reifsnyderb Posted October 5, 2023 Share Posted October 5, 2023 Hello, I did a quick search and didn't find an answer, so, I figure I'll ask. I am using the printer output, in Altirra, whereby I have a device configured as a virtual printer ("P:") and can get a virtual printout in the "Printer Output" window. Presently it's only 40 columns. Is this normal? Can I configure this to be 80 columns? Thanks! Brian Quote Link to comment Share on other sites More sharing options...
phaeron Posted October 5, 2023 Share Posted October 5, 2023 Not currently, it simulates a baseline 820 -- doesn't do line splicing for the wider printers. 2 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted October 5, 2023 Share Posted October 5, 2023 4 hours ago, phaeron said: Not currently, it simulates a baseline 820 -- doesn't do line splicing for the wider printers. That's odd, mine seems to print any width I send to it ? Unless I'm missing something in how the printer is being setup. 10 DIM A$(100) 20 OPEN #1,8,0,"P:" 50 A$="SKDJSALDJKSLALDSLJSLAJLDJSALSJD LSAALJLSLDJLSLALLSALJLSLAJLJLJALJ" 100 PRINT #1;A$;A$: REM PRINT A$ TWICE WITH NO CR IN BETWEEN 110 CLOSE #1 OUTPUT in Printer Windows=SKDJSALDJKSLALDSLJSLAJLDJSALSJDLSAALJLSLDJLSLALLSALJLSLAJLJLJALJSKDJSALDJKSLALDSLJSLAJLDJSALSJDLSAALJLSLDJLSLALLSALJLSLAJLJLJALJ Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 5, 2023 Share Posted October 5, 2023 I'm getting 40 cols regardless whether I use LPRINT, ? # or LIST "P:" Maybe it's version dependent? That was in 3.90 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted October 5, 2023 Share Posted October 5, 2023 2 hours ago, Rybags said: Maybe it's version dependent? That was in 3.90 Mine is 4.10 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted October 5, 2023 Author Share Posted October 5, 2023 I am using 4.10. 40 columns isn't a problem for what I am working on. I just wanted to know. 🙂 Quote Link to comment Share on other sites More sharing options...
phaeron Posted October 5, 2023 Share Posted October 5, 2023 It's interface dependent. The Printer device in the emulator implements both CIO hooks and an SIO device. If you write through the CIO device, you'll get more than 40 columns in current versions, but if you're sending SIO commands -- say, because you're working on a print spooler -- it'll be limited to 40 columns. That's because the SIO protocol fundamentally still sends 40-column chunks, it's just that some printers re-splice the lines via the EOLs in the sent data. IIRC, there were some unusual behaviors in the way that some OS versions sent EOLs in corner cases, which is part of the reason I started disassembling the 820 and 1025 firmwares (not having the physical printers, nor much of a desire to actually get said printers). 1 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted October 5, 2023 Author Share Posted October 5, 2023 (edited) 32 minutes ago, phaeron said: It's interface dependent. The Printer device in the emulator implements both CIO hooks and an SIO device. If you write through the CIO device, you'll get more than 40 columns in current versions, but if you're sending SIO commands -- say, because you're working on a print spooler -- it'll be limited to 40 columns. That's because the SIO protocol fundamentally still sends 40-column chunks, it's just that some printers re-splice the lines via the EOLs in the sent data. IIRC, there were some unusual behaviors in the way that some OS versions sent EOLs in corner cases, which is part of the reason I started disassembling the 820 and 1025 firmwares (not having the physical printers, nor much of a desire to actually get said printers). That explains it! Since I am avoiding CIO, and sending straight to SIO, I only get 40 columns. That's fine. 🙂 32 minutes ago, phaeron said: I started disassembling the 820 and 1025 firmwares (not having the physical printers, nor much of a desire to actually get said printers). You really do need to get a 1025. Printing 20 pages, on a 1025, needs to be experienced to be truly appreciated. 🙂 Edited October 5, 2023 by reifsnyderb 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 5, 2023 Share Posted October 5, 2023 [posted in wrong thread...] Quote Link to comment Share on other sites More sharing options...
