+slx Posted July 23, 2023 Share Posted July 23, 2023 While Incognito certainly has enough storage for the Omnimon code, does the firmware support it as well (or are there any plans to add it in the future, @candle, @flashjazzcat)? Thanks! Questions applies equally to the various iterations of Omnimon and Colleen/XL mode. P.S.: BTW, what about U1MB and Omnimon? Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 23, 2023 Share Posted July 23, 2023 For Omnimon in XL mode it should be no problem. For 800 Omnimon, don't you need Rom available at $C000-CFFF ? Then there's QMeg as well, isn't that XL mode and at least 192K of extended Ram at $4000-7FFF Quote Link to comment Share on other sites More sharing options...
+slx Posted July 24, 2023 Author Share Posted July 24, 2023 20 hours ago, Rybags said: For Omnimon in XL mode it should be no problem. For 800 Omnimon, don't you need Rom available at $C000-CFFF ? Then there's QMeg as well, isn't that XL mode and at least 192K of extended Ram at $4000-7FFF I think 800 Omnimon resides at $C000-CFFF but can Incognito “put”/simulate ROM there? Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 24, 2023 Share Posted July 24, 2023 The normal XL OS uses that range as well, so Incognito would support it. But for 800 mode operation, unsure. The memory map of a stock 800 should give address bus noise from that range. Quote Link to comment Share on other sites More sharing options...
