Overange Posted May 5, 2023 Share Posted May 5, 2023 (edited) Friday rainy day project = Fit Ultimate 1MB into my 65XE Remake. Not being happy with the pillar style of mounting the U1MB and that I was only able to find a mounting bracket for the 800XL ( Jeff Thiele Design ), using this as a basis I designed one specifically for the XE models. Like the 800XL version, it only uses the one PCB mount screw to hold it in place, it also has a very small bump to locate it into the RF sheild PCB through hole and to hold it square. Being offset means you can still unscrew it from the main XE PCB with out having to unmount the U1MB from the Mount. I have uploaded the STL to Thingiverse for those wanting to print their own. https://www.thingiverse.com/thing:6009020 Enjoy Edited May 5, 2023 by Overange 6 1 Quote Link to comment Share on other sites More sharing options...
Ppyo Posted May 7, 2023 Share Posted May 7, 2023 Nicely done! 1 Quote Link to comment Share on other sites More sharing options...
V-Cool Posted May 9, 2023 Share Posted May 9, 2023 Nice. Is there a link for the 800XL version you mentioned? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted May 9, 2023 Share Posted May 9, 2023 3 hours ago, V-Cool said: Nice. Is there a link for the 800XL version you mentioned? Here is the 800XL version : https://www.thingiverse.com/thing:4572439 And while I am at it the 600XL one also: https://www.thingiverse.com/thing:3555432 1 Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted May 9, 2023 Share Posted May 9, 2023 Interresting. Though, U1MB is usually mounted rotated 90 degrees to the right, over the modulator (or a space where it usually is). Good job anyway. Quote Link to comment Share on other sites More sharing options...
Overange Posted May 9, 2023 Author Share Posted May 9, 2023 8 hours ago, Peri Noid said: Interresting. Though, U1MB is usually mounted rotated 90 degrees to the right, over the modulator (or a space where it usually is). Good job anyway. Thanks, I did take this into consideration and you can mount it however you wish. 4 Quote Link to comment Share on other sites More sharing options...
V-Cool Posted May 21, 2023 Share Posted May 21, 2023 Thanks to everyone for the info. I finally got my Ultimate 1MB installed without having to do any drilling or soldering thanks to the bracket above and this: https://www.tindie.com/products/devzine_pl/sally-adapter-for-atari-xlxe-and-ultimate-1mb-mod/ In addition to everyone who was kind enough to share info on here I also owe a big thanks to Pawel Mandes who made the sally adapter for his help when I made installation errors. 2 Quote Link to comment Share on other sites More sharing options...
