mmoec Posted October 14, 2023 Share Posted October 14, 2023 Hi 👋 I just finished pimping out this 130XE with the following: VBXE UAV SAVO XE U1MB PokeyMax v2B (Stereo + Quad Covox) Triple checked all my wiring, fired it up and (yeah! 😃) it booted to SDX. The only issue is there is this loud buzzing noise coming from the TV speakers. I double checked all the wiring again and everything looks sound. I put the Pokey chip back in and the buzzing stops. The L and R audio from the PokeyMax are connected to the L and R audio on the SAVO, and the jumper is removed. I wired the PokeyMax according to this diagram I found on the RetroLemon site. My question is, am I supposed to add those two 10uf resistors to the L and R audio 🤔? Initially it looked to me like they were only to be added if the audio was being connected to an external device. IMG_0207.mov Quote Link to comment Share on other sites More sharing options...
foft Posted October 14, 2023 Share Posted October 14, 2023 I was replying on facebook, but for the benefit of the thread... Pokeymax 2B has the external decoupling caps built-in, its just Pokeymax 2 that doesn't. There are 4 outputs and the 4th goes direct to pin 37, its not on the header To play bad audio like that I'd say most likely it has the wrong core and has gtia audio input on one of those address inputs. Run pokeycfg to check the version is correct. Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted October 14, 2023 Share Posted October 14, 2023 I had the buzzing sound when I used my Pokeymax was due to using the ground from the Pokeymax pin itself. I solved it by picking up ground somewhere else on my XE remake (I think I picked it up from the pins on the cart/eci port). How are you grounding your external audio from the SAVO? Also, it seems you have a wire from the ground pin going to the ground plane of the PCB. In my setup, I left it unconnected since I picked up ground somewhere else. @foft: Is it necessary to connect up the ground from the Pokeymax if it is not used? Quote Link to comment Share on other sites More sharing options...
mmoec Posted October 17, 2023 Author Share Posted October 17, 2023 Issue Resolved! I have been in contact with the person who sold me the PokeyMax and I found out exactly what version I have (Quad version with Auto control) and wired it according to one of the diagrams I found on the RetroLemon site, and the device is now working properly. Thanks to all who took the time to share their input, and apologies for not responding sooner, as I was unable to make the time. 👍 2 Quote Link to comment Share on other sites More sharing options...
