Dopy25 Posted September 25, 2023 Share Posted September 25, 2023 So I have a Dreamcast that was dropped or hit or something. I bought it as parts but it needed a new power supply. After that it powered and worked fine over VGA on a flat screen. Come time to play it on crt, I only had a composite cable. It had crap video, almost like it was scrolling. I took it apart and thought to check everything inside. I didn't see anything out of the ordinary. Nothing burned up, no broken solder that I could see. Continuity between all contacts on the video output. So I ordered an svideo cable and it works fine over svideo. Different cable still won't support composite. Also, I tried both cables on a different console with the same result. Image attached. Is there a composite video amp or chip that's separate from s video or VGA? Any advice is appreciated. Quote Link to comment Share on other sites More sharing options...
