Juansinlau Posted December 10, 2023 Share Posted December 10, 2023 I've tested a 32-in-1-cartridge on the 2600+. It loads and I can play the 1st game ("UFO"), but I can't switch to any of the other games. The original manual states to "toogle the ON/OFF switch between the ON and OFF positions", but that only restarts the console with the 1st game appearing again. Any clues? Quote Link to comment Share on other sites More sharing options...
guidedlight Posted December 11, 2023 Share Posted December 11, 2023 I found if you quickly remove and reinsert the 32-in-1 cartridge the game will change. But it’s unreliable, and the dreaded “Game Loading Failure” message will certainly thwart your progress. I’d say this cartridge is not compatible with the Atari 2600+. 3 Quote Link to comment Share on other sites More sharing options...
AtariYMás009 Posted December 11, 2023 Share Posted December 11, 2023 Many people have previously tried the 32 in 1 (myself included) and it works wonderfully, most likely you are turning the console off and on too quickly, although this is normal in the original console, in the 2600+ it is advisable to wait a few 3 seconds after turning off to turn on again. Try it again and tell me if that works for you. Quote Link to comment Share on other sites More sharing options...
Mockduck Posted December 11, 2023 Share Posted December 11, 2023 The 32 in 1 randomly plays a game every time I power the system off and on, I always figured that was how it was supposed to work even if it's odd. Mine is a PAL cart though so I haven't actually been able to play it until now. Quote Link to comment Share on other sites More sharing options...
Juansinlau Posted December 11, 2023 Author Share Posted December 11, 2023 Thank you AtariYMás009, that does the trick. So it works actually. Odd: If I want to choose a specific game I need to switch on/off the system in average 16 times... Mmmmh, I'll see how often I'm willing to do that 1 Quote Link to comment Share on other sites More sharing options...
GarryG Posted February 24 Share Posted February 24 Was this the cartridge that could be hacked to add your own games instead of the origonal ones? Quote Link to comment Share on other sites More sharing options...
Glorkbot Posted February 29 Share Posted February 29 Changing the dip-switches and reinserting doesn’t work? Or is this a multi-cart without dipswitches? Quote Link to comment Share on other sites More sharing options...
THX-1138 Posted March 1 Share Posted March 1 12 hours ago, Glorkbot said: Changing the dip-switches and reinserting doesn’t work? Or is this a multi-cart without dipswitches? No DIP-switches. With the 2600+ you just leave the power on and momentarily pull the 32-in-1 cart out and reinsert it and it should start the next game. Works fine. Mostly. 1 Quote Link to comment Share on other sites More sharing options...
Marc Fiorillo Posted March 2 Share Posted March 2 I just bought a 32-in-1 within the past month, and it works fine with my 2600+. Quote Link to comment Share on other sites More sharing options...
Slider271 Posted March 3 Share Posted March 3 You can definitely change games without turning the 2600+ off and on with the power switch. Just take the cart out briefly, slot it back in while powered on and it’ll load the next game Depends if you prefer wear and tear on the power switch or the cart slot 1 1 Quote Link to comment Share on other sites More sharing options...
Pac-Man Senior Posted March 9 Share Posted March 9 On 3/3/2024 at 5:12 AM, Slider271 said: You can definitely change games without turning the 2600+ off and on with the power switch. Just take the cart out briefly, slot it back in while powered on and it’ll load the next game Depends if you prefer wear and tear on the power switch or the cart slot I would like to add a third way: Just pull the usb cable out of the usb power adapter and replug it in. It's the best solution concerning lifetime of the 2600+ hardware. But I have to admit that it depends on your distance to the power source. 2 Quote Link to comment Share on other sites More sharing options...
