JasonACT Posted August 27 Share Posted August 27 Looks like I forgot to reset the "GPU running flag" - to stop the GPU before setting the restart flag (the doco that's available says writing the low GPU address register triggers a full restart) - missing line highlighted in yellow: I also changed main() to only save/scan the first 8 VDP registers (instead of 64) - since being locked prevents any others from changing anyway. Testing other F18A software shows the other methods of F18A detection still need to be implemented (the write only register to specify which status register to read, I guess, but that's crossing over into an area of code best left for @visrealm when he's back from leave). .uf2 firmware attached. pico9918.zip 5 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted August 29 Share Posted August 29 On 8/27/2024 at 7:26 PM, JasonACT said: Testing other F18A software shows the other methods of F18A detection still need to be implemented (the write only register to specify which status register to read, I guess, but that's crossing over into an area of code best left for @visrealm when he's back from leave). .uf2 firmware attached. I wanted to clean up my restart and locked variables which were a quick hack, so they are now in the main Pico9918 struct. While I was at it, I made the changes needed for other software to detect a F18A, along with setting some of the status registers and scanline/blanking memory addresses. I did the sprite limit register too, what is that even for? Anyway, a rhetorical question, the GPU should be pretty usable in the standard graphics modes now. Not to mention there's almost 64KB of RAM available to it as well (check out the main struct to see where GPU code can currently go). pico9918-dev.zippico9918.zip 3 1 Quote Link to comment Share on other sites More sharing options...
visrealm Posted August 29 Author Share Posted August 29 Looking forward to trying it out, @JasonACT 2 Quote Link to comment Share on other sites More sharing options...
Stuart Posted August 29 Share Posted August 29 (edited) Mine arrived safely in the UK today - great job thanks! You can add the Powertran Cortex and my homebrew TM990 video card to the list of compatible computers. Edited August 29 by Stuart 6 Quote Link to comment Share on other sites More sharing options...
visrealm Posted August 29 Author Share Posted August 29 1 hour ago, Stuart said: You can add the Powertran Cortex and my homebrew TM990 video card to the list of compatible computers. Nice one. Will do. 2 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 31 Share Posted August 31 On 8/20/2024 at 12:10 AM, visrealm said: My Tindie page is live now and I've just made some initial stock available to purchase. Note: I'm going away for a week from this weekend (back on September 1st), so I've only made available the quantity I'm confident I can ship before this weekend while also being able to ship stock to @arcadeshopper. There's a chance I'll put more up later in the week. US/Canada: For now, I've disabled shipping to US/Canada to give a chance for Arcade Shopper's stock to arrive. Store link: PICO9918 from Troy Schrapel on Tindie https://www.arcadeshopper.com/wp/store/#!/Pico9918-V1-0-VDP-replacement/p/692136720/category=0 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted September 1 Share Posted September 1 To quote South Park, "And there gone." 3 1 1 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 1 Share Posted September 1 I'll get more 5 1 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 2 Author Share Posted September 2 On 8/30/2024 at 6:12 AM, Stuart said: You can add the Powertran Cortex and my homebrew TM990 video card to the list of compatible computers. I've now updated the GitHub repo with both of these Thanks, @Stuart. Also, if anyone else tests on any other system, I would love to add it to the supported devices list. I will also add it to the Unsupported devices list if it doesn't work. So far, that list is empty, but I'm sure there will be some machines it doesn't work on for whatever reason. 1 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 3 Author Share Posted September 3 On 8/29/2024 at 6:47 PM, JasonACT said: I wanted to clean up my restart and locked variables which were a quick hack, so they are now in the main Pico9918 struct. While I was at it, I made the changes needed for other software to detect a F18A, along with setting some of the status registers and scanline/blanking memory addresses. I did the sprite limit register too, what is that even for? Anyway, a rhetorical question, the GPU should be pretty usable in the standard graphics modes now. Not to mention there's almost 64KB of RAM available to it as well (check out the main struct to see where GPU code can currently go). pico9918-dev.zip 3.93 MB · 7 downloads pico9918.zip 13.51 kB · 8 downloads Thanks again Jason. I've created a new branch for this so I can start playing around with it. visrealm/pico9918 at gpu-dev (github.com) Also a new vrEmuTms9918 branch linked. 3 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted September 3 Share Posted September 3 No worries @visrealm. I've PM'd you a few more changes I made after that build too. 1 1 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 3 Author Share Posted September 3 Got it. Thanks. I read the message, but forgot about it since I couldn't do anything with it at the time. I've committed that change now too. 2 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted September 3 Share Posted September 3 @visrealm vrEmuTms9918.c should have had one other change, to store the write only register 15 value into read status register 15 when set. 3 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 6 Author Share Posted September 6 (edited) Thanks again to @JasonACT for the TMS9900 GPU code, I've had a bit of a go at implementing some of the enhanced display features of the F18A... with mixed results. Here's a couple of short videos showing the progress. The flickery scanlines are occurring when it ran out of time to generate a scanline, so effectively skips an odd or even scanline, reusing the previous odd or even scanline. So far, I've implemented the palette registers, 30 row mode, dual tile layers, x and y scroll registers, horizontal and vertical pages, ecm/bit planes for tile map layers. Something seems awry with tile2 scrolling?? Also, keep in mind, I've never written software for the F18A (nor do I have one to test against), so it's all quite new to me. Lots of trial and error. Still quite a bit to go, and as seen above, we're out of render headroom without some optimization of the existing render code. Edited September 6 by visrealm 7 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted September 6 Share Posted September 6 (edited) 1 hour ago, visrealm said: So far, I've implemented the palette registers, 30 row mode, dual tile layers, x and y scroll registers, horizontal and vertical pages, ecm/bit planes for tile map layers. Something seems awry with tile2 scrolling?? Also, keep in mind, I've never written software for the F18A (nor do I have one to test against), so it's all quite new to me. Lots of trial and error. Did you implement the HSYNC GPU trigger? That's very important for both Mario and Zaxxon. Edited September 6 by Asmusr 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted September 6 Share Posted September 6 (edited) And you need to implement the GPU mapping of the VDP registers into the >6000 region. Edited September 6 by Asmusr 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted September 6 Share Posted September 6 Mario is changing the horizontal scroll offset while the screen is drawn to keep the top part steady. Zaxxon is switching sprite attribute table half way down the screen in order to use more sprites. 1 1 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 6 Author Share Posted September 6 Thanks, @Asmusr I havent added hsync gpu triggers yet. I have added hsync interrupts and registers are memory mapped. I'll look into it tomorrow. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted September 6 Share Posted September 6 These are all my F18A games and demos. F18A.zip 4 1 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 7 Author Share Posted September 7 Did a bit more on it this morning. I've implemented hsync and vsync GPU triggers, which did... some... stuff. Also tried out processing the tilemap bitplanes 4 pixels (one nibble) at a time using my old mate, the lookup table. Check it out here: The lookup table is 8kB, mapping up to 3x bitplane nibbles (16^3) to a 16-bit value containing 4x 4-bit pixel color values which can be combined with the ecm-level palette. Still many other issues going on, but... the results are seriously impressive! Well... I'm impressed anyway. It's given me a glimmer of hope this might be possible. 4 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 7 Author Share Posted September 7 I think I'm missing a start page setting. I've uploaded a video showing @Asmusr's ECM3 scrolling demo, and it looks like it should be swapping pages, but I'm not doing it. I think that would explain the super mario weirdness too. I've attached the documentation I'm working from and it might be outdated or missing some stuff. In the PDF, there is mention of a "start page" setting, but I can't find it anywhere. Does anyone have better documentation? f18a_register_use.ods F18A documentation.pdf 3 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted September 7 Share Posted September 7 I finally installed the PICO9918 by @visrealm inside my TI-99/4QI console, and the picture is crystal-clear on this small VGA screen which replaces the bulky CRT I was using before. I also installed a larger VGA monitor that arrived from eBay to my main TI99 v9938 system. 5 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted September 7 Share Posted September 7 50 minutes ago, visrealm said: I've attached the documentation I'm working from and it might be outdated or missing some stuff. In the PDF, there is mention of a "start page" setting, but I can't find it anywhere. Does anyone have better documentation? That's the same doco I have. This brought up 3 hits though: https://forums.atariage.com/search/?q="start page"&quick=1&type=forums_topic&item=207586 2 Quote Link to comment Share on other sites More sharing options...
visrealm Posted September 7 Author Share Posted September 7 Ah. that was it. It is mentioned in the PDF, but I missed it: VR2: MSB LSB 0 1 2 3 4 5 6 7 X X X X A0 A1 A2 A3 - Normal X X X X A0 A1 VPS HPS - Vertical / Horizontal Page Start from VR29 Thanks, Jason. 4 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted September 7 Share Posted September 7 1 hour ago, visrealm said: Ah. that was it. It is mentioned in the PDF, but I missed it: VR2: MSB LSB 0 1 2 3 4 5 6 7 X X X X A0 A1 A2 A3 - Normal X X X X A0 A1 VPS HPS - Vertical / Horizontal Page Start from VR29 Thanks, Jason. The documentation about scrolling is outdated. Scroll limit registers and fixed map no longer exists. Maybe you can get some hints from the Js99er source code? https://github.com/Rasmus-M/js99er-angular/blob/master/assembly/f18a.ts https://github.com/Rasmus-M/js99er-angular/blob/master/src/app/emulator/classes/f18a.ts 4 Quote Link to comment Share on other sites More sharing options...
