Mattlyme Posted August 19, 2023 Share Posted August 19, 2023 Ohh where to start, Not a beginner here, but new to sdrive. Problem 1 I have a working UNO with a display that works. After flashing, I get the calibrate screen, calibrates fine. Sdrive boots, then I have no touch response, nothing. When the display goes to screensaver I can exit by touching the screen. Problem 2 After first boot I get the SIO timeout error, and I should because it's not hooked up. When hooked up I don't get D0 to load on the computer. I used to, but not anymore, I have formatted the SD and added the files multiple times, but I can never get it to load again. I Have used 4 different UNO's 2 of them brand new, 3rd known good. I have used 2 different displays, assumed working as the touchscreen calibrates. Thoughts? HELP!!!! Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 19, 2023 Share Posted August 19, 2023 Usually it's down to the display driver, some work to a degree, but you need to get the right one for your display, I've had them do the calibrate, but then not work correctly. There's usually several display drivers in the download, try each one and see if it gets any better. Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted August 19, 2023 Share Posted August 19, 2023 Tried them all, some are mirrored, some work, but none work with the touch. Forgetting about the touch part, it defaults to D0 so I should still get the menu on the Atari. I'm only using 3 wires so this should be straight forward. 1 wire from A5 1 from Tx 1 from Rx Power is supplied from barrel plug not USB Quote Link to comment Share on other sites More sharing options...
ascrnet Posted August 19, 2023 Share Posted August 19, 2023 for D0 verify that the file sdrive.atr exists in the root and that it is not damaged. Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted August 19, 2023 Share Posted August 19, 2023 Did that, tried multiple cards / downloads. What are the possibilities that I damaged something in the 65XE, What chip listens to the SIO plug. How would I test if it's good? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 19, 2023 Share Posted August 19, 2023 1 hour ago, Mattlyme said: How would I test if it's good? Do you have a disk drive or Cassette, you can test if SIO is ok with one of those. Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted August 19, 2023 Share Posted August 19, 2023 I do not, First Atari in the collection. Quote Link to comment Share on other sites More sharing options...
E474 Posted August 19, 2023 Share Posted August 19, 2023 (edited) If the 800XL booted previously, it's much more likely to be a problem with your SDrives. Have you formatted with FAT32, and how large is the SD-card? Can you upload photos showing the boards (PCBs)? Edited August 19, 2023 by E474 Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted August 20, 2023 Share Posted August 20, 2023 (edited) Wasn't there 2 hex files to transfer ? first flash flash:w:eeprom_writer.hex have you done that? Stefan Edited August 20, 2023 by Stefan Both Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted August 20, 2023 Share Posted August 20, 2023 3 hours ago, Stefan Both said: Wasn't there 2 hex files to transfer ? first flash flash:w:eeprom_writer.hex have you done that? Stefan Flash 2 files, then SD gets 1 file. Did that. It worked for 3 boots then I rewired the cable (yes it is correct after checking a million times) I might have flashed it again. I think I just had the right combination of UNO's, flash files, ATR and displays. Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted August 20, 2023 Share Posted August 20, 2023 FYI I GAVE UP!!!! Bought a Fuginet last night. I don't give up easily but by time I buy the correct display and another UNO, this is just easier. Thanks to all Quote Link to comment Share on other sites More sharing options...
deffroe Posted August 20, 2023 Share Posted August 20, 2023 Good call! Fujinet is one of those devices that makes you go, WOW! Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted August 26, 2023 Share Posted August 26, 2023 So Fujinet doesn't work either. With lots of reading, seems like POKEY chip is the problem. BUT my keyboard, controllers, and sound are fine. Next item would be the PIA. Any thoughts on this. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 26, 2023 Share Posted August 26, 2023 PIA certainly looks a possibility, but I would first check all the solder joints on the SIO port just in case any are cracked etc. Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted August 26, 2023 Share Posted August 26, 2023 1 hour ago, TGB1718 said: PIA certainly looks a possibility, but I would first check all the solder joints on the SIO port just in case any are cracked etc. Just re-flowed the SIO port, Pokey and the PIA Chip. Nothing. If you look back I did have this working as I was building an s-drive max. Then it quit. I bought the Fuginet to test if the port is truly bad. Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted September 2, 2023 Share Posted September 2, 2023 update PIA chip is not bad, replaced it tonight with the same result. In search of a POKEY chip next. I read somewhere that a Ballblazer cart would have a POKEY in it so I bought one off feeBay. The cart works but I don't think the chip inside is any version of POKEY the number is C05564-001 Yes / NO? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 2, 2023 Share Posted September 2, 2023 (edited) ballblazer 5200 the one you want is ballblazer 7800 Edited September 2, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted September 2, 2023 Share Posted September 2, 2023 24 minutes ago, _The Doctor__ said: ballblazer 5200 I hope your right, I just bought one of FeeBay Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 2, 2023 Share Posted September 2, 2023 36 minutes ago, Mattlyme said: update PIA chip is not bad, replaced it tonight with the same result. In search of a POKEY chip next. I read somewhere that a Ballblazer cart would have a POKEY in it so I bought one off feeBay. The cart works but I don't think the chip inside is any version of POKEY the number is C05564-001 Yes / NO? The Pokey chip is actually in the 7800 version of Ballblazer, not the 8 bit one. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 2, 2023 Share Posted September 2, 2023 (edited) 1 minute ago, Mattlyme said: I hope your right, I just bought one of FeeBay The one you want is BallBlazer 7800 cartridge it has a Pokey in it. The 5200 has a Pokey in the machine itself. Edited September 2, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted September 2, 2023 Share Posted September 2, 2023 3 minutes ago, _The Doctor__ said: The one you want is BallBlazer 7800 cartridge it has a Pokey in it. The 5200 has a Pokey in the machine itself. Thank you for that, I just canceled the order, I work for a music and games company, I digging through scrap boards looking for one. Does anyone have a list of coinop games that had this chip in it? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 2, 2023 Share Posted September 2, 2023 (edited) @Mattlyme @Mattlyme Pokeys were in a ton of coin op machine, some had 2 or 4 of them and some have quad pokey LSI chips too The POKEY chip, its dual, and quad-core versions were used in Asteroids Deluxe, Centipede, Millipede, Missile Command, Asteroids Deluxe, Gauntlet Firefox, Return of the Jedi, I Robot, and Major Havoc Edited September 2, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 2, 2023 Share Posted September 2, 2023 Not a complete list but according to Wikipedia: POKEY chips are used for audio in many arcade video games of the 1980s including Centipede, Missile Command, Asteroids Deluxe, and Gauntlet. Some of them also use the mythical "quad" pokey chip. Basically four Pokey chips in one package. They are: Firefox, Return of the Jedi, I, Robot, and Major Havoc Quote Link to comment Share on other sites More sharing options...
Mattlyme Posted September 2, 2023 Share Posted September 2, 2023 1 minute ago, scorpio_ny said: Not a complete list but according to Wikipedia: POKEY chips are used for audio in many arcade video games of the 1980s including Centipede, Missile Command, Asteroids Deluxe, and Gauntlet. Some of them also use the mythical "quad" pokey chip. Basically four Pokey chips in one package. They are: Firefox, Return of the Jedi, I, Robot, and Major Havoc If I don't find one local, would I be better to buy the reproduction, or the 7800 cart? There is someone selling an alternative modern FPGA replacement. https://paradisearcadeshop.com/products/pokeyone-v2-fpga-atari-pokey-replacement Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 2, 2023 Share Posted September 2, 2023 Make sure the replacement FPGA ones can handle SIO etc. some were only for sound. 1 Quote Link to comment Share on other sites More sharing options...
