trying to figure what dos version to use with compute! disks
bradhig1
You are confusing ProDOS and DOS.  There is no ProDOS 3.3, but there is a DOS 3.3.  My guess is you are booting using a DOS 3.3 boot disk, and then trying to catalog a ProDOS formatted disk.  A disk can be formatted with a ProDOS filesystem, but not be bootable.
Looking at this disk image in CiderPress, that is the case.  The Compute! disk is formatted for ProDOS file system, but it has no ProDOS installed on the filesystem.  It is simply just a data disk in ProDOS format.  Since there is no "PRODOS" on the disk, it cannot boot.  You need to boot first with a disk that has a file called "PRODOS", and then some other "system" file.  The simplest would be a disk with "PRODOS" and "BASIC.SYSTEM" on it.  It will boot straight to BASIC the way you are probably used to a DOS 3.3 disk doing.
You can go to https://prodos8.com/ and download a ProDOS version 2.4.2 disk.  It will boot to a menu, select BASIC.SYSTEM and hit enter.  It will drop you to BASIC.  Then you can swap in and read this Compute! disk.  Note that in ProDOS, CAT is usually preferred over CATALOG when in 40 col mode.
Edited by nick3092
