sl0re Posted April 14, 2023 Share Posted April 14, 2023 Hi everyone. I've been having more files glitch and crash than I would expect loading from xex files. Thought I'd ask what others see / know to see if its a problem. I have a 800 with fujinet. I just upgraded / totally replaced the memory and the problem happens with both old and new ram. As a example; Time Pilot from homesoft and atarimania crash loading from my fujinet. Does this image work for anyone else? Any other 800 users? Anyone else loading via fujinet? Thanks. It's just one test example; enough are failing it is worth it to figure out the problem. Thanks Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 14, 2023 Share Posted April 14, 2023 only suggestions, turn down pokey divisor turn off R: driver etc. but how do I net without R: or N:? you first copy the disk or file to a local SD card and mount that.. but my MidiMaze doesn't work or disconnect... tell them about it, here, on discord, and github etc. but my drives disappear/timeout or things randomly stop working the more I use the drive slot etc... tell them about it, here, on discord, and github etc. try rolling back to earlier firmware, or earlier bt supporting firmware. see if you can find the older flasher if necessary. all of the above appear to be normal for the device. Might be best to use it as a netmodem, and limited network backup storage drive until it gets reliable Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted April 14, 2023 Share Posted April 14, 2023 How much RAM do you have? I'd suggest making sure that games you're trying to load work with your Atari if loaded from a different device. It's possible that the XEX loader provided by FN requires memory area, which is not available in your config or there's a conflict with an older ROM version. In such a case it would be good to make an ATR image with a loader that deffinitely works on your system and load a game from this image rather than with a default XEX loader. I have an 800 and FijiNet works fine but this machine was expanded with an Incognito so it's not stock. Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted April 14, 2023 Share Posted April 14, 2023 I just tried with an emulator, Time Pilot does not run on an 800 with 48k. 1 Quote Link to comment Share on other sites More sharing options...
bandit Posted April 14, 2023 Share Posted April 14, 2023 I have an 800 and Time Pilot runs fine with Fujinet < However I have Incognito also. 1 1 Quote Link to comment Share on other sites More sharing options...
sl0re Posted April 14, 2023 Author Share Posted April 14, 2023 5 hours ago, Dinadan67 said: I just tried with an emulator, Time Pilot does not run on an 800 with 48k. Perfect; thank you. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted April 14, 2023 Share Posted April 14, 2023 21 minutes ago, bandit said: I have an 800 and Time Pilot runs fine with Fujinet < However I have Incognito also. I guess it would do if the Incognito settings in bios are 1088kb and Atari XL/XE O/S. You could set the Incognito bios to stock Colleen 800 settings temporaily and see what happens with Timepilot then. Quote Link to comment Share on other sites More sharing options...
bandit Posted April 14, 2023 Share Posted April 14, 2023 16 minutes ago, Beeblebrox said: I guess it would do if the Incognito settings in bios are 1088kb and Atari XL/XE O/S. You could set the Incognito bios to stock Colleen 800 settings temporaily and see what happens with Timepilot then. I had almost forgot Incognito, that was a last second post. Anyway Collen mode does not run game. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 15, 2023 Share Posted April 15, 2023 will it run on 800 at 52k? many titles do. Quote Link to comment Share on other sites More sharing options...
sl0re Posted April 15, 2023 Author Share Posted April 15, 2023 14 hours ago, _The Doctor__ said: will it run on 800 at 52k? many titles do. How do I get up to 52k? Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted April 15, 2023 Share Posted April 15, 2023 15 hours ago, _The Doctor__ said: will it run on 800 at 52k? many titles do. I tested it with my 800 that has 52KB base memory + 496KB Axlon memory. Unfortunately Time Pilot does not run. 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted April 15, 2023 Share Posted April 15, 2023 (edited) 50 minutes ago, sl0re said: How do I get up to 52k? There are diy mod instructions over the years as well as modern plugin boards you can buy, although the latter will tend to be higher than 52k upgrades. In the States @reifsnyderb has desiged and sells some 800 ram boards like this 1056k one: https://www.tindie.com/products/5cfab/1056k-memory-upgrade-board-for-the-atari-800/ Edited April 15, 2023 by Beeblebrox 1 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted April 15, 2023 Share Posted April 15, 2023 44 minutes ago, Dinadan67 said: I tested it with my 800 that has 52KB base memory + 496KB Axlon memory. Unfortunately Time Pilot does not run. 52k of base memory will conflict with Axlon memory as the Axlon registers are within the high part of the 52k of RAM. Specifically, to have 52k of base memory, the 800 will use the memory from $C000-$CFFF. Axlon uses, at minimum, $CFFF as it's register. In many implementations of Axon banking, $CFFF is mirrored with at least 16 of the addresses before it. This results in a situation whereby if a program tries to uses memory within the Axlon range the memory banks will change and the system will crash. The only way for a program to use any of the 52k of base memory, with an Axlon compatible memory installed, is for the program to have been written to not attempt to use the addresses within the Axlon banking region. 1 1 Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted April 15, 2023 Share Posted April 15, 2023 Interesting, i did not know that. I repeated the test with 52k enabled and Axlon Ram disabled, but Time Pilot does not run. Quote Link to comment Share on other sites More sharing options...
sl0re Posted April 15, 2023 Author Share Posted April 15, 2023 I have that ram board 1 Quote Link to comment Share on other sites More sharing options...
