newTIboyRob Posted October 20, 2023 Share Posted October 20, 2023 Hello all. A couple of months ago, I posted a thread about this topic, but as I couldn't quite put everything together, I thought I'd just start fresh with a new post here. I have the Atariwriter cartridge and Epson FX-80 printer combination. When I got to the print menu of Atari-only printers 1-4, namely the 1025,820,825,822, naturally none would work. So I'll have to go the insert printer control codes route it seems. I looked in the back of the FX 80 manual, but as I say, I couldn't quite put it together in how to use/where to insert the codes in Atariwriter. It was showing LPRINT statements in general, so I wasn't quite sure if those literally have to be incorporated in an Atariwriter document or where. So I thought it just easier if someone who has done this before and can recall might be so kind as to demonstrate how, with the codes, within the following fun little paragraph I wrote. Actually before that 2 quickies: 1) what is and where does the command for just a straight file dump, without any specialized codes, to the printer go within the document? 2) Is there a way with the printer codes to completely change the entire font style for the printout in Atariwriter, say from 15 pica to a 10 of another style/look of printed characters on paper? 3) Here is the paragraph as if typed in Atariwriter: It is (amazing, in boldface) how an early 1980's Atari 600XL computer can still communicate with modern devices in (2023 underlined), like the [Sdrive Max in italics]. Such a piece of gadgetry can obliterate both the need for and the problems associated with the obsolete 410 tape recorder. Though it may take a [little, in condensed print] effort to get comfortable with using, the horizons are [wide, in double wide print] open in terms of future technological advances for the Atari fan. Quote Link to comment Share on other sites More sharing options...
+David_P Posted October 20, 2023 Share Posted October 20, 2023 Atarimania appears to be down right now, but once it's back up: http://www.atarimania.com/utility-atari-400-800-xl-xe-printer-driver-construction-set_18544.html Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 Thanks @David_P I see that now. I am not quite sure how to incorporate that for use with the Atariwriter though? Is that something I download and put on my Sdrive Max and then run it one time, like our modern drivers, which will then always make Atariwriter communicate with my FX 80? I'm not quite following yet. (I don't understand how it comes into play with loading and using an Atariwriter document.) Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 @x=usr(1536) and @TGB1718 ... hoping you have some thoughts on my post above Quote Link to comment Share on other sites More sharing options...
Forrest Posted October 20, 2023 Share Posted October 20, 2023 The link at Atarimania shows a floppy disk label that says boot side 2 of this disk for documentation. Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 yes Forrest, I see those literal floppy disk photos in the PDF... but I am not sure how all this interplays... Quote Link to comment Share on other sites More sharing options...
Forrest Posted October 20, 2023 Share Posted October 20, 2023 I’m guessing there are two disk images in the download - side 1 and side 2 Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 (edited) That link may refer to Atariwriter Plus, which I know shipped with 2 floppies back in the day and gave you the ability to load a driver from disk for example. However, I have the original Atariwriter cartridge, so I would like to use that with the Epson FX-80 in the way I described above. Edited October 20, 2023 by newTIboyRob Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted October 20, 2023 Share Posted October 20, 2023 Nope it does not. Why do you discuss instead of just trying to boot these images and see what happens? 🙄 On the above linked page is also a link to AtariWriter itself. If you follow this link, you will find the complete manual of AtariWriter (which might give some information on how to define printer controls). But anyway: First try the Construnction Set. Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 (edited) @DjayBee I just find that link a little bit confusing because I see you can Load or Save a driver, but I don't see how to create the Epson Fx-80 printer driver. I didn't think it was so wrong to discuss this here. Luckily I did a little research and found a disk image that contained the FX 80 driver, so I will see if I can get that to work. In case anyone else needs it, I found it with APX_AtariWriter_Printer_Drivers_1.0.atr Edited October 20, 2023 by newTIboyRob Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 20, 2023 Share Posted October 20, 2023 1 hour ago, newTIboyRob said: Luckily I did a little research and found a disk image that contained the FX 80 driver, so I will see if I can get that to work. In case anyone else needs it, I found it with APX_AtariWriter_Printer_Drivers_1.0.atr There's a 2.0 version of this same set of drivers: Serious Computerist - AtariWriter Printer Drivers v2.0 Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 Hello again @MrFish ... you can see I have come a long way, yes? So you think the 2.0 version would be better to use than what I posted? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted October 20, 2023 Share Posted October 20, 2023 6 hours ago, newTIboyRob said: @x=usr(1536) and @TGB1718 ... hoping you have some thoughts on my post above Would love to help, but although I used AtariWriter extensively and with many Epsom printers using my own drivers and printer interface, I really can't remember how I did it (round the goldfish bowl too many times). I know I used to boot my disk first, then put in a DOS disk to continue the boot to AtariWriter, when using AtariWriter, I know I used to embed the printer codes in the text file itself. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 20, 2023 Share Posted October 20, 2023 4 minutes ago, newTIboyRob said: Hello again @MrFish ... you can see I have come a long way, yes? Haven't really been following the progress; but I did see you mention an SDrive Max and 64KB RAM (?). 10 minutes ago, newTIboyRob said: So you think the 2.0 version would be better to use than what I posted? Depends if the disk contains an update for your specific printer. I don't really know what the update is about, at this point (I used to know, back when I added it to my website). You'll have to refer to the documentation to answer your question. Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 Hello @TGB1718 thank you, no problem Yes, your last sentence on code embedding echoed my thoughts in my first post above. Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 20, 2023 Author Share Posted October 20, 2023 @MrFish yes, exactly. There was no way I could use the Sdrive without also getting the 64K RAM... so after going around in circles like a mad dog, I just bit the bullet. It's been working out nicely thus far though, as I don't cringe as I did when I approached the uncertainty of the 410 working or not! Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted October 22, 2023 Share Posted October 22, 2023 Where are you with this? I think you generate an Autorun.Sys file on your AtariWriter boot disk. This overlays the printer drivers that come with AW. Do you have a copy of PDCS? Or something equivalent? Bob Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 22, 2023 Author Share Posted October 22, 2023 Hello Bob, thank you. I learned there is an Epson FX 80 driver for the Atariwriter found on a disk image I downloaded and put on my Sdrive. I am trying to see if that will work with the Atariwriter cartridge or not. Should it fail, I've learned that Atariwriter Plus has accomodation for FX 80 printer within the program itself. I will know more when I run some tests tomorrow. Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 22, 2023 Author Share Posted October 22, 2023 So there's another element thrown into the mix here. Let's see if we can figure this one out or come up with a work-around. I got an Atarwriter text file I made to Save and Load to D1 on The Sdrive. (From what I gather, D2 does not work with the program, just D1 to load and save.) I was able to get the APX file containing the Epson FX80 driver onto the SDrive easily and Load it back in to memory, (From (I)nventory of files I did see the EPSNFX80 driver) But now the driver is in memory for later printing. If I try to load my text program back from D1, it will ask Erase File In Memory (the Epson Driver) Someone who has used Atariwriter with an Epson printer back in the day would be very helpful here. How did you do it back then? Maybe thus it can't work in this new configuration now with the Sdrive? Quote Link to comment Share on other sites More sharing options...
gozar Posted October 22, 2023 Share Posted October 22, 2023 The directions are on the second disk of Atari 400 800 XL XE Printer Driver Construction Set Since the FX80 was so popular, Disk A already contains the driver for it. Copy it to your AtariWriter boot disk and name it autorun.sys. Boot up AtariWriter from that disk and you're good to go! Quote Link to comment Share on other sites More sharing options...
newTIboyRob Posted October 23, 2023 Author Share Posted October 23, 2023 (edited) Actually, I had a happy ending with this here after all. Turns out that, yes, that autorun.sys file was the clincher, as gozar just mentioned. Here's more detail: I just downloaded the second set of APX drivers that contained the necessary EPSNFX80 file onto my Sdrive Max. Once you select that APX file, you load that in from the Sdrive so you can load the EPSNFX80 file into Atariwriter memory, then (S)ave that file as AUTORUN.SYS on your Atariwriter data disk. But 2 key elements I would like to add: 1) After this is done, you need to power off then on the Atari 2) If you're using the original cart still like I am, that Epson driver is shared (basically "hidden" because it still is not listed on the printer selection menu) by selecting #3, the Atari 820 After I did all of the above, I finally had success: typed, saved, loaded and printed a nice little document. Since the printer now communicates, I can just look in the manuals to see how to get those more fancy things like the Italics et al I mentioned in the first post above in there. Eventually a very satisfying experience on this one! Edited October 23, 2023 by newTIboyRob 3 Quote Link to comment Share on other sites More sharing options...
