Sega Genesis system cleaning kits trying that on the system to clean the cartridge port. If that doesn't work trying cleaning your games with a Q-tip and rubbing alcohol. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 26, 2023 Share Posted February 26, 2023 19 hours ago, Tidus79001 said: Does anyone here repair Sega Genesis consoles? I have 2 consoles that I took out of storage and while with both of the power on they both only show a black screen. I have tried both the the Sega Genesis AV cable (RCA end) as well as 2 different RF adapters. Made sure the consoles were set to channel 3 and TV tuned to 3 when using the RF adapters and turned to the correct AV input when using the AV cable. Also tested multiple games and the TV that I am connecting to is a CRT. Not sure what this issue is as the both worked last time I used them. Could just be the capacitors. Sega Genesis Model 1 (original launch version with "High Definition Graphics" printed on the case) Sega Genesis Model 1.2 (looks like with launch version but doesn't have "High Definition Graphics" printed on the case) Quote Tidus79001 324 Replied: 35 minutes ago I also replied to your PM to me on this. I suggest trying another power supply if you have one. While I understand both consoles power one, that doesn't mean the PSU is providing enough current and could be dropping in voltage enough to prevent the systems from turning on. The fact that you have two different Genesis systems doing the same thing leads me to think the PSU might be the issue. But as @Starwander also stated, the Genesis will not boot if the cartridges can't be read properly so a good cleaning of the games and cartridge port if possible, would be something else to check real quick. Quote Link to comment Share on other sites More sharing options...
zylon Posted February 27, 2023 Share Posted February 27, 2023 retensioning the cart port pins, can also help sometimes. I've seen it as more an issue with well-used model 1's, but even had a model 3 recently, needing that adjustment. In the case of the G3, it was black screen, but in tinkering with it, it would attempt to start, if the cart was leaned back a bit in port. 2 rounds of retensioning, and it now works fine. There's several videos on doing this, out there already. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted March 2, 2023 Share Posted March 2, 2023 You should at least open it up and make sure the solder joints are okay and that it's getting power. I once found a Gensis v2 where half of the external connector pins (power, controllers, etc.) had bad solder joints. Quote Link to comment Share on other sites More sharing options...
