Charlie_ Posted May 17 Share Posted May 17 Does PP's adaptions not work with HDDriver? I'm using version 12 of HDDriver with my Ultra Satan and all of PP games adaptions crash the system. New adaptions and old. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 17 Share Posted May 17 I would have thought they would work fine, I use ICD Pro both on a "real" hard drive and a USB stick via NetUSBEE and they (mostly) work fine on my STE. What ST/version of TOS are you using. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted May 17 Author Share Posted May 17 37 minutes ago, TGB1718 said: I would have thought they would work fine, I use ICD Pro both on a "real" hard drive and a USB stick via NetUSBEE and they (mostly) work fine on my STE. What ST/version of TOS are you using. I'm using TOS 2.06 on a Mega STe and TOS 1.62 on a STe What happens is the patch starts with the typical options screen that lists the hardware and any cheat options. Then space bar brings you to a screenshot picture. Space bar again will normally start the patch. However, with HDDriver what you get is HDDriver scans the ACSI ID's again just like at boot and then the system crashes with a few bombs. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 17 Share Posted May 17 Must admit, I never got HDDriver to work on my STE, it always bombs during boot. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 17 Share Posted May 17 2 hours ago, Charlie_ said: I'm using TOS 2.06 on a Mega STe and TOS 1.62 on a STe What happens is the patch starts with the typical options screen that lists the hardware and any cheat options. Then space bar brings you to a screenshot picture. Space bar again will normally start the patch. However, with HDDriver what you get is HDDriver scans the ACSI ID's again just like at boot and then the system crashes with a few bombs. How much memory does HDDriver report using at boot? Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 17 Share Posted May 17 12 minutes ago, TGB1718 said: Must admit, I never got HDDriver to work on my STE, it always bombs during boot. Weird, been using it for years on my STE. Use HDDriver 12 and HDmenu with hard drive adapts. Quote Link to comment Share on other sites More sharing options...
larryleffaovell Posted May 17 Share Posted May 17 14 minutes ago, TheNameOfTheGame said: Weird, been using it for years on my STE. Use HDDriver 12 and HDmenu with hard drive adapts. I have to copy that. Similar situation: Compiled some hard drives with demos, games (also PP ones) and other stuff and never had an issue with my STe, MiST/MiSTer... - but I'm still using HDDriver 11. Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted May 17 Share Posted May 17 I only use 11 on my STe but also no issues. Have you tried getting support here? The HDDRIVER Forum - Index page I think 12 removed some types of HD interfaces from use, though it seems doubtful UltraSatan would be removed as they are rather ubiquitous. Quote Link to comment Share on other sites More sharing options...
BJolly Posted May 17 Share Posted May 17 Same here: Used HD Driver 7.12 & 7.7 on my 4MB STE with Syquest EZ Flyer 230 drives for years without problems booting. Recently resurrected after about 15 years and HD Driver helped me to reclaim the drives - get the up & running again to back them up. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 17 Share Posted May 17 1 hour ago, Atari8guy said: Have you tried getting support here? The HDDRIVER Forum - Index page I had quite a long dialogue via emails from the chap who sells HDDriver, he suggested a number of things, but nothing worked, I'm using an ICD Host Adaptor with a 4.9GB SCSI hard drive, ICD Pro has no problems. Everything works on my STE, I've even used the Diagnostics Cart and it shows all good. Just a bit of a mystery as to why it wonk work. Quote Link to comment Share on other sites More sharing options...
Sporny Kun Posted May 17 Share Posted May 17 If memory serves me right, PP was stressing about how HDDriver was, by default, too memory hungry to be able to run his hd adapted games. So basically, he said to check HDDriver for how to limit the cache size or something like that, and be sure to have no other resident program too. Quote Link to comment Share on other sites More sharing options...
Tillek Posted May 17 Share Posted May 17 9 hours ago, TheNameOfTheGame said: Weird, been using it for years on my STE. Use HDDriver 12 and HDmenu with hard drive adapts. Yeah... I mean, I don't use that guys games, but I use HDDriver on all my systems, including the BBS's which run 24/7 with as heavy a hard drive usage as any Atari today is likely to get, so that includes stints with a Mega ST, Mega STE, Falcon and TT with TOS 1.04, 2.05, 2.06 3.06 and various EmuTos versions. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted May 19 Author Share Posted May 19 I've been playing with HDDriver 12.04 since creating this thread. I have it set to what I believe is minimum memory usage. I remember an older version used to display "HDDriver is set for minimum memory use" at boot. I don't see that in this version. Anyway, it claims to use 58K. This after setting the buffers to 2 each and 0 additional folders. I don't know if that is all it takes for minimum memory usage? Also set it to only scan for devices on 0 ID and that allowed a few of the PP adaptions to run. It is certainly much more compatible now. There are still many of the PP adaptions that will not launch as I described in the first post. They are mainly older ones that launch with START.TOS like Space Quest. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 22 Share Posted May 22 START.TOS games are the older GAMEX ones. Here is a page for GAMEX usage: https://atari.8bitchip.info/GamexUsage.html Btw, people needing a driver to run games should check out Ppera's driver: https://atari.8bitchip.info/pphdr.php. Cool feature he just added is ability to have multiple sections (each of which act as seperate card) and choose which one to use at boot. So can use all of the space on those 32GB cards now :). Quote Link to comment Share on other sites More sharing options...
