emuxer0 Posted October 5, 2003 Share Posted October 5, 2003 Hi. I hope someone can help me. I typed-in this game I found in the Digital ANALOG project; it worked, however in the version of the game in which the Atari has to guess your number, I have an error I can't fix. I have attached a ZIP file with both the ATR disk image and the BAS file. The listing and descriptioin of this game are at this address http://www.cyberroach.com/analog/an04/comp3.htm comp3.zip Quote Link to comment Share on other sites More sharing options...
emkay Posted October 5, 2003 Share Posted October 5, 2003 Well in line 35 the program tries to put a command to the printer. But I don't know the reason for this. REM the line and the program is working.... without printing ?!? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 5, 2003 Share Posted October 5, 2003 Actually, line 95 does the same thing (twice). Sending out LPRINT statements when the documentation says that info should be going to the screen (re: "all possible choices"). But even when changing these to PRINT #6 statements (which at first seems to work), you are going to run into another nasty error at line 215 when variable G cannot be collected correctly. This must be related to line 40's INPUT statement...which tries to gather from channel #1 (which has no corresponding OPEN command). My guess is that they published a correction in the Bugs&Bytes column in a following issue. Changes: Change LPRINT commands to PRINT #6 commands in lines 35 and 95, and the INPUT #1 command in line 40 to INPUT #6. The program will still display the computer's guess incorrectly and crash when you press the firebutton...but we're getting closer on this one Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 5, 2003 Share Posted October 5, 2003 OK...I think I have the gist of this... corrections: 35 PRINT #6; CHR$(27); "E" 40 TRAP 100 : INPUT A$ : A=LEN(A$) : FOR I=1 TO A 95 TRAP 100 : PRINT #6; A$(77,114) : PRINT #6; A$(115) : GOTO 40 Getting close with this one I'm still unsure what the INPUT command is supposed to be doing (I'm thinking that it is supposed to be grabbing a value from the screen...but the fixes above won't do this. Must have been a missing line in the original program (that showed what line #1 was supposed to be assigned to) Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 5, 2003 Share Posted October 5, 2003 Hmm...I still can't figure out what the INPUT command is supposed to be doing, OR the PRINT statements on 95...but when I took those out, it seemed to work So in addition to the updated line #'s 35 and 40 above, just change line 95 to read : 95 TRAP 100 Is this working? Looks so. Quote Link to comment Share on other sites More sharing options...
emuxer0 Posted October 6, 2003 Author Share Posted October 6, 2003 It seems to be working correctly now. Thank you VERY much. I also found those lines that called the printer and was the first thing that I removed. I think the original listing must have some typos. I hope somebody with an ANALOG magazine collection can find those corrections to know what those LPRINT commands were for if they were not a mistake in the first place. Quote Link to comment Share on other sites More sharing options...
