Atari 5200 2 Port - No Power
NoLogicNeeded
5 minutes ago, bent_pin said:
Well, that sucks that it's dead, but at least you didn't open your 5200 yet.
I can sell you one. Did you buy it on ebay?
Also, did you try a different plug in your house to be sure that it's dead?
Yep, I bought it off Ebay. Tested it in 3 different places and I get the same 120 millivolt reading. How much would you want for one?
8 minutes ago, bent_pin said:
Just checked ebay, I'd probably need to charge more than they would. Try to get one marked as tested from someone with a good feedback rating.
https://www.ebay.com/itm/325839452498
This one has a make an offer so you might be able to get it cheaper.
Strange, mine looks completely different.
Edit: Looks like the one you sent is for a four port unit, mine's a two port.
Edited by NoLogicNeeded
If you don't mind the shorter cord, I can also strongly recommend these replacement power supplies that work great on the 5200. I use one of these in the test lab in fact.
https://console5.com/store/triad-magnetics-power-supply-for-atari-5200-twin-famicom-pal-snes.html
I'll keep that in mind if this one doesn't work.
  • 1 month later...
On 10/9/2023 at 10:35 AM, 0078265317 said:
Or atari_dna was able to rebuild mine last time I sent my 4 port in for fixing.
Yes the original PSU doesn't have much in it other than the transformer, a fuse, and a large filtering capacitor. The fuse is usually the culprit as something in the past might have caused them to blow and have to be replaced out. I've repaired a few of the original PSUs in this manner and in fact might be sitting on a small stock pile of 5200 PSUs just in case...
