JOD-I Posted September 13, 2023 Share Posted September 13, 2023 I have the full rom of Gorf Arcade and it will not run on my new Encore cartridge. I tried to update it even though it came with the current updates. It runs most roms fine but some of my champ games roms are not running properly or at all. I have tried this cart in 2 of my 7800 consoles and my 2600 console. All are the same. Quote Link to comment Share on other sites More sharing options...
JOD-I Posted September 14, 2023 Author Share Posted September 14, 2023 I tried to put the rom in on developer mode but when I pressed download the program told me that the rom could not be compressed. I could put other roms in on developer mode but not Gorf Arcade. Quote Link to comment Share on other sites More sharing options...
JOD-I Posted September 15, 2023 Author Share Posted September 15, 2023 My original Harmony which I also updated will play Gorf Arcade on any of my Atari's even though my Harmony Encore will not. Why? Quote Link to comment Share on other sites More sharing options...
+H454 Posted September 16, 2023 Share Posted September 16, 2023 The new Harmony carts have a new chips. A small number of roms may need to moded to work on the new cart. 1 Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted September 16, 2023 Share Posted September 16, 2023 @batari Has the programmer from champ games corrected his ROMs? Would getting a reissue from him fix @JOD-I's problems? 1 Quote Link to comment Share on other sites More sharing options...
JOD-I Posted September 16, 2023 Author Share Posted September 16, 2023 So I just downloaded and tested the demo version of Gorf Arcade and it does work so I am assuming that the full version has been updated and should work. Thank you @H454 and @bent_pin for your guidance and support. Quote Link to comment Share on other sites More sharing options...
JOD-I Posted September 17, 2023 Author Share Posted September 17, 2023 Long story short, I went ahead and got v3 of Gorf Arcade and thank the lord it works great now on my Harmony Encore. 1 1 Quote Link to comment Share on other sites More sharing options...
Eisengrim Posted October 24, 2023 Share Posted October 24, 2023 I'm trying out Gorf Arcade Demo on a Harmony Cart via Intellivision System Changer, and it works, but the "Quark Laser" function where the fire button releases a new shot but destroys the first isn't working. An earlier demo I had with fewer sound effects did have this function. Does the full game work like the arcade? Quote Link to comment Share on other sites More sharing options...
+batari Posted October 25, 2023 Share Posted October 25, 2023 On 9/15/2023 at 5:20 PM, H454 said: The new Harmony carts have a new chips. A small number of roms may need to moded to work on the new cart. Yep, in around late 2021, I began using chips with a different silicon revision. Recently, I was able to obtain chips of the silicon revision I was using before 2021, so I am now using these pre-2021 chips exclusively for Harmony Encore. The pre-2021 chips should run either version of the games. For now, Standard Harmony carts may still use the post-2021 chips. Quote Link to comment Share on other sites More sharing options...
Absalon Posted October 26, 2023 Share Posted October 26, 2023 23 hours ago, batari said: Yep, in around late 2021, I began using chips with a different silicon revision. Recently, I was able to obtain chips of the silicon revision I was using before 2021, so I am now using these pre-2021 chips exclusively for Harmony Encore. The pre-2021 chips should run either version of the games. For now, Standard Harmony carts may still use the post-2021 chips. I own one of these "different silicon revision" chip cards and can not play the pal rom of Qyx on my pal systems. When I order another harmony encore card, do I get the "old" chip? Quote Link to comment Share on other sites More sharing options...
+batari Posted October 26, 2023 Share Posted October 26, 2023 We're working on fixing Qyx. So stay tuned on that. 1 Quote Link to comment Share on other sites More sharing options...
SuperSamyon Posted November 23, 2023 Share Posted November 23, 2023 On 10/25/2023 at 5:06 AM, batari said: Yep, in around late 2021, I began using chips with a different silicon revision. Recently, I was able to obtain chips of the silicon revision I was using before 2021, so I am now using these pre-2021 chips exclusively for Harmony Encore. The pre-2021 chips should run either version of the games. For now, Standard Harmony carts may still use the post-2021 chips. Just wanted to confirm, if I buy a Harmony Encore today, the chip inside will be the pre-2021 one? Quote Link to comment Share on other sites More sharing options...
BIGHMW Posted November 23, 2023 Share Posted November 23, 2023 (edited) Then I am also wondering if MY Encore has a post-2021 ship in it too, that could explain the most recent wrath of issues I am having with Chaotic Grill that started yesterday after it was working previously in it as well as my older Encore cart as well as my Flashback 9, cause it sure as hell couldn't be the ROM itself Edited November 23, 2023 by BIGHMW Quote Link to comment Share on other sites More sharing options...
