+videofx Posted March 1, 2023 Share Posted March 1, 2023 After reading the manual for SIDE3 it shows how to create a blank .ATR. So my question is if I have a floppy with some program on it how do I make the .ATR? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted March 1, 2023 Share Posted March 1, 2023 Go into SIDE3 menu press L to go into the loader press CRTL M and a menu should appear move down with arrow keys and select new image or just press SHIFT-CTRL I for the same option then select the image you want then name it whatever you want to call it <name>.ATR that's it, you will have a new disk image on the SD card that you can mount into a drive slot Quote Link to comment Share on other sites More sharing options...
+videofx Posted March 1, 2023 Author Share Posted March 1, 2023 Thanks! Does it automatically read the floppy disk that is inserted in drive 1. I am trying to make ATRs from all my floppys Thanks Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 1, 2023 Share Posted March 1, 2023 (edited) 42 minutes ago, videofx said: Does it automatically read the floppy disk that is inserted in drive 1. Currently not, but if you mount the ATR you just created on one drive and have the floppy on a different drive ID, you can boot the DOS of your choice and do a raw copy between the floppy and the ATR. Or you can run your preferred sector copier direct from the loader, to which it will return when it's done. Edited March 1, 2023 by flashjazzcat 1 Quote Link to comment Share on other sites More sharing options...
+videofx Posted March 1, 2023 Author Share Posted March 1, 2023 Thanks Jon! I assume it will also work in reverse? If I want to make a floppy from the ATR mount the ATR then do a RAW copy to the floppy? Thats the answer I was looking for Cheers! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 1, 2023 Share Posted March 1, 2023 1 minute ago, videofx said: I assume it will also work in reverse? If I want to make a floppy from the ATR mount the ATR then do a RAW copy to the floppy? Yes, it will work the other way around as well. The FAT-hosted ATRs report PERCOM data corresponding to their geometry, so any disk copier should believe it's dealing with two physical floppies. 2 Quote Link to comment Share on other sites More sharing options...
