cx2k Posted May 22, 2023 Share Posted May 22, 2023 In the process of dumping a bunch of carts I've picked up over the years and found this one marked "1200 SALT" but it also has something handwritten above that which I can't make out. The strange part is that the cart contains roms, not eproms. I was unable to match the co part numbers to anything (maybe my google skills are sub-par). The cart doesn't boot on an 800 or 800XL but I don't have a real 1200 at the moment to test. It also doesn't work in Altirra. I even tried swapping the roms in case someone put them in the wrong spots but no luck. I dumped the cart twice, once normal and once with roms swapped. Also, didn't see any noticeable text with hex editor. Maybe one of the experts here can delve into this a little more and figure out what it is? Attached is cart pics and both rom dumps. Thanks, John Atari 1200 unknown 8k.bin Atari 1200 unknown 8k reversed roms.bin 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 22, 2023 Share Posted May 22, 2023 Does seem strange, for an 8K cart, the code looks like it's for a 16K cart, look at this snip of the disassembly even stranger, that first JSR goes to an empty block in the ROM 8030 JSR 9BE7 20 E7 9B 8033 JSR 8E24 20 24 8E <<< inside the $8000-$9FFF for an 8K cart 8036 LDY 98 A4 98 8038 LDA #00 A9 00 803A STA 0AEB,Y 99 EB 0A 803D JMP A4DD 4C DD A4 <<<jmp outside the 8K 8040 LDA #00 A9 00 8042 STA 88 85 88 8044 JMP A5B2 4C B2 A5 <<< and again and 8053 INC DD E6 DD 8055 BNE 8077 D0 20 8057 INC DE E6 DE 8059 JMP B077 4C 77 B0 <<< and again Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 22, 2023 Share Posted May 22, 2023 3 hours ago, cx2k said: Also, didn't see any noticeable text with hex editor. The texts "G A M E O V E R", "A T T A C K W A V E C O M P L E T E D", and "B O N U S X" appear in the roms. This should be recognized as from Defender by most people. 3 hours ago, cx2k said: Maybe one of the experts here can delve into this a little more and figure out what it is? Comparing with Atari's Defender cartridge, parts of the two 4K section match up. I didn't take the time to see if they were consecutive or what... but, obviously Defender is a 16K cart, so... Quote Link to comment Share on other sites More sharing options...
cx2k Posted May 22, 2023 Author Share Posted May 22, 2023 1 minute ago, MrFish said: The texts "G A M E O V E R", "A T T A C K W A V E C O M P L E T E D", and "B O N U S X" appear in the roms. This should be recognized from Defender by most people. Comparing with Atari's Defender cartridge, two of the 4K section match up. I didn't take the time to see if they were consecutive or what... but, obviously Defender is a 16K cart, so... Interesting. I tried dumping it as a 16k cart as well but it just showed half of it as empty. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 22, 2023 Share Posted May 22, 2023 8 minutes ago, MrFish said: The texts "G A M E O V E R", "A T T A C K W A V E C O M P L E T E D", and "B O N U S X" appear in the roms. This should be recognized from Defender by most people. Comparing with Atari's Defender cartridge, two of the 4K section match up. I didn't take the time to see if they were consecutive or what... but, obviously Defender is a 16K cart, so... Actually, I should say, two large portions within each 4K section match up. I only started from the discernible text areas forward. Further analysis required... Quote Link to comment Share on other sites More sharing options...
cx2k Posted May 22, 2023 Author Share Posted May 22, 2023 13 minutes ago, MrFish said: Actually, I should say, two large portions within each 4K section match up. I only started from the discernible text areas forward. Further analysis required... I still don't see the text but I'm using HxD for my editor. I took a regular Defender cart that was socketed and tried transplanting the chips into that but it still didn't work. I also tried mixing the chips to identify if one of them was bad and couldn't get it to boot. While I had it in the 16k cart I did a dump and see that it is a full 16k. No idea why it doesn't run though. Here's the 16K dump... 1200 Defender 16k.bin Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 22, 2023 Share Posted May 22, 2023 18 minutes ago, cx2k said: I still don't see the text but I'm using HxD for my editor. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted May 22, 2023 Share Posted May 22, 2023 (edited) also says DEFENDER 1982 ATARI here : 0029A0 0029B0 Edited May 22, 2023 by Ricky Spanish added info 1 Quote Link to comment Share on other sites More sharing options...
DrVenkman Posted May 22, 2023 Share Posted May 22, 2023 I went to go look inside my Defender cart just to verify the Atari part numbers on those ROMs but of course, as luck would have it, I can't find it. I suspect it might currently be parked under the hatch of one of my 400s or 800s in storage. But it should be easy enough for someone with the cart handy. Quote Link to comment Share on other sites More sharing options...
cx2k Posted May 22, 2023 Author Share Posted May 22, 2023 10 minutes ago, DrVenkman said: I went to go look inside my Defender cart just to verify the Atari part numbers on those ROMs but of course, as luck would have it, I can't find it. I suspect it might currently be parked under the hatch of one of my 400s or 800s in storage. But it should be easy enough for someone with the cart handy. I did verify the numbers. See above. I even swapped the roms with a known good Defender cart to see if it worked. Quote Link to comment Share on other sites More sharing options...
cx2k Posted May 22, 2023 Author Share Posted May 22, 2023 20 minutes ago, MrFish said: Do I have a wrong setting or something?? Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted May 22, 2023 Share Posted May 22, 2023 It's just a standard Defender. Your "1200 Defender 16k.bin" ROM dump, if we swap the first and second 8K blocks around, is exactly identical to the known Defender cartridge. Obviously the ROMs were swapped into incorrect sockets when you were making the dump. According to the numbering present in the Atari Engineering Information System - Item Master List, parts with the code C0173xx and C0603xx are ROM #1 and #2, respectively, from the cartridges with the matching serial number RX80xx. Defender's serial is RX8025, so we have a match for both of the ROM chips. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 22, 2023 Share Posted May 22, 2023 12 minutes ago, cx2k said: Do I have a wrong setting or something?? It's probably the encoding, the characters are the reverse field set i.e. bit 8 set, another way to see them is to drag and drop the file into ATR Explorer, it displays correctly there as it's written for Atari Files and .ATR's 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 22, 2023 Share Posted May 22, 2023 19 minutes ago, cx2k said: Do I have a wrong setting or something?? You need to use an Atari font. Quote Link to comment Share on other sites More sharing options...
cx2k Posted May 22, 2023 Author Share Posted May 22, 2023 21 minutes ago, Kr0tki said: It's just a standard Defender. Your "1200 Defender 16k.bin" ROM dump, if we swap the first and second 8K blocks around, is exactly identical to the known Defender cartridge. Obviously the ROMs were swapped into incorrect sockets when you were making the dump. According to the numbering present in the Atari Engineering Information System - Item Master List, parts with the code C0173xx and C0603xx are ROM #1 and #2, respectively, from the cartridges with the matching serial number RX80xx. Defender's serial is RX8025, so we have a match for both of the ROM chips. OK. This is getting really strange. Here's a picture of a working Defender cart that I opened. Notice the part numbers and each chip is actually stamped L (Left) & R (Right). Now, I reversed the other ROMS since you said the the roms were swapped and it works, but the roms weren't swapped. Here's a pic - Note that CO60325A is on the right side Does this mean the masked roms were programmed wrong? John Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted May 22, 2023 Share Posted May 22, 2023 (edited) I don't know. Notice that your production Defender chip numbers end with an A, maybe they are "revision A" chips, i.e. different? Maybe the difference is in the configuration of Chip Select lines? If I understand correctly, your working assumption is that the "salt" chips are mislabelled and C017325 contains the same data as C060325A, and C060325 is the same as C017325A, right? Easy to check. If you still want to investigate, please try this: insert only one of the four chips into either socket and leave the other socket empty, and then dump the cartridge as 16K. Then post the 4 dumps. Edited May 22, 2023 by Kr0tki 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 22, 2023 Share Posted May 22, 2023 1 hour ago, cx2k said: Do I have a wrong setting or something?? If you go into the Options dialogue and select the Format tab, you can select a font for HxD to use. You need to have some modern adaptation of the Atari font installed on your system first. There are a few here: AtariWiki - Atari Truetype Fonts 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 22, 2023 Share Posted May 22, 2023 (edited) Low and Hi are determined by the latter numbers L R2928 8249/H R2929 8250 , Left and Right the same L CN52539 8245 /R CN52540 8246 The chips are from different runs and may have been in different PCB's at one time. Combined Nomenclature (Cartridge Number) vs CO Number. Differing sizes come into play... 40K 64K 80K 128K and so on. Edited May 23, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
cx2k Posted May 23, 2023 Author Share Posted May 23, 2023 3 hours ago, MrFish said: If you go into the Options dialogue and select the Format tab, you can select a font for HxD to use. You need to have some modern adaptation of the Atari font installed on your system first. There are a few here: AtariWiki - Atari Truetype Fonts Got it! Thanks!! Quote Link to comment Share on other sites More sharing options...
cx2k Posted May 24, 2023 Author Share Posted May 24, 2023 On 5/22/2023 at 5:18 PM, Kr0tki said: I don't know. Notice that your production Defender chip numbers end with an A, maybe they are "revision A" chips, i.e. different? Maybe the difference is in the configuration of Chip Select lines? If I understand correctly, your working assumption is that the "salt" chips are mislabelled and C017325 contains the same data as C060325A, and C060325 is the same as C017325A, right? Easy to check. If you still want to investigate, please try this: insert only one of the four chips into either socket and leave the other socket empty, and then dump the cartridge as 16K. Then post the 4 dumps. So, I did as you mentioned and you can see that they are mislabeled/programmed wrong. CO17325 is same as CO60325A & CO60325 is same as CO17325A. Dumps below. CO17325.bin CO60325A.bin CO60325.bin CO17325A.bin 1 Quote Link to comment Share on other sites More sharing options...
