chad5200 Posted November 23, 2023 Share Posted November 23, 2023 This is listed on the Atari+ Game Compatibility List as UNTESTED. Artillery Duel works fine. However, Spike's Peak does not work. The game will load and it looks OK at first. Even plays the little starting tune. But there is no joystick functionality (tried both Left and Right ports). You can hit Reset and it will play the starting tune again... but still, joystick not working. (I confirmed Spike's Peak works properly on a real original 2600 with joystick in Left port. And yes, I did clean the contacts.) It is interesting to note that the Atari+ Game Compatibility List has the single-ender Spike's Peak listed as PASS. I wonder if they tried actually playing the game? Or maybe the ROM is different between the single-ender and the double-ender? 1 Quote Link to comment Share on other sites More sharing options...
DEANJIMMY Posted November 23, 2023 Share Posted November 23, 2023 (edited) Both Double-Ender games work🤙 Sir Lancelot & Robin Hood PAL(!) Edited November 23, 2023 by DEANJIMMY Quote Link to comment Share on other sites More sharing options...
atwwong Posted November 24, 2023 Share Posted November 24, 2023 9 hours ago, chad5200 said: This is listed on the Atari+ Game Compatibility List as UNTESTED. Artillery Duel works fine. However, Spike's Peak does not work. The game will load and it looks OK at first. Even plays the little starting tune. But there is no joystick functionality (tried both Left and Right ports). You can hit Reset and it will play the starting tune again... but still, joystick not working. (I confirmed Spike's Peak works properly on a real original 2600 with joystick in Left port. And yes, I did clean the contacts.) It is interesting to note that the Atari+ Game Compatibility List has the single-ender Spike's Peak listed as PASS. I wonder if they tried actually playing the game? Or maybe the ROM is different between the single-ender and the double-ender? I have a Xonox double ender with Ghost Manor and Spike's Peak. Ghost Manor works. Spike's Peak does the same as the OP; it loads fine but the joystick does nothing. 1 Quote Link to comment Share on other sites More sharing options...
tradyblix Posted November 25, 2023 Share Posted November 25, 2023 On 11/23/2023 at 1:36 PM, DEANJIMMY said: Both Double-Ender games work🤙 Sir Lancelot & Robin Hood PAL(!) That's not likely to make that cart any cheaper lol Quote Link to comment Share on other sites More sharing options...
Chemical Burrito Posted November 25, 2023 Share Posted November 25, 2023 On 11/23/2023 at 1:00 PM, chad5200 said: This is listed on the Atari+ Game Compatibility List as UNTESTED. Artillery Duel works fine. However, Spike's Peak does not work. The game will load and it looks OK at first. Even plays the little starting tune. But there is no joystick functionality (tried both Left and Right ports). You can hit Reset and it will play the starting tune again... but still, joystick not working. For what it's worth, I see the exact same behavior on my 2600+ from Spike's Peak on my working-on-original-hardware Artillery Duel/Spikes Peak double-ender. Quote Link to comment Share on other sites More sharing options...
