reifsnyderb Posted April 25, 2023 Share Posted April 25, 2023 (edited) Hello, Does SIDE3 cartridge use the XL PORTB RAM located in the OS ROM region? Thanks! Brian Edited April 25, 2023 by reifsnyderb Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 25, 2023 Share Posted April 25, 2023 I would say no, I have used all the PortB banked RAM with U1M and SIDE3 present with no issues. SDX in SIDE3 uses some of it's banked memory and may also use some conflicting memory space areas, hence having to use the 'X' command to run some applications. I'm sure others who know a bit more about the actual technical details will advise 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 25, 2023 Share Posted April 25, 2023 (edited) The loader uses neither the Shadow RAM nor extended RAM. SDX may use either or both depending on the configuration (see the SDX manual). Edited April 25, 2023 by flashjazzcat 1 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted April 25, 2023 Author Share Posted April 25, 2023 4 hours ago, TGB1718 said: I would say no, I have used all the PortB banked RAM with U1M and SIDE3 present with no issues. SDX in SIDE3 uses some of it's banked memory and may also use some conflicting memory space areas, hence having to use the 'X' command to run some applications. I'm sure others who know a bit more about the actual technical details will advise 3 hours ago, flashjazzcat said: The loader uses neither the Shadow RAM nor extended RAM. SDX may use either or both depending on the configuration (see the SDX manual). Excellent! Thanks! Quote Link to comment Share on other sites More sharing options...
