+hunmanik Posted July 23, 2023 Share Posted July 23, 2023 What was the standard power supply unit used with the 1027 printer in the UK? There's the C061636 (two versions) for 120V AC, and the C061605 for 220V AC, but I can't find an equivalent one for 240V AC for the UK. Except for this page with a blurry picture of something but with almost the right description, is that it? https://collections.museumsvictoria.com.au/items/406491 Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 23, 2023 Share Posted July 23, 2023 Sounds like you need a step-down transformer. You don't need a high wattage unit, 40 watts so I'd go for at least 50 watts. Those are very cheap. Quote Link to comment Share on other sites More sharing options...
+hunmanik Posted July 23, 2023 Author Share Posted July 23, 2023 I'm looking for details/pictures of the original equipment unit. Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted July 24, 2023 Share Posted July 24, 2023 As I understand, you're looking for a PSU as a collector, not necessarily as a user. I don't know the answer (I suppose it's the same PSU as for a 1050) but a 1027 with an original printing hrad will print nothing nowadays. And it's head will be destroyed at an attempt. If you have one and want to keep it as a connectible item - don't even try. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 24, 2023 Share Posted July 24, 2023 2 hours ago, Peri Noid said: I don't know the answer (I suppose it's the same PSU as for a 1050) It requires a little more power than a 1050, service manual says 40 Watt PSU (about 4.4A @9VAC) I don't think these sort of PSU's are readily available (certainly not in the UK) I know people here have been struggling to get anything above 2.1A which is ok for a 400 or 800 but pushing it a bit for a 1050, certainly no good for a printer. Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted July 24, 2023 Share Posted July 24, 2023 1 hour ago, TGB1718 said: It requires a little more power than a 1050, service manual says 40 Watt PSU (about 4.4A @9VAC) It's not that difficult if you know where to look. And you can find them in a ... guitar store. Guitar effect PSUs often give 9VAC output an you can find even 4A ones (https://taniestruny.pl/efekty-i-akcesoria/zasilacze/zasilacz-rockpower-9v-ac-4000-ma, only the plug must be changed). 3A are even easier to find. Appart from that, this PSU is extremally simple and one can make it himself, the only problem is an appropriate transformer. 1 Quote Link to comment Share on other sites More sharing options...
+hunmanik Posted July 25, 2023 Author Share Posted July 25, 2023 If anyone realizes they have the original equipment 240V UK power supply unit for the 1027 in their closet, I hope they will consider sharing details and pictures of it here someday. Seemingly most people trashed them when their 1027 became unusable. Quote Link to comment Share on other sites More sharing options...
+slx Posted July 25, 2023 Share Posted July 25, 2023 As no dedicated 1027 unit seems to be listed on any of the „usual suspects‘“ sites, Atari UK might have repurposed an existing PSU for a few 1027s. Quote Link to comment Share on other sites More sharing options...
