Charlie_ Posted April 3 Share Posted April 3 I have a backbit 32K expansion. It works when plugged directly into the computer. I can not get it to function properly when plugged into the speech synthesizer. I don't think it is my speech synthesizer as I can plug the peb into it and the disk and 32k in that work fine. Has anyone else tried this combo of bakbit 32k and speech synthesizer? If this would work I wouldn't really need the PEB hooked up for most things I play from the final GROM cart. Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted April 3 Share Posted April 3 i haven’t tried it. if it’s not working post in the BB forum, evie is relay great with responding and implementing fixes. Quote Link to comment Share on other sites More sharing options...
+chue Posted April 3 Share Posted April 3 I don’t know anything about your RAM expansion, just taking a guess. Did you try plugging in the Ram first, and then speech synthesizer into the Ram? Does the Ram expansion require an external power supply? Quote Link to comment Share on other sites More sharing options...
PeteE Posted April 3 Share Posted April 3 (edited) The speech synth doesn't pass through 5v power, so that's probably why it doesn't work. If the backbit 32k has an external power connector, you'll need to power it that way. Edit: From photos, it appears to not have ext power. So it cannot be used with the speech synth between it and the side port. Edited April 3 by PeteE 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 3 Share Posted April 3 59 minutes ago, PeteE said: The speech synth doesn't pass through 5v power, so that's probably why it doesn't work. If the backbit 32k has an external power connector, you'll need to power it that way. You can if you do this modification, but with the caveat you might over-draw the internal PSU. 5 Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted April 6 Author Share Posted April 6 On 4/3/2024 at 5:57 PM, OLD CS1 said: You can if you do this modification, but with the caveat you might over-draw the internal PSU. Thank you for all the replies. I'm going to try to ebay a working speech device and do this 5V mod. The one I own now is in the PEB. Plus, I don't want to risk breaking it. (Not the best at soldering) Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 6 Share Posted April 6 On 4/3/2024 at 1:46 PM, Charlie_ said: I have a backbit 32K expansion. It works when plugged directly into the computer. I can not get it to function properly when plugged into the speech synthesizer. I don't think it is my speech synthesizer as I can plug the peb into it and the disk and 32k in that work fine. Has anyone else tried this combo of bakbit 32k and speech synthesizer? If this would work I wouldn't really need the PEB hooked up for most things I play from the final GROM cart. This is covered in the FAQ. By the way, the speach synthesizer section.. Any 32k sidecar should have a external power supply connection. If it doesn't, then it's short-sighted.. 2 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted April 7 Share Posted April 7 If you need some help soldering, let me know, I can do it for free if you cover postage both ways and will test it. 1 1 Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted April 8 Author Share Posted April 8 I was able to get a voice synthesizer locally and do this simple mod. The backbit 32k seems to work very well connected to it now. Thank you very much for all the help! 4 Quote Link to comment Share on other sites More sharing options...
