Duewester Posted April 13 Share Posted April 13 8 hours ago, visrealm said: I've had no issues with the 7x7 array of adapters. I'm using an Ender-3 V3 KE with a textured PEI build plate. It could be that my printer (and hence my nozzle and build plate) is relatively new (5-6 weeks). I've had my E3 for 5 years plus now and it's so heavily modded, I hesitate to call it an E3 Pro anymore 😁. I love my glass bed over the textured beds. Smooth face on no base adhesion except for tiny little parts. I THINK if I slow down the print, I could get the array to print. Last evening I tried using PETG (tougher and finer finish) for an adapter and I think I prefer it to the PLA. Just FYI, Kailh black keys can be had for $40 or so for 120 on Amazon. I have yard work to do today but, this evening I'll crank up the printer again. OBTW, I used JLCPCB to order some boards. I currently have a discount with them and saved about $20. Once again, thank you @visrealmfor your efforts and as was mentioned in the other forum - time to buy up some mitsumi keyboards before the Ebayers catch on and jack up the prices. 1 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 13 Share Posted April 13 10 minutes ago, Duewester said: Once again, thank you @visrealmfor your efforts and as was mentioned in the other forum - time to buy up some mitsumi keyboards before the Ebayers catch on and jack up the prices. Seriously... they are already trying to get around $100 for TI keyboards, irrespective of make, model, or condition. God help us if they put two-and-two together and jack up console prices. 😠 Quote Link to comment Share on other sites More sharing options...
visrealm Posted April 15 Author Share Posted April 15 I've just uploaded a build video covering the entire upgrade process for those who are interested (currently unlisted): https://youtu.be/9g29EfUJuLM 4 2 Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 18 Share Posted April 18 On 4/15/2024 at 12:54 AM, visrealm said: I've just uploaded a build video covering the entire upgrade process for those who are interested (currently unlisted): https://youtu.be/9g29EfUJuLM So happy for the YT. I had missed the part where I needed to reuse the Space Bar end pieces. Good point about the soldering timeline. And doggone that's a tiny switch for the Alpha Lock. My print(s) are not hugging it very well and I'm afraid to make it too tight. I'll get there though everything else has worked out pretty well. I'm doing most of the pieces in PETG. I think it is stronger and my tolerances seems to "Tolerate" it better than PLA. Thanks again for all you work. OBTW - PCB's scheduled to arrive the 23rd. This one (I call it my Ti99-4aW Polished) has some goofy keys and is a good candidate to see if I can make your board work on it. The aluminum was all mangled, glued and taped when I got it so I decided to polish it and paint it. It's actually quite attractive😍 2 Quote Link to comment Share on other sites More sharing options...
visrealm Posted April 19 Author Share Posted April 19 8 hours ago, Duewester said: So happy for the YT. I had missed the part where I needed to reuse the Space Bar end pieces. Good point about the soldering timeline. And doggone that's a tiny switch for the Alpha Lock. My print(s) are not hugging it very well and I'm afraid to make it too tight. I'll get there though everything else has worked out pretty well. I'm doing most of the pieces in PETG. I think it is stronger and my tolerances seems to "Tolerate" it better than PLA. Thanks again for all you work. OBTW - PCB's scheduled to arrive the 23rd. This one (I call it my Ti99-4aW Polished) has some goofy keys and is a good candidate to see if I can make your board work on it. The aluminum was all mangled, glued and taped when I got it so I decided to polish it and paint it. It's actually quite attractive😍 Thanks for the updates. I'm doing some test prints with PETG today. As this is all relatively new to me, I've only just bought my first rolls of PETG. Did the 7x7 switch adapters in it - turned out pretty swell. It seems a tad softer than PLA. Just looking at your white wonder - the keycaps don't look Mitsumi (too rounded), so you'll need to invent adapters for them which might change the overall height. Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 19 Share Posted April 19 13 hours ago, visrealm said: Thanks for the updates. I'm doing some test prints with PETG today. As this is all relatively new to me, I've only just bought my first rolls of PETG. Did the 7x7 switch adapters in it - turned out pretty swell. It seems a tad softer than PLA. Just looking at your white wonder - the keycaps don't look Mitsumi (too rounded), so you'll need to invent adapters for them which might change the overall height. The Keycaps are actually quite similar. It's the Key switch that's different (taller than MX keys). The way the PCB is built is also significantly different. It's not a box, the key switches mount directly to the PCB. 1 Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 20 Share Posted April 20 My PCB s came in today. Four days early. Supposed to rain all day tomorrow so, good day to build a keyboard.🥰 7 Quote Link to comment Share on other sites More sharing options...
visrealm Posted April 22 Author Share Posted April 22 On 4/21/2024 at 2:41 AM, Duewester said: My PCB s came in today. Four days early. Supposed to rain all day tomorrow so, good day to build a keyboard.🥰 How'd the build go? Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 22 Share Posted April 22 Board is built. I used the insert style verses the self tapping for the space bar and mounting brackets. Did key switches individually. The Kailh switches are just loose enough that they can twist a little and cause keys to look crooked. I reprinted my PCB stiffeners, the screws were too loose so I reverted my horizontal expansion setting to default of -0.2. They are nice and tight now. The spacebar is great. Great job on the engineering there. Unfortunately for me, my PETG adapters for the keys seem to have worn out or something. What fitted great a couple of days ago now won't hold the cap on the switch 😭. I reprinted some with new new horizontal expansion settings to tighten them up and they kinda work. I'll see about some pictures tomorrow. 2 Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 24 Share Posted April 24 No, you're not seeing things. There are Blue and Black (and one white) key switches. I'm using PETG - doesn't snap break like the PLA- and m3 nylon screws in the inserts. Currently printing all new adapters for the keys. The originals jus wouldn't stay on after a few dozen strokes. Almost like they wore down or the Kailh switch stretched. PLA adapters just never would fit right, either too big or too small. Maybe it's the hardness of the PLA that wouldn't give enough to snap in. The wires are some silicone multistrand jumpers I had around. I though "Flexibility" might be called for here. My next one will have a rainbow ribbon that I removed from the Frankenine version one keyboard. OBTW, after I took the picture I put some black tape on the wires where they cross the brace. The braces have a strip of Kapton tape on the back to insulate them from the PCB. 6 Quote Link to comment Share on other sites More sharing options...
visrealm Posted April 25 Author Share Posted April 25 11 hours ago, Duewester said: No, you're not seeing things. There are Blue and Black (and one white) key switches. I'm using PETG - doesn't snap break like the PLA- and m3 nylon screws in the inserts. Currently printing all new adapters for the keys. The originals jus wouldn't stay on after a few dozen strokes. Almost like they wore down or the Kailh switch stretched. PLA adapters just never would fit right, either too big or too small. Maybe it's the hardness of the PLA that wouldn't give enough to snap in. The wires are some silicone multistrand jumpers I had around. I though "Flexibility" might be called for here. My next one will have a rainbow ribbon that I removed from the Frankenine version one keyboard. OBTW, after I took the picture I put some black tape on the wires where they cross the brace. The braces have a strip of Kapton tape on the back to insulate them from the PCB. Nice work. Thanks for the update. The keycap adapters are always going to be the trickiest part to get right - the tolerances are very small. Mine worked well in PLA. I've since tried PETG and have found the retaining bumps on the adapter stem do seem to wear down. Is the main issue the connection of the adapter to the switches? or the keycaps? It sounds like the switches, but if it is the keycaps, the spacebar-specific adapter might work better. The only difference is the retaining bumps on the stems are 0.1mm larger. I might try and pick up a few different brands of switches to try as I've only tested the Akko switches linked in the repo. Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 25 Share Posted April 25 @visrealm, Frankenine has a new Keyboard. Unfortunately, I had previously altered the beige box to get my other keyboard to fit so now there is a gap below the space bar. I started working on the 99/4aW. The key switches are taller and the space bar has a different setup. I'm "Stretching" the PCB mounts (left and Right) 8mm to compensate for the key switches. I don't know what I'll do about the Space Bar yet. The supports are a few mm's wider than the Mitsumi. Too close for an adapter unless I can come up with some Offset of some kind. 3 Quote Link to comment Share on other sites More sharing options...
visrealm Posted April 26 Author Share Posted April 26 3 hours ago, Duewester said: @visrealm, Frankenine has a new Keyboard. Unfortunately, I had previously altered the beige box to get my other keyboard to fit so now there is a gap below the space bar. It's great to see Frankenine with original keycaps. Didn't recognize him 😁 Quote Link to comment Share on other sites More sharing options...
visrealm Posted April 26 Author Share Posted April 26 3 hours ago, Duewester said: @visrealm, I started working on the 99/4aW. The key switches are taller and the space bar has a different setup. I'm "Stretching" the PCB mounts (left and Right) 8mm to compensate for the key switches. I don't know what I'll do about the Space Bar yet. The supports are a few mm's wider than the Mitsumi. Too close for an adapter unless I can come up with some Offset of some kind. In my repository, there are two versions of the space bar support. One which adapts to the original Mitsumi clips (preferred) and another "from scratch". You could try the "from scratch" ones. It might need some tweaking, depending on the thickness of the wire. It comes in two pieces and when printing it, it's designed to be laid out thusly to increase strength in the desired directions: Then you insert the sideways piece into the mount piece and clip your wire in. Again, it's a very fine tolerance type piece, so YMMV. 1 Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 26 Share Posted April 26 @visrealm Thanks fort the pointer on the space barbut, it doesn't quite fit the bill. Turns out the original PCB to TI attachments work fine. Maybe .5mm or so off. The Space Bar pads, I used the original and a ockup of the ones on the original keyboard to bodge together something I think will work. It's printing right now. I had printed one I though would work and it turned out to be about 4mm too tall. I trimmed it down but now I wonder if I left enough room for the inserts. (It's always something with me.) I have a wide assortment of inserts so, I probably have something short enough to work. Well, while I was writing this, my test piece came off the printer. New issue. Need a hole in the center. Back to Tinkercad. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 28 Share Posted April 28 Can anyone speculate as to whether these Cherry MX key switches would fit on the General Instrument keyboard circuit board? The key switches on that keyboard look to be the same profile. Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 28 Share Posted April 28 (edited) 14 hours ago, OLD CS1 said: Can anyone speculate as to whether these Cherry MX key switches would fit on the General Instrument keyboard circuit board? The key switches on that keyboard look to be the same profile. Apparently, I don't have one of the General Instrument keyboards so I'm not much help there.. I have two with the same Keyswitches (the ones I show on the TI-99/4aW)and different keycaps (One is yellow - yes yellow not yellowed - lettering and one is white lettering). I have one of the Keyboards with a boxed in keyswitch that presses two copper plates together inside the keycap, and I had the Mitsumi which now has Cheri MX style keyswitches. Edited April 28 by Duewester Quote Link to comment Share on other sites More sharing options...
TheMole Posted April 29 Share Posted April 29 It's only tangentially related, and I'm sure a lot of you have seen this, but (around 10:30): I wasn't aware! 2 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted April 29 Share Posted April 29 @visrealm Looking forward to this! Amazing look. I have a box of Mitsumi membrane keyboards (Radio Shack clearance BITD) that are no use by themselves. @arcadeshopper I would go for a kit, unless you think that's a dumb idea. If the 3D printing is a big time sink, I could have it done locally. 2 Quote Link to comment Share on other sites More sharing options...
Duewester Posted April 29 Share Posted April 29 6 hours ago, TheMole said: It's only tangentially related, and I'm sure a lot of you have seen this, but (around 10:30): I wasn't aware! He also shows a power supply that is one number different (stock number) from the keyboard. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 30 Share Posted April 30 10 hours ago, FarmerPotato said: @visrealm Looking forward to this! Amazing look. I have a box of Mitsumi membrane keyboards (Radio Shack clearance BITD) that are no use by themselves. @arcadeshopper I would go for a kit, unless you think that's a dumb idea. If the 3D printing is a big time sink, I could have it done locally. you can order with or without 3d printed parts - i haven't assembled one yet.. its in my queue 2 1 Quote Link to comment Share on other sites More sharing options...
Duewester Posted May 10 Share Posted May 10 (edited) Been a while but the 99-4aW has a new keyboard with ALL functioning keys. The original KB had a Non-functioning Space Bar Keyswitch. I had swapped the Left Shift Keyswitch into the Space Bar. Which had left this gap Thanks to the efforts of @visrealm I was able to build (so far) 3 functional Key boards. One in the Frankenine, one for the 99-4aW, a spare "Prototypeing" board. The white board had brass 1/4" keystock for stiffeners. I used brass cause, well, it's easier to drill and tap and I had some. I tapped it to M2 and used 8mm M2 screws and two bars not only make a stiff board, they make it feel weightier. Note also that I used a 90 degree header on the board to interface the wiring harness. On the prototype the wires kept breaking off when the cable flopped around while soldering in the key switches. NOTE: Hindsight - put the cable down with some VFD tape. I used Gateron Buttery Yellow switches. They are five pi and REALLY fit the board well. So well I was tempted to not solder them in but I found that the contacts didn't always snug up against the hole sides. So I soldered them in. The Prototype board also revealed a clearance issue The PCB adapter needed to have more clearance on the shoulder to slide the keyboard over about 2mm. A few minutes in Tinkercad and I had wider shoulder and longer holes. The last issue was the space bar. It's different animal than the one in the Frankenine. I tried to mod the adapters in several ways and I'm just not that good. So, I modded the PCB and used two extra keyswitches. Had I kept going with leftovers from the Frankenine teardown I could have this. At any rate, the 99-4aW Takes its' rightful place on the desk (in front of Colosus ). OBTW - 99-4aW used the F18a Mod 1 for graphics and Frankenine uses the Tang HDMI. Thanks for listening (Reading) and have a great weekend. PS - DO NOT FORGET THE DIODE! Edited May 10 by Duewester added PS 12 Quote Link to comment Share on other sites More sharing options...
Duewester Posted July 23 Share Posted July 23 Finished saving a late model (no Solid State Software plaque) Black Ti-99/4a today. Replaced the Mitsucki keyboard with this wonderful project. Found it pretty cheap on E-bay with known dead KB. Checked it out and the interior was dirty but the cartridge port looked like it had never been used. No markes on side port pins and door was pretty much stuck closed. Video is through a HDMI converter. It's "usable" but a pain on the eyes. I ended up buying a new 3d printer because of this keyboard. My heavily modded Ender-3 Pro destroyed its' hot end (some kind of impermeable blockage in the all metal tube to the nozzle) trying to print the switch adapter in an array of 40. New Ender 3 V3 SE was $159.00 at Microcenter so, I bought one. Best decision I've made in some time about my 3d printing. I guess I could have reinstalled the old hotend but I couldn't find it and besides I ditched the tube for direct drive and it has made all the difference in my experience. Anyway, now three saved keyboards and a test unit. Enough parts for 1 more keyboard - hmmm ebay? 4 Quote Link to comment Share on other sites More sharing options...
visrealm Posted July 23 Author Share Posted July 23 Nice one. Glad you're finding it useful. 🙂 Quote Link to comment Share on other sites More sharing options...
