Shift838 Posted February 28, 2023 Share Posted February 28, 2023 I have a VBXL that I am ready to install into my Atari 800XL. I know it ports it all RGB with a C/Hsync line. I have seen many installs using a mini-DIN 13 to SCART connector. I have currently designed a RGB KVM+Audio switch and I believe I can instead just use the Standard DIN 8 instead of a mini-DIN 13 to port the RGB, Sync and Audio so it could hook up to this KVM. Am I correct in assuming that? I know I will not be able to use the keyboard as my two Geneves use a USB keyboard interface specifically designed for them. But video and audio should be fine. thoughts? My current KVM: Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 1, 2023 Share Posted March 1, 2023 Should work I guess. Note that CSync is TTL level but the RGB components are low voltage (something like 0-1.2 V I think) Quote Link to comment Share on other sites More sharing options...
Shift838 Posted March 1, 2023 Author Share Posted March 1, 2023 maybe I should make a version of this KVM for use with the Atari ? Quote Link to comment Share on other sites More sharing options...
Mathy Posted March 1, 2023 Share Posted March 1, 2023 Hello Shift838 Another option might be SAVO XL. It uses the Sega Saturn connector and the hole where the RF-modulator usually sits. Sincerely Mathy PS the site in the URL was used because it seems to be the only one I could find. SAVO XL and SAVO XE are new. 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted March 5, 2023 Author Share Posted March 5, 2023 Update. I have completed the installation of the VBXL and it works with my KVM switch. I am not using the keyboard hooked up to my KVM as it is strictly for the Geneve, but it works for RGB video output via SCART and Audio. 2 Quote Link to comment Share on other sites More sharing options...
