DrVenkman Posted May 30, 2023 Share Posted May 30, 2023 2 minutes ago, jindroush said: Now what do you mean by 'swapping'? Flipping the disk over/inserting Disk 2/whatever. For that matter, my own copy of Zork I from BITD, that I bought new in 1985 or so, is singe-sided, too, and runs on a stock 48K 800. 1 Quote Link to comment Share on other sites More sharing options...
jindroush Posted May 30, 2023 Share Posted May 30, 2023 1 minute ago, DrVenkman said: my own copy of Zork I from BITD, that I bought new in 1985 or so, is singe-sided Yep, when I take single sided 'rel 26' Zork ATR, it's 0x10-1F8F interpreter. Just after it is a story file: Z-code version: 3 Interpreter flags: Display score/moves Release number: 26 Size of resident memory: 48eb Start PC: 49d9 Dictionary address: 37f0 Object table address: 02ae Global variables address: 2228 Size of dynamic memory: 2e26 Game flags: None Serial number: 820803 Abbreviations address: 01ee File size: 128bc Checksum: 05c5 From this is obvious that 0x1F80 + 0x128Bc = 0x1483C -> dec 84 028 bytes, which fits on one SD side. I believe that any Z3 game can be modified to be ran from single sided ATR / other media, there's no magic in this, double sided just split story file between resident part, which is on first disk and high memory, which is loaded on-needed-basis from second disk. To cut this short - any Z3 file from any source could be used as 'single sided'. The maximum length of Z3 story is 128K. Quote Link to comment Share on other sites More sharing options...
drpeter Posted May 30, 2023 Share Posted May 30, 2023 3 hours ago, jindroush said: To cut this short - any Z3 file from any source could be used as 'single sided'. The maximum length of Z3 story is 128K. Indeed- I was just wondering if someone already had the build tools to hand. Quote Link to comment Share on other sites More sharing options...
jindroush Posted May 30, 2023 Share Posted May 30, 2023 27 minutes ago, drpeter said: I was just wondering if someone already had the build tools to hand. I have something (being fossil, just a batch file calling masm, windows build of Inform and a short Perl script), which builds me a final game ATR from sources. It's not production quality though, so if you have any game in mind, just drop me .z3 story file and I'll send you ATR. I did that for my own use when I tried to prove I can make Czech (we have all those goddamned accented characters, flexing and whatnot not found in English) Inform game. Which I, mildly-successfully, have proven. 1 Quote Link to comment Share on other sites More sharing options...
drpeter Posted May 30, 2023 Share Posted May 30, 2023 3 hours ago, jindroush said: if you have any game in mind, just drop me .z3 story file and I'll send you ATR. Thanks- I don't have one ready yet, but will send it when I do... Quote Link to comment Share on other sites More sharing options...
Shift838 Posted May 30, 2023 Author Share Posted May 30, 2023 8 hours ago, jindroush said: Yep, when I take single sided 'rel 26' Zork ATR, it's 0x10-1F8F interpreter. Just after it is a story file: Z-code version: 3 Interpreter flags: Display score/moves Release number: 26 Size of resident memory: 48eb Start PC: 49d9 Dictionary address: 37f0 Object table address: 02ae Global variables address: 2228 Size of dynamic memory: 2e26 Game flags: None Serial number: 820803 Abbreviations address: 01ee File size: 128bc Checksum: 05c5 From this is obvious that 0x1F80 + 0x128Bc = 0x1483C -> dec 84 028 bytes, which fits on one SD side. I believe that any Z3 game can be modified to be ran from single sided ATR / other media, there's no magic in this, double sided just split story file between resident part, which is on first disk and high memory, which is loaded on-needed-basis from second disk. To cut this short - any Z3 file from any source could be used as 'single sided'. The maximum length of Z3 story is 128K. do you have a script or program that takes the Z3 file and makes it into a bootable ATR? Quote Link to comment Share on other sites More sharing options...
jindroush Posted May 30, 2023 Share Posted May 30, 2023 Yep, very ugly Perl script currently making only SD ATRs. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted May 30, 2023 Author Share Posted May 30, 2023 11 minutes ago, jindroush said: Yep, very ugly Perl script currently making only SD ATRs. are you willing to share it with some instructions, i would like to see if my z3 file i have that is not booting will make a bootable ATR Quote Link to comment Share on other sites More sharing options...
jindroush Posted May 30, 2023 Share Posted May 30, 2023 (edited) 4 minutes ago, Shift838 said: are you willing to share it with some instructions, i would like to see if my z3 file i have that is not booting will make a bootable ATR As I wrote here: it works without basic - I used Z3 you shared on ifdb.org I'll check out tomorrow (midnight here) if it's possible to de-uglize it a bit Edited May 30, 2023 by jindroush Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 30, 2023 Share Posted May 30, 2023 9 hours ago, jindroush said: Yep. But there is a computation of cache size. Cached sector numbers are stored in $600-$67F (low) and $680-$6FF (high). $80 is maximum number, but this is computed as a number of pages between end of resident part and memtop page. And that could overflow for short stories, as there is no test. This is the exact problem why the Locked Room riddle does not work with 48 KB (by 2 pages). If you boot it with only 32 KB of RAM, it works and by inserting BASIC, the remaining RAM is only 40 KB. Since DOSINI is set to the correct start address, entering DOS will then run the game. I'll try to create a hack which modifies the cache allocation in a way that it never tries to allocate more than $80 buffers. Stay tuned. 1 Quote Link to comment Share on other sites More sharing options...
jindroush Posted May 30, 2023 Share Posted May 30, 2023 1 minute ago, DjayBee said: I'll try to create a hack which modifies the cache allocation in a way that it never tries to allocate more than $80 buffers. I've got this done already, as I have z3 interpreter in .asm. When I was trying if my czech localization works, it wouldn't - so I had to modify the interpreter a bit. LDA byte_BC CLC ADC zvar_game_file_hi STA zvar_b9 JSR get_max_free_mempage SEC SBC zvar_b9 BCC loc_915 .ifdef OVERFLOW_PROTECT ;if in this place, number of pages available in RAM is greater than $80 ;whole disk caching would go bonkers (as there are allocated only 4x$80 bytes for two word storage) ;this is computed as space between last sector of resident memory and MEMTOP CMP #$80 BEQ not_too_much BCC not_too_much LDA #$80 not_too_much: .endif 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 30, 2023 Share Posted May 30, 2023 Yes, this is what I also want to do but from my understanding of the code it must be set to #$7F because the original result (bcc not_too_much) is incremented by 1 to get the number of cache buffers. Furthermore I wanted to hack the OP's original interpreter. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 31, 2023 Share Posted May 31, 2023 This image should work on any RAM configuration starting from 16 KB: locked_atari8bit[f].atr To patch the interpreter itself permanently do the following replacements with a hex editor like HxD: Right at the beginning (in the ATR from offset $0028) original: A9 08 85 0B 18 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 patch: A9 08 85 0B A2 05 BD 29 07 9D 30 01 CA 10 F7 18 60 C8 84 BD 4C 9A 09 and a little farther in the program (ATR offset $0217) original: A8 C8 84 BD A8 84 BF A9 FF 91 C4 4C 9A 09 patch: 10 02 A9 7F A8 84 BF A9 FF 91 C4 4C 30 01 5 1 Quote Link to comment Share on other sites More sharing options...
jindroush Posted June 5, 2023 Share Posted June 5, 2023 Regarding the build process, Z3 games for 8bit Atari could be created with this toolchainhttps://github.com/ByteProject/Puddle-BuildTools It looks huge and complicated, but should be able to auto-create images needed, using original Infocom interpreters, including large games with double-disk targets. On the side note: I had a bit of time to check the releases I have, so now I have extracted 3 different single-sided interpreters and 6 double disk interpreters. Most of the double disk interpreters have built in version information, which you can get by running $verify command from game. Few games got more than one release from Infocom. I was able to find these: 1 version: Ballyhoo, Cutthroats, Sorcerer, Spellbreaker, Fooblitzky, Hollywood Hijinx, Infidel, Leather Goddesses, Moonmist, Planetfall, Plundered Hearts, Seastalker, Stationfall, Suspect, Lurking Horror, Witness (16 games) 2 versions: Enchanter, Starcross, Wishbringer (3 games) 3 versions: Deadline, Suspended, HHtG, Zork III (4 games) 4 versions: Zork II (1 game) 5 versions: Zork I (1 game) So totally 25 titles in 43 releases. All of these are Z3. The latest releases are Lurking Horror (870506) and Plundered Hearts (870730). Both use double disk interpreter G. 3 Quote Link to comment Share on other sites More sharing options...
