macsonny Posted December 26, 2023 Share Posted December 26, 2023 Hi All, Been reading a little about the Atari 1050 diagnostics floppy software called "Atari 1050 CPS". To get a "quality" floppy for diagnostics testing, I read you need a floppy made on a perfect 1050 drive and it has to be true double density. Is that true? If so, is there a process to make our own quality floppies of the CPS software? I have 8 x 1050 drives, some with a Happy upgrade and 2 x Indus GT drives so assume one of those drive should be able to make the CPS floppy right? Anyone got a process? Thanks macsonny Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted December 26, 2023 Share Posted December 26, 2023 You need to have a copy prepared on a drive with a perfectly alligned head so that you can position any other in a reliable way. Otherwise, whatever you realign, will be aligned as the drive on which you prepared the disk - and it doesn't have to be as it should. Otherwise - there should be no problem. A real DD drive is required because a HD drive is usually an 80-track drive and thus created paths, that are too narrow with a lot of "noise" in between the tracks. Quote Link to comment Share on other sites More sharing options...
macsonny Posted December 26, 2023 Author Share Posted December 26, 2023 6 minutes ago, Peri Noid said: You need to have a copy prepared on a drive with a perfectly alligned head so that you can position any other in a reliable way. Otherwise, whatever you realign, will be aligned as the drive on which you prepared the disk - and it doesn't have to be as it should. Otherwise - there should be no problem. A real DD drive is required because a HD drive is usually an 80-track drive and thus created paths, that are too narrow with a lot of "noise" in between the tracks. Ok. So is it just a matter of loading the ATR file using FujiNet (or similar), formatting the floppy on my Indus GT to DS (on DD drive) and then copying the ATR file to the freshly formatted floppy? 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted December 27, 2023 Share Posted December 27, 2023 The 1050 Diagnostics disk is just a plain disk. Heck, the binaries could be copied however you want. Or boot it via whatever method you prefer. The analog Alignment disk (which is a different part number) is specially formatted and for use with SillyScopes to align the heads, etc. This disk can not be hand made. Some folks of resorted to using official Atari factory formatted disks to help them align if things are really out of whack, but nothing will produce the signals from the original alignment disks.. AFAIK. Quote Link to comment Share on other sites More sharing options...
macsonny Posted December 27, 2023 Author Share Posted December 27, 2023 2 hours ago, kheller2 said: The 1050 Diagnostics disk is just a plain disk. Heck, the binaries could be copied however you want. Or boot it via whatever method you prefer. The analog Alignment disk (which is a different part number) is specially formatted and for use with SillyScopes to align the heads, etc. This disk can not be hand made. Some folks of resorted to using official Atari factory formatted disks to help them align if things are really out of whack, but nothing will produce the signals from the original alignment disks.. AFAIK. Does anyone have a FLuxEngine image of the specially formatted floppy they can share? 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted December 27, 2023 Share Posted December 27, 2023 Quote Link to comment Share on other sites More sharing options...
