tape based type-in spreadsheet basic program for Atari 600XL or 800XL
newTIboyRob
@newTIboyRob
Because the have different screen actions
they are different key combinations
esc clear
esc control clear
esc shift clear
also, hitting esc key twice yields esc symbol then your key combo is entered for those instances
Edited by _The Doctor__
oh, so, when I am typing in that line with the shaded arrow, i still type it in with just the Esc key and arrow as I have been doing just now (not using the inverse key like you said).... with the concept that when the program is run, the user would have to first press the Esc key with the up arrow key in order to perform the function, which, in the program line of the pdf is that shaded arrow?
No, you are putting screen commands in, they will execute when the program runs.
the bent arrow may clear the screen,
the individual arrows may show the person to press the arrows
it depends on the escape sequence
one esc and then the special character combo will execute during run
two esc and then the special character may just show the graphic representation so a person knows to press the arrow keys to move around. If the escape sequence were a single it would move the cursor around the screen.
I suppose this is harder to describe if you don't have the pdf up. Are you able to see the lines in question?  For example line 414 has the shaded arrow, and that is what I am trying to achieve while still typing that line now.
And also note the arrows are different within the last few lines of the program.
Edited by newTIboyRob
It's not hard at all, if you want to be told what each combination is there is a complete section on it in the BASIC manuals.
I have the PDF up and I sincerely already knew what to expect, as I have used BASIC for many decades, as well as 6502 ML.
If I were sitting in front of the Atari at this moment, I would type it in without thinking at all about it.
Sitting on a PC keyboard typing it on the forum isn't quite the same.
The other thing I normally do is to POKE 82,0 first thing as I get to BASIC, It allows me to type more in per BASIC line.
2 minutes ago, newTIboyRob said:
Esc 2 didn't do anything (I also tried Esc Cntrl 2)
Escape key hold control press 2 sure will do something
and pressing control 2 without an escape first certainly will buzz
make sure you didn't press the inverse or caps key etc.
CONTROL key held and press 2 will buzz immediate mode
ESC key control held and press 2 will give inverse bent arrow and at run time will buzz when that line executes
ohhhhh ... I was holding down the Escape key.  You just press that key ONCE and then rather quickly press but hold contrl 2 and NOW I see the bent upwards left arrow is there.  C'mon, that is/was tricky for someone who doesn't have your decades of experience in basic!   :)
So the final question I guess is in line 460, as that one is not shaded in. How do I achieve that?  Is that the same as the standard Escape Control up arrow or no?
normal bent arrow is clear screen
inverse bent arrow is buzzer
go back and read you will see pressing and holding was only mentioned for control key not escape key
so once again
escape key hold control and press clear
or
escape key hold shift and press clear.
that gets you normal bent arrow for clear screen
the only other notation would be escape key control key help press (whatever key)
Correct, but you see how in the last line of the program there are both kinds of arrows?  I understand how to get the shaded one in now while typing in that line, but what I am asking is... is that plain arrow towards the end a simple Esc press once then hold and press Cntrl 2 and the Up arrow, while typing in this line, I mean to have that appear in the program line before pressing enter?
I did read.
When I press Esc Cntrl 2, I get what looks like a shaded in arrow on screen.  But... if I did that same procedure while typing the last line in, I would not get a non-shaded arrow.  Herein lies the confusion.
Unless what we are saying is that I would type that same way again with the Esc Cntrl 2,  but when the program is run, it will actually do that command  (thus both of my Esc Cntrl 2, while typing in the line will both appear on my screen as the same looking bent shaded in upwards arrow.  If that's not it, I just don't get it....yet.
you need to do them differently on the last line, first one is the buzzer combo second one is the clear combo you can do both on the same line, just do the escape control held 2 on the first one and then do escape control held clear on the second one.
Oh Doc, my apologies... I actually glanced over, what, ironically, was what caused my confusion... I simply missed it.  It was here, and I missed it with all the back and forth:
so once again
or
And your last post summed it all up.... I think I have it now, and, again, sorry for that confusion on my part!  (Feeling dumb and embarrassed on this end, but now I see the light with all that.)
Just wondering also... would you say that the symbol at the end of line 276 is a simple dash then with the left arrow key?
