Time delta in milliseconds?
trufun101
https://reboot-games.com/jagstudio/ReferenceManual.html#general
You will need to use rapNTSCFlag to determine if you are running on a PAL or NTSC console. This tells you if it should be 50 or 60 ticks per second.
Then you'll need to look the the current rapTicks value. If you track the difference of rapTicks from your last frame, you can then divide with the 50 or 60 from above to work out timing.
Perfect, thank you!
On 10/7/2023 at 4:28 AM, trufun101 said:
Is there a way to calculate the time delta between updates?  I've tried using rapSetClock(0) and rapClockHex, but that appears to be an integer value of whole seconds.  Is there a way to keep time at the millisecond?  I'm using JagStudio C.
Thanks!
If 20 or 17 ms is to rough, you can always use one of th HW timers. Setting these up is no rocket science.
  • 2 weeks later...
I think I'm doing something wrong.  I'm trying to calculate the time delta (as a fraction of a second) and multiply that by the movement speed, but the character isn't moving.
Here's what I've got:
int ticksPerSec = 60;  //NTSC by default
int lastTicks = 0;
if (!rapNTSCFlag)
    ticksPerSec = 50;  //PAL
//Main Loop
for(;;)
    float delta = (rapTicks - lastTicks) / ticksPerSec;
    lastTicks = rapTicks;
    //for movement...
    sprite[spriteIndex].x_ -= playerMoveSpeed * delta; //playerMoveSpeed == 40
So, let's say the delta is 3 ticks / 60 tps or 0.05.  I would expect the character to move 2 pixels (40 * 0.05) with each update.
Or am I going about this the wrong way?
int lastTicks = 0;
if (!rapNTSCFlag)
//Main Loop
for(;;)
    //for movement...
Above statement is always 0 since you're doing integer division, change it to this...
    float delta = (float)(rapTicks - lastTicks) / (float)ticksPerSec;
Oh, duh.  Thank you.  I can't tell you how many times I've made that mistake in the past.  It's just tougher without being able to step through the code.
Speaking of which, is there a way to print the value of the int using js_r_textbuffer?
50 minutes ago, LordKraken said:
To elaborate on what @42bs just wrote, use rapTicks directly, just adjust your move speed directly.
 sprite[spriteIndex].x_ -= playerMoveSpeed * rapTicks;
I think you missed the delta.
x -= playerMoveSpeedPerTick * delta;
Of course we do not want float, so
playerMoveSpeedPerTick = (40*256+20)/60;
or
playerMoveSpeedPerTick = (40*256+20)/50;
then
x -= (playerMoveSpeedPerTick * delta) >> 8;
