TGB1718 Posted April 28, 2023 Share Posted April 28, 2023 Long story, but PC trashed itself, clean build (still not really working great) but Luckily I keep all my Atari stuff on a separate SSD so everything is intact except for the Altirra configuration which is kept in the registry by default (lesson learned there) Anyway I have got Altirra going now with U1M/SIDE3/USD 1050 etc. but I have one issue when I boot it will not read the CONFIG.SYS file on my boot drive, I have an AUTOEXEC.BAT file on the boot drive and it processes that which is really odd. I've checked the settings on my 130XE/U1M/SIDE3 setup which uses the same setup/files and that's working normally I copied the CONFIG.SYS file to D1: and point U1M to that, I see that it accesses D1: during boot, but still no processing of CONFIG.SYS DEVICE SPARTA OSRAM DEVICE SIO DEVICE ATARIDOS DEVICE ULTIME DEVICE JIFFY DEVICE FATFS.SYS DEVICE PCLINK.SYS DEVICE DOSKEY SET PATH=CAR:;;D6:\BIN\;D6:\BAT\;D6:\XEX\;D9: SET MANPATH=D6:\MAN\ What am I missing (probably something very obvious) ? here's a few screen shots of the setup During boot as you can see CONFIG.SYS has not been acted upon, should see some devices being loaded Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 28, 2023 Share Posted April 28, 2023 1 hour ago, TGB1718 said: I copied the CONFIG.SYS file to D1: and point U1M to that You mean D9:? SDX's default drive is D9:, so the CONFIG.SYS setting is plainly working. Side-note: '.SYS' is the assumed extension for DEVICE entries if none is given. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 28, 2023 Author Share Posted April 28, 2023 2 hours ago, flashjazzcat said: You mean D9:? SDX's default drive is D9:, so the CONFIG.SYS setting is plainly working. Side-note: '.SYS' is the assumed extension for DEVICE entries if none is given. When it didn't seem to work, although I realise it must be accessing D9: as the AUTOEXEC.BAT worked, I copied the config.sys to D1: and changed the boot drive in U1M to D1: and config.sys to D1:, didn't copy autoexec.bat, so when it booted, just SDX messages nothing else. Still scratching my head on this one. This is the config.sys that I've been using for a couple of years, the only thing that's changed is having to reconfigure Altirra. Nothing in config.sys is being acted upon, no messages about FATFS/PCLINK etc. loading and my PATH is just CAR: Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 28, 2023 Share Posted April 28, 2023 2 minutes ago, TGB1718 said: Still scratching my head on this one. I'm getting a dim, distant memory from the past. Disable 'Fast Boot' in the Altirra settings. 2 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 28, 2023 Author Share Posted April 28, 2023 1 minute ago, flashjazzcat said: I'm getting a dim, distant memory from the past. Disable 'Fast Boot' in the Altirra settings. You are the MAN!!! 🥰😍🤩 the moment I read that the penny dropped from when I first started using Altirra 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 28, 2023 Share Posted April 28, 2023 3 hours ago, flashjazzcat said: I'm getting a dim, distant memory from the past. Disable 'Fast Boot' in the Altirra settings. Welcome to the club! Bulbs that burned more brightly, in cases have dimmed more quickly. Take action now to correct this, or it can become nigh impossible to reverse. You don't want to get pissed at yourself later, trust in that. Feed your brain and it's constituent path and parts. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 28, 2023 Share Posted April 28, 2023 (edited) 1 hour ago, _The Doctor__ said: Welcome to the club! Bulbs that burned more brightly, in cases have dimmed more quickly. Take action now to correct this, or it can become nigh impossible to reverse. You don't want to get pissed at yourself later, trust in that. Feed your brain and it's constituent path and parts. I assume that's an attempt at humour, since the rambling, stream-of-consciousness club is not one I have any desire to join. The fact I was able to solve the problem quickly by retrieving from memory an extremely obscure piece of information not discussed for some years suggests there's nothing wrong with my long-term memory even if - like most other middle-aged people - I once in a while get to the top of the stairs and wonder why I climbed them in the first place. Edited April 28, 2023 by flashjazzcat 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 28, 2023 Share Posted April 28, 2023 (edited) It was for the exercise! Subconsciously you knew you needed to get the blood flowing! When you realized you were at the top of the stairs and didn't remember why you climbed them, you already joined said club and you didn't know it! 🤣 Edited April 28, 2023 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 28, 2023 Author Share Posted April 28, 2023 and just to top that, I just got Eclipse/Wudsn IDE working, couldn't download, there seems to be an issue there but copied some file off an old backup . 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 28, 2023 Share Posted April 28, 2023 2 minutes ago, TGB1718 said: and just to top that, I just got Eclipse/Wudsn IDE working, couldn't download, there seems to be an issue there but copied some file off an old backup I've taken to keeping a backup on the server of both the Eclipse installation folder and the workspace folder(s); this way, after a fresh OS install, I can be up and running just by copying those folders back. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted April 28, 2023 Share Posted April 28, 2023 You guys have memories like blackholes... nothing escapes. 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted April 29, 2023 Share Posted April 29, 2023 16 hours ago, Ricky Spanish said: You guys have memories like blackholes... nothing escapes. but then nothing could be retreived .... its a write only, never read function. 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted April 29, 2023 Share Posted April 29, 2023 19 minutes ago, kheller2 said: but then nothing could be retreived .... its a write only, never read function. Black hole information paradox . Quote Link to comment Share on other sites More sharing options...
