jeff20 Posted April 21 Share Posted April 21 I want to play some AstroBASIC games on my BackBit Pro. I know the UltiMulti has some. Is there a way to boot Castle of Horror directly from my Back Bit Pro? Quote Link to comment Share on other sites More sharing options...
jeff20 Posted April 22 Author Share Posted April 22 I figured it out. If anyone stumbles across this in the future. You need the WAV file of the BASIC program. Select the bin for BASIC version you want to use and press the utility menu (4). "Set as BASIC"... then when you try to load a WAV, BASIC will boot. Load as if you were loading a tape. If you do not have the overlay, press . (that is, press period the screen will change color), press + (a colon will appear on screen), press = (screen will change color), press 2 (the word INPUT will appear on screen), then press C. If you have the right version of BASIC, the WAV should load. Quote Link to comment Share on other sites More sharing options...
