jschultzpedersen Posted May 30 Author Share Posted May 30 There is always room for improvement. So here is a more generic Basic version of a conversion program. It will convert a decimal number to any number system between 2-16. It can return an unsigned number of any size (if you set the length parameter to 0), while a signed number only works up to the limit of 2 to the n'th power-1, where n is the number system you convert to. You can pad the returned number with zeroes so the string, that is returned with the result has a certain length (excluding any minus sign). The parameters for the sub are: N The decimal number to be converted R The number system to convert to S The number of characters in the answer string. Use 0 to just return the actual length. SF The sign Flag. True means it returns the value in signed format. False returns the value as unsigned. A$ The string holding the result. 10 CALL CNVRT(34000,16,5,0,A$):: PRINT A$ :: A$="" ** Convert 34000 to HEX unsigned. Return string length is 5 11 CALL CNVRT(34000,16,5,-1,B$):: PRINT B$ ** Convert 34000 to HEX signed. Return string length is actual length. 12 CALL CNVRT(42,2,0,0,C$):: PRINT C$ ** Convert 42 to binary unsigned. Return string length is actual length. 20 END 1000 SUB CNVRT(N,R,S,SF,A$) 1010 FLAG=0 :: S$="0123456789ABCDEF" :: L=2^R 1020 IF NOT SF THEN 1060 1030 IF N>=L THEN A$="NUMBER TOO BIG" :: SUBEXIT 1040 IF NOT(N<(L/2))THEN FLAG=-1 1050 IF FLAG THEN N=L-N 1060 V=INT(N/R):: D=N-R*V 1070 A$=SEG$(S$,D+1,1)&A$ 1080 N=V :: IF V>0 THEN 1060 1090 IF S<>0 THEN A$=RPT$("0",S-LEN(A$))&A$ 1100 IF FLAG THEN A$="-"&A$ 1110 SUBEND 3 Quote Link to comment Share on other sites More sharing options...
