andy_bernstein Posted October 2, 2003 Share Posted October 2, 2003 Hello, I got a 130XE and a XEGS from Ebay but they definitely come from a heavy smoker. Because the XE line is grey / beige, they're not as forgiving with smoke as the XL line. Has anyone of you ever cleaned up a "yellowed" XE system and got good results ? And, if yes, what product did you use ? AB. Quote Link to comment Share on other sites More sharing options...
Bryan Posted October 2, 2003 Share Posted October 2, 2003 Usually that's not from smoke, but UV exposure. I don't know of a way to remove it. -Bry Quote Link to comment Share on other sites More sharing options...
andy_bernstein Posted October 2, 2003 Author Share Posted October 2, 2003 Bry, Thanks for the reply but it's definitely smoke: it 'smells' so bad, I have to leave the 130XE in its box when I'm not using it. AB. Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted October 2, 2003 Share Posted October 2, 2003 I'd take the casing off, take the keys out, and give them all a good cleaning. I bought a "yellowed" 130XE myself a few days ago, and found that Vim will remove some of the grunge (but not the discoloration). Quote Link to comment Share on other sites More sharing options...
Callipygous Posted October 3, 2003 Share Posted October 3, 2003 Just a crazy thought, but baking soda is often used to absorb odors. Maybe a box of Baking soda inside the computer box will work. Or putting the bare case in a tray of the stuff? Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted October 14, 2003 Share Posted October 14, 2003 A better way to get rid of that horrible cigarette smell is to clean the outside of the system with rubbing alcohol. I tried it with my 7800, and it no longer reeks of cigarettes (except near the air vents). Quote Link to comment Share on other sites More sharing options...
classics Posted October 14, 2003 Share Posted October 14, 2003 Strangely enough, you can get rid of some sunburn on Atari cases. You have to use a chemical to remove the outer layer of the plastic. Just under the surface it will be a much lighter color, though not perfect unless you remove quite a bit. A rag with a xylene mixture like Goof-Off will disolve the plastic with some rubbing. Wear breathing gear and gloves though, its very nasty stuff. Quote Link to comment Share on other sites More sharing options...
Mindfield Posted October 14, 2003 Share Posted October 14, 2003 If you know someone in the printing biz, ask him to give you a little rubber rejuvinator. It's pretty well pure toluene, and that stuff will definitely strip plastic. I've seen it eat styrofoam cups in under a minute. However, it's an order of magnitude nastier than anything with xylene in it, so breathing gear and lots of ventilation are a definite must. Quote Link to comment Share on other sites More sharing options...
Gregory DG Posted October 14, 2003 Share Posted October 14, 2003 The XEGS is probably the EASIEST Atari to open and clean. Here are my suggestions for cleaning your system. http://www.ataritimes.com/features/fea_cle...nyouratari.html Quote Link to comment Share on other sites More sharing options...
JB Posted October 21, 2003 Share Posted October 21, 2003 Doubt it'd cut the smoker grime, but I cleaned my yellowed SNES with just rubbing alcohol and a cloth(with q-tips for the hard-to-reach places). Quote Link to comment Share on other sites More sharing options...
Mindfield Posted October 21, 2003 Share Posted October 21, 2003 I haven't got the patience to wait for alcohol to work when I get something that's particularily grimy, so I'll reach for something with a little more chutzpah like lighter fluid or a little bit of solvent. Case yellowing from tobacco is fairly easy to remove with stuff like that, but oxydation takes even more muscle. Quote Link to comment Share on other sites More sharing options...
JB Posted October 21, 2003 Share Posted October 21, 2003 I haven't got the patience to wait for alcohol to work when I get something that's particularily grimy, so I'll reach for something with a little more chutzpah like lighter fluid or a little bit of solvent. Case yellowing from tobacco is fairly easy to remove with stuff like that, but oxydation takes even more muscle.Mine was only lightly yellowed, and I already had the rubbing alcohol out from a cart cleaning session. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted October 22, 2003 Share Posted October 22, 2003 Hello, I got a 130XE and a XEGS from Ebay but they definitely come from a heavy smoker. Because the XE line is grey / beige, they're not as forgiving with smoke as the XL line. Has anyone of you ever cleaned up a "yellowed" XE system and got good results ? And, if yes, what product did you use ? AB. There nothing to remove, the plastic has actually changed colors, the only way to fix the problem is to order a replacement case from B&C or Best. I see this mostly in Sun exposure or a desk lamp near the equipment, yes I have seen equipment with nicotine/tar residue build up but the real culprit is usually strong light exposure over long periods of time. However another issue is also heat it seems... I ran a BBS (Bulletin Board System) pre-Internet days.... for several years and I had 4 810's stacked 2 by 2 for many months until I managed to score a Corvus 10mb HD system.... when I moved the equipment around I found the backs of the 810's (never exposed to ANY light as they were in a desk hutch right out of the boxes) had all yellowed on the top backs, so I believe this was due to 24/7 heat from the boards inside and poor ventilation. So heat can be a factor as well... Bottom line is there is little cosmetically you can do once the yellowing/discoloring occurs except replace the plastic(s) or consider spraying on a coat of primer and repainting the cases. Curt Quote Link to comment Share on other sites More sharing options...
