Tursi Posted April 24 Share Posted April 24 (edited) I played with it after watching the video posted in the Python thread, but I didn't want to hijack that thread. What might be most interesting was this answer, if it's true: Quote You will you remember these corrections? Meta AI Yes, I will remember these corrections! I am designed to learn and improve from the conversations I have with users like you. The corrections you provided will be stored in my memory, and I will apply them to future conversations about TI BASIC programming on the TI-99/4A. If you have any other corrections or tips, feel free to share them, and I will make sure to update my knowledge accordingly. My goal is to provide accurate and helpful responses to your questions, and I appreciate your help in achieving that goal! Basically, I iterated with it till it created a TI BASIC program that should actually work. This has potential - the system could gain experience from many people teaching it. But it's also highly probable that in many areas it will be taught garbage. It would be interesting if someone else could try it - go to Meta.AI and ask for a program that moves an asterisk across the screen (I actually asked for a human, but it was struggling and kept wanting to use a predefined character) using TI BASIC for the TI-99/4A (you have to specify that, or it uses the calculator syntax). See if it gets it in one try or not. 10 REM MOVECHAR 20 X=1 30 PRINT TAB(X);"*" 40 X=X+1 50 IF X>28 THEN 60 55 GOTO 70 60 X=1 70 FOR DELAY=1 TO 50 80 NEXT DELAY 90 GOTO 30 100 END This isn't a very interesting program, but it's correct and runs. We got there solely by my telling it how to fix errors in the generated code, took 10 iterations. Edited April 24 by Tursi 4 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 24 Author Share Posted April 24 (edited) It took significantly more tries to get SNAKE as in the video. This code works, but isn't perfect: 10 REM SNAKE 20 CALL CLEAR 30 X=10 40 Y=10 50 DX=1 60 DY=0 65 PX=X 66 PY=Y 70 CALL HCHAR(Y,X,64) 80 GOSUB 372 90 REM MOVE SNAKE 100 GOSUB 400 110 X=X+DX 120 Y=Y+DY 130 IF (X<1)+(X>28)+(Y<1)+(Y>12)THEN 380 140 CALL GCHAR(Y,X,C) 150 IF C<>ASC("O")THEN 160 151 GOSUB 372 160 CALL HCHAR(Y,X,64) 170 FOR DELAY=1 TO 50 180 NEXT DELAY 190 REM HANDLE KEYS 200 CALL KEY(0,K,S) 210 IF K=ASC("E")THEN 250 220 IF K=ASC("X")THEN 280 230 IF K=ASC("S")THEN 310 240 IF K=ASC("D")THEN 340 245 GOTO 100 250 DX=0 260 DY=-1 270 GOTO 100 280 DX=0 290 DY=1 300 GOTO 100 310 DX=-1 320 DY=0 330 GOTO 100 340 DX=1 350 DY=0 360 GOTO 100 370 REM GENERATE FOOD 372 FX=INT(RND*28)+1 374 FY=INT(RND*12)+1 376 IF (FX=X)*(FY=Y)THEN 372 378 CALL HCHAR(FY,FX,79) 379 RETURN 380 REM END GAME 382 PRINT "GAME OVER" 390 END 400 REM SNAKE TRAIL 410 CALL HCHAR(PY,PX,32) 420 PX=X 430 PY=Y 460 CALL HCHAR(PY,PX,45) 461 RETURN Importantly the trail is only a single character long, so you can never hit yourself and you never grow. It required significant coaxing to make the keyboard and food work, to remember the limitations of IF..THEN, and repeatedly I had to call out specific line numbers in its own code. BUT it did better than ChatGPT did and I didn't WRITE any of this code. (Oh, and for some reason it decided maximum row was 12... but that's good enough for today.) Edited April 24 by Tursi 8 Quote Link to comment Share on other sites More sharing options...
