Matej Posted April 24, 2023 Share Posted April 24, 2023 (edited) Bulgarian Olimex manufacturer of ARM singleboard computers similar to RaspberryPi also AgonLight2 Z80 hobby computer is developing 30Euro 6502 computer called NEO6502. He want use RP2040 for graphics, sound and i/o key/mouse and disk. Here is blog:https://olimex.wordpress.com/2023/04/21/neo6502-open-source-hardware-modern-retro-computer-project/ Here is how AgonLight2(z80) looks like: Website:https://www.olimex.com Some very early specs: - real 6502 processor. - 264kb RAM on RP2040. - W65C02 from WDC can be overclocked up to 16Mhz also slow mode 1-2mhz - DVI/HDMI so that you can connect it to your home TV or modern monitor. - support for a modern USB keyboard - PSG sound synthesizer like the popular C64 SID - the power supply should be via a USB-C - UEXT connector with modern interfaces like UART, I2C, SPI. - disk storage for code. - the 6502 bus should be available on a slot/connector(cartridge) so that additional hardware can be easily added on - 2MB of external SPI flash to hold the firmware (firmware/OS/BASIC) Maybe we can suggest/modding RP2040 firmware: - use pokey instead of SID (or external UEXT card) - 2x ATARI joystick To have 14mhz 30Euro hybrid ATARI/NEO6502 Or we can just port games from ATARI 800. Or connect it to cartridge port use as turbocard/320x240x256 or 640x480/16colors graphics card. Edited April 24, 2023 by Matej 8 Quote Link to comment Share on other sites More sharing options...
Matej Posted April 27, 2023 Author Share Posted April 27, 2023 There will be also Agon Light 65x! So 2 (6502) new computers in 2023. 1 Quote Link to comment Share on other sites More sharing options...
Eric Badger Posted May 7, 2023 Share Posted May 7, 2023 I made a 6502 computer. 6 Quote Link to comment Share on other sites More sharing options...
Matej Posted June 26, 2023 Author Share Posted June 26, 2023 (edited) https://olimex.files.wordpress.com/2023/06/neo6502-1.jpg So Olimex has made first prototype. The board size is only 80×55 mm but do not be fooled this is complete 6502 computer with: - wdc w65c02 14mhz!!! cpu - HDMI output - USB host for keyboard - Audio output on 3.5mm jack - Small speaker - UEXT connector with +3.3V, GND, I2C, SPI, UART6502 BUS 40 pin connector with all 6502 signals on it! - RP2040 with 2MB Flash to handle all software defined peripherals and RAM https://olimex.files.wordpress.com/2023/06/neo6502-3.jpg Here is blog:https://olimex.wordpress.com/2023/06/23/neo6502-the-credit-card-size-open-source-modern-retro-computer-with-w65c02-processor-prototypes-are-ready-for-test/ Facebook Group:https://www.facebook.com/groups/745798620676673 If You are 6502 or RP2040 coder You can help with development and get board sooner. I can imagine play some Atari game conversions on it. Or plug it into cartridge port and use it as turbocard / gpu... Edited June 26, 2023 by Matej 6 Quote Link to comment Share on other sites More sharing options...
