Gamestation PRO not recognizing SD card
Obadiah64
Ok, I think I have tried everything that can be done to get this to work, but I thought I would run by you guys to see if I missed anything.
My Gamestation Pro does not recognize any micro sd card I put in it.
I have tried two differnt brands, a Samsung and a ONN.
Both are 32GB cards. I formatted them in the exFAT format.
I used the Windows format tool on both a Windows 10 and 11 system.
I tried using 3rd party sd formatting tools. I also tried formatting on a Linux OS (Mint) system.
Nothing worked.
The unit works flawlessly otherwise. Love it. But I would like to be able add a few more games.
So if anybody has any suggestions on what might be the problem, I would greatly appreciate the help.
I have contacted MyArcade and their suggestion was to do a return and swap.
I purchased it through Amazon and if all else fails, that is what I will do.
Thanks in advance.
Uuhhhhhhhhh.....Well......I....mmmmmmmm.....
Looks like the problem was user error.....appearantly once you format the sd you have to create a folder named "games" on it.......mmmmm.....well, there you have it, case closed..
  • 1 month later...
I accidently did the same thing last night and could not figure out why the new SD card wasn't working for a good hour. Then it dawned on me.
