Duewester Posted June 18, 2023 Share Posted June 18, 2023 Got a PEB on Ebay. Has two half height drives and an original Ti disk controller. As I understand it, I need Single Density floppies. Any advice or info is appreciated. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted June 18, 2023 Share Posted June 18, 2023 Any double sided double density floppies will work. I have a similar setup. 1 1 Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted June 18, 2023 Share Posted June 18, 2023 Yep... the oxide used on DD disks is the same as single density... the main difference is FM vs MFM modulation yielding higher density recording rather than the physical media itself. 2 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 18, 2023 Share Posted June 18, 2023 You will come across both 1D/SD and 2D/DD disks, but they are generally interchangeable. 2D/DD media will work with 1D/SD drives. Commodore 64 and Apples use GCR encoding which effectively format DD, different from MFM, but can use SD disks. 2 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 18, 2023 Share Posted June 18, 2023 I have disks in my store 2 1 Quote Link to comment Share on other sites More sharing options...
Duewester Posted June 18, 2023 Author Share Posted June 18, 2023 8 hours ago, arcadeshopper said: I have disks in my store Somewhere around here there SHOULD be a huge Rubbermaid box of floppies but, I will order some and probably get them in the mail before I could find them in the attic.😎 1 Quote Link to comment Share on other sites More sharing options...
