Ghostbusters - Development Diary
TheMole
On 12/2/2023 at 8:22 AM, TheMole said:
If anyone plays it on real hardware and doesn't mind recording their session, please let me know. Dying to know what it looks and sounds like on real hardware!
I can try to record it playing via MiSTer on with my CRT arcade monitor. It's not going to show the RF interference effects but should look pretty nice.
I had the opportunity to try it on real iron and the game start screen can be seen as in the photo. in the other photo my configuration on where the game runs. maybe it only does it on my iron.. For the rest, beautiful! I had fun playing it and I didn't get any errors. the gameplay is wonderful, the graphics are even more so. Well done, my compliments for the work done👍🏻
20231205_122742_copy_451x444.jpg.e2885a071e5e886808dd1758c6a57e2a.jpg20231205_124948_copy_800x600.thumb.jpg.a299e61bbe6b78ef32fa353d12ec0a6a.jpg
  • Like 4
Thanks for the kind words! That's a weird bug, that screen doesn't do anything that the other screens don't do... can you tell me a little bit about your hardware? Is it an unmodified console, or does it have an F18A (I'm guessing it's an F18A, because some of the color combinations I think I can see cannot be reproduced on a real 9918a)? Are you using a FinalGrom, or did you burn a cartridge? It looks like the screen mode hasn't been set correctly, but the text at the bottom indicates that at least some of the data in VRAM is correct.
There is perhaps one thing you can try for me, which is to hold the fire button while starting up the game (until you see the themole logo), that should bypass the F18A detection mechanism.
Has anyone else tried it on real hardware with or without an F18A?
My recording was from an unmodifed NTSC console, but I can try again tonight with F18A.
It works fine on my F18A console, and those sprites that flicker on 9918A look very nice. Unrelated to the type of VDP, I find it very difficult to enter a haunted building from the map. I often don't manage to do it until the ghost is gone. I try to move into the building from various directions while pressing fire. What am I supposed to do?
13 hours ago, TheMole said:
Grazie per le gentili parole! È un bug strano, quello schermo non fa nulla che gli altri schermi non facciano... puoi parlarmi un po' del tuo hardware? È una console non modificata o ha un F18A (immagino sia un F18A, perché alcune delle combinazioni di colori che penso di vedere non possono essere riprodotte su un vero 9918a)? Stai usando un FinalGrom o hai bruciato una cartuccia? Sembra che la modalità schermo non sia stata impostata correttamente, ma il testo in basso indica che almeno alcuni dati nella VRAM sono corretti.
Forse c'è una cosa che puoi provare per me, ovvero tenere premuto il pulsante di fuoco durante l'avvio del gioco (finché non vedi il logo della talpa), che dovrebbe bypassare il meccanismo di rilevamento F18A.
Qualcun altro l'ha provato su hardware reale con o senza F18A?
Forgive me, I forgot to point out that my ti99 is without F-18, you can't see it from the photo, I use a finalgrom to read .bin files. thanks for the advice, as soon as possible I will try the mechanism to avoid the control of a possible F-18 installed👍🏻 I thank you for the answer.
Lapo.
1 hour ago, JasonACT said:
PAL console?
Thought that as well, but I just tried it in Mame while emulating a PAL console (ti99_4ae), and it doesn't have this issue. Would be good if someone could try it on another PAL console though.
Edited by TheMole
Entering a building can be done by being on the street either below or above the building, holding the joystick up or down (pointing towards the building you want to drive to) and pressing fire. It doesn't work from the sides. Some versions of the game allow that as well, but I chose not to implement it because it feels "cleaner" to me. Supporting left/right would make it less obvious that the buildings on the sides of the screen can't be reached...
I'm open to changing this though, if it's a big issue.
So tried testing the latest release on the TI-99_4A core on my MiSTer.  Unfortunately, the ROM graphics are all scrambled, and the sound is messed up as well.
UPDATE>> I've gotten the larger carts to work on MiSTer.  In the MiSTer TI-99_4A core config menu I had to select "Cart Type:  Paged378", now the graphics load correctly (vs "Cart Type:  Normal").
TheMole title screen:
Main title screen:
Edited by retrodroid
I think there is a problem with the sprite flicker routine on the city map. On a 9918A console you either see the white outline or the green inside of the ghosts, but not both. On an F18A console the ghosts flicker between the outside and the inside, which is what I would have expected on the 9918A.
  • Confused 1
Finally had a chance to play the latest version for a bit on my TI-99/4A w/ 32K external and holy cow! The jaw dropping levels of detail that went into this is truly off the charts. All the "little" to major stuff and everything in between such as the stylish opening animation upon startup, graphics and color choices (of absolutely everything ...but esp. buildings, cars, ghosts, equipment, title screen, etc), full version of the hit song that elegantly fades before repeating, and the sampled speech which is extremely clear and integrates perfectly. Haven't followed the super quick progress as much as I would have liked, but it's obvious that such care, love and expertise was put into this game. Almost unbelievable what machine we're enjoying it on.  😎
So far, the game hasn't crashed on me. Only thing I noticed that's hardly worth mentioning, is how it can be a little tough to navigate streets (mostly horizontal?) while in map mode. By that I mean the cornering can be a little sticky and requires exacting precision before you find the entry. Only talking map mode of course, so no big deal if it is what it is. Edit - I see the cornering comment/trick SteveB mentioned and will give that a try next time I boot it up.
Will be spending more time with this in the coming weeks, but as of now - looks to be my favorite version of the game! Such a treat, and easily among the very best of the best TI games I've ever had the pleasure to play. Thank you @TheMole and everyone else that had a hand with feedback and in developing!!  😀
  • Like 4
Excellent, thanks for reporting back!
9 hours ago, Asmusr said:
The game froze for me two times today (real iron, F18A). Both times touching a ghost with a ray. The music also froze (continued to play the same note).
Dsc_0316.thumb.jpg.708f1418304fdce286cc8a320c8e87ca.jpg Dsc_0317.thumb.jpg.d2c0d72f904a62414f98330692851f99.jpg
Hmmm, the ghost-beam collission detection routine is not the sort of code that you would think could lead to a crash:
// If we're about to hit one of the beams, bounce the ghost off of the beam
// in the opposite direction
if (ghost.y > 16)	// Make sure spook is not higher than streams
	if (abs((ghost.x + ghost.hdir) - beam1_x) < (BEAM_BOUNCE + 1))
		if ((ghost.x + ghost.hdir) > beam1_x)
			ghost.x += BEAM_BOUNCE;
		else
			ghost.x -= BEAM_BOUNCE;
	else if (abs((ghost.x + ghost.hdir) - beam2_x) < (BEAM_BOUNCE + 1))
		if ((ghost.x + ghost.hdir) > beam2_x)
		else
	else
		ghost.x += ghost.hdir;
		ghost.y += ghost.vdir;
It's a hell of a coincidence though. I'm not sure what to think of this...
I'll be flying back to Europe around christmas, where I can test on real hardware myself. I have an F18A console and two NTSC consoles I can try on. I'll also try reproducing it in any emulator I can get my hands on here.
I'm not sure I understand 100% what you're describing, but the algorithm is intended to work in the way you described for the 9918A (alternating between white outline and green inside). When the game detects an F18A at startup, it will unlock it, ensure that the 4-sprites-per-line limit is set, and lock it again. The rest of the code just assumes an 9918A, so it shouldn't really look different unless the F18A has a slightly different behavior somehow?
First, thank you very much for the kind words! Of course I code for the joy of coding and my love for the platform, but I would be lying if I said this type of feedback doesn't motivate me do create more games :).
Regarding the navigation, indeed... the street targets are very small, basically one pixel. So trying to turn at exactly the right time is going to be very difficult, so use the diagonals. If you're going in a given direction and add in the diagonal, the game will always prioritize the new input for you, making it (hopefully) extremely easy to make the corners.
What I mean is that on the 9918A it's not alternating - you either see just the outline or just the interior. Could be something with my TV, I guess, if it's only showing half of the frames.
