thedocbwarren Posted July 20, 2023 Share Posted July 20, 2023 I have a MegaSTe with the 1.44 floppy drive buit-in. I would like to use a Gotek drive, however, I'm wanting to not lose the ability to use a floppy drive. I'm not totally fussed replacing the internal but I want to use the 1.44 externally (or vise-versa.) What would I need and any suggestions on doing this? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 21, 2023 Share Posted July 21, 2023 I bought a Goex drive, fits perfectly in my old external floppy drive case and the OLED display fits nicely on top, no need to drill/file anything. I left a "real" floppy drive (not 1.44Mb) inside my STE, I changed the jumpers so the Goex external floppy drive is the boot drive, at some point I will fit a switch so I can select A/B for the drives. Only reason for not fitting a switch before is I didn't really want to drill the STE case. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted July 22, 2023 Share Posted July 22, 2023 As for the internal, the GOEX units are very nice and a Gotek (with a simple mod to move the light) will also fit without case modification. Quote Link to comment Share on other sites More sharing options...
Ute Posted July 24, 2023 Share Posted July 24, 2023 (edited) If you want to use the Goex or Gotek externally you have a few of choices for the adapter cable: https://www.ebay.com/itm/334756348147?hash=item4df10880f3:g:WakAAOSwDIdj804R&amdata=enc%3AAQAIAAAA0E%2FNQQLq17xw3AVHmlQ2vZ9XZTyN5hzZ4Ju42KSpU8D8M%2Fj%2F%2FiEpMum0ywDhGstKKjTmD2tmhijgsUEGnONAc5BE6WXAtWTP6hlLCGhl0sFoXnDrz2FkZVOhejxooRUfSOsAv%2BrSuHPMnEGkkV6AAShxVrg4d0b5FDGZudJrwz5VmHazDhhMqwl81HTLu8FgyQZousfpVEH5cCKf%2Fwdj9bXREb5TzseP9j%2BVJC9l8mfUNe85cPM4XPs%2B%2F2t7frFXLGdf495KfD18QtkzEIuQv1s%3D|tkp%3ABk9SR7jAuZ-xYg https://www.ebay.com/itm/334841786603?hash=item4df62030eb:g:JvwAAOSwpNlkQkuW&amdata=enc%3AAQAIAAAA0OvZBXYqz3J38cbvAsoQwSgS4ozJNAmO7XOjCsqjdZl1OkTQD%2FhLJzrc4XJwdC5tFW3LBBlIBKcefyKHLtBcXjpCNL3lGlwyLlEspYgH8teWbva%2Fdbon9IykMdhmsYfLz3StEqMzOhgfhRhttPzgoiWspluUhExsfyLUHE3HQx2Nl1GFag1ojDPjEIZbLEpJHeh30sbNFA5NbOKLxwNCL0STZwx4RcZ6uSUu2Y0sqVY8dWJZzW9kEIzFcaDcG1tUjT17GMvol%2B588fiamPuB0tU%3D|tkp%3ABk9SR7jAuZ-xYg https://www.ebay.com/itm/114409935581?hash=item1aa35d12dd:g:oSQAAOSwInxfNphw&amdata=enc%3AAQAIAAAA4PDYRN116Aaq00Biim3ZF1xtyA4bkguLBEIOHq%2FXwQrZCXDR87KXOw1KJ%2BBSdKuQ8rB2s%2BUvwipDClz2GfIZfzotDI%2FQlPX%2FDVNX8eiUevoWVEpOwHjJbEpe%2FkYZM96WHh%2Fx8J8m3TlThxtu%2Bj4dt5dd%2FA4SH1INIWx7Z4d0Jf0Ncx4Sy8B1CuRxrP%2F8TZndlBGLSu1Y67%2FchO8YPJI%2F7t%2BxWEbV1lnR7lVnS97J14VZzZqufBlCpf0zaZPv6jy1tbNdWEVEA32U3hHSfxoo%2Be%2F3544WAqOxewb6Qj%2FfH5KF|tkp%3ABFBMvsC5n7Fi Then you just need an external +5V power supply, I can't remember exactly, but I think 1-2 amps should be enough. I've made both the floppy cable and power supply before, but I don't recommend making the floppy cable since it is a little complex and there are other options available. Here is an older thread with more details: Edit: It looks like the first vendor sells it with a usb power supply cable as well so you can just plug it in to a phone charger and you're good to go. Edited July 24, 2023 by Ute Quote Link to comment Share on other sites More sharing options...
thedocbwarren Posted August 13, 2023 Author Share Posted August 13, 2023 Going to try again with a cable as the Indus hack just crashes on startup if it's connected. I still can't figure out how to make images on it that don't register a 304 error. Quote Link to comment Share on other sites More sharing options...
