pixelmischief Posted September 2, 2023 Share Posted September 2, 2023 (edited) I have an XF551 that's been working fine for years. I recently bought a HyperFX upgrade for it and when I opened it up...there was nothing in U6. Just through-holes filled with solder. With nothing to remove, I just installed the upgrade. The drive still woks, but none of the expected functionality seems available; no ultra-speed skew in SDX format and no "boot?" prompt when I power on without a disk. I opened one of my other XF's and it is as I would expect; a socket at U6 with a ROM in it. I suppose I can desolder the upgrade from the "brainless" (two-brained?) XF and put it into the socketed one, but I'm still curious about the unexpected configuration. A lazy Google shot turned up nothing. Edited September 2, 2023 by pixelmischief Quote Link to comment Share on other sites More sharing options...
cwc Posted September 2, 2023 Share Posted September 2, 2023 (edited) If I am getting this right from another thread (happy to be corrected), the firmware on your XF551 without U6 will be on the P8050H processor U1. I assume you can install a socket and EPROM in U6 (as you have done) then change the jumper from the S3 to S4 position and that should do it. See: https://forums.atariage.com/topic/338300-atari-xf-551-roms/?do=findComment&comment=5308127 Edited September 2, 2023 by cwc 1 Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted September 2, 2023 Author Share Posted September 2, 2023 @cwc Thanks for info. Decided to just remove the mod from C6 and put it into the socketed XF, since it requires no additional mod. Got the "boot?" prompt. Now I just need to learn about these many "modes". 2 Quote Link to comment Share on other sites More sharing options...
cwc Posted September 3, 2023 Share Posted September 3, 2023 (edited) In case you haven't found the manual: http://blog.3b2.sk/igi/post/Hyper2b-XF-10-MANUAL.aspx Edited September 3, 2023 by cwc Quote Link to comment Share on other sites More sharing options...
